| Suspension / Brakes / Chassis All suspension, brakes and chassis discussions. |
Thread Tools |
#1 | |
Tampa Gulf Coast Family
Drives: 1977 Z28, 2SSRS 2010 M6 Join Date: Sep 2009
understeer help
I have a 2SS M6 with 403 rwhp. I've been autocrossing 6 or 7 times with it now and doing pretty well in my local club. Everybody really seems to like it judging by how many people ask to ride along. My suspension has Pedders bushings (radius rods, diff, and subframe), Pedders 27mm sways front/rear, Pedders SS brakelines, Pfadt trailing arms, and I got a set of rear stock wheels for front so 275/40/20 all around. I just had an alignment and front camber is -1.6, caster 6.4, toe out .02; rear camber is -1.16 and toe .04. Swaybars are set in middle settings front/rear, will definitely go full hard in rear. Tire pressures were 41 psi front and 40 psi rear.
Now the issue is the dam understeer, I guess these mods have helped a little but not a lot. The car has so much power for these smaller courses that it kills me not to be able to use it all. I beat a bunch of nice/expensive cars but I want to go faster. I've been thinking about coils or coilovers to help with handling but really not too sure that will help. Is my only option another set of wheels and slicks, which will put into a class with mostly racecars. The video is my first run of the day, it was a 39.6, by the end of the day I knocked it down to a 37.5. Any suggestions or flaming will be accepted. <object style="height: 344px; width: 425px"><param name="movie" value="http://www.youtube.com/v/agycQ4DiRJU?version=3"><param name="allowFullScreen" value="true"><param name="allowScriptAccess" value="always"><embed src="http://www.youtube.com/v/agycQ4DiRJU?version=3" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="425" height="344"></object>
![]() Drives: 2010 2SS RS, 2007 FJC Join Date: Nov 2009
Cool video. Looks like you had fun. You can try a couple of easy things to reduce understeer: 1. adjust the front swaybar to the softest setting and the rear to the stiffest and 2. lower the rear tires pressure. I assume you still have the OEM springs and dampers so I'm a little surprised that caster is not within factory spec of 6.7 to 7.1 degrees. More positive caster (Pfadt recommends 7.5 to 8.5 degrees), more front negative camber and less rear camber would all help decrease understeer.
![]() Drives: 2010 camaro Join Date: Sep 2009
Looks like you are having a good time with your car.Changing to drop springs or even coil overs will help the handling but you can get some improvement by changing the rear camber more positive to help reduce the under steer and toe the front out more to help the turn in when you are auto crossing this is where I would start. Good luck.
![]() Drives: Rally Yellow Camaro+Avalanche Join Date: Dec 2009
Big car, big horse power and small course do not match. You'll never be able to pedal to the metal, ever. Being not as agressive is the key for small courses and our Camaros, but then, where's the fun in that?
C.A.I., Apex Scoop, ARH LT, Pypes Cat Back, Barton Short Throw, JDP Tow Hook
Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler Pfadt coilovers, camber plates, trailing arms & differential bushings. BMR adjustable toe-rods. Pedders ZL1 barz, rear cradle inserts, radius arm & steering rack bushings. Hotchkis Max Chassis Brace (minus tunnel cross-over piece for SCCA rules) 1LE 3.91 gearzzz. Drive Shaft Shop Road Race Axle Upgrade. TurnOne power steering pump. Forgeline GA3-R 19x11 + Hoosier R6 315/30R19 426 HP @ 5550 RPM / 427 TQ @ 4700 RPM |
Suspension Specialist
Drives: 2011 Camaro Join Date: Aug 2010
You can do a lot of add ons, but in terms of alignment, change the rear camber to -.5, the front toe to .1 toe out each wheel. Add front caster.
This will give you maximum reduction in understeer, without adding additional parts mike dms |
#6 |
Won't this amount of toe-out in the front make the car track street roads really agressively?
#7 |
Thanks for the input guys, going to do the swaybar suggestion for sure and will talk to my alignment guy. I'm still interested in lowering coils or coilovers but still don't see this helping the understeer seems more for looks, I don't know. Next mod will have to be driver, being patient and realizing that these cars will never turn as sharp as a lightweight Miata or S2000. Make my turns wider and slower, but showing that kind of restraint is so hard.
#8 |
Get a pedders complete set up for the track, you will be shocked at the difference.
#9 | |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Halltech Yellowjacket fed Kooks LT's/ Dynomax VT Pfadted (springs/sways) Aint nobody got time for that |
#10 | |
![]() Drives: it like I stole it. Join Date: Feb 2010
#11 | |
Evil Pedders Guy Since 06
![]() Drives: His Wife Crazy Phone:860-880-0486 Join Date: Jan 2008
#12 | |
Shop Owner
Drives: 1 ton silverado Join Date: Jan 2009
#13 | |
Thanks again everyone for the input.
#14 |
#15 |
Needs Lowering
![]() Drives: Pedders USA Camaro Justice Join Date: Jun 2007
Bruce, Rich, Rob and Mike know what they are talking about. Well done Pedders Suspension Specialists! Let us know how your next event goes.
![]() Camaro Information | Buy Pedders Parts | Pedders Dealers | The 5th Gen Book | GMPP | SEMA Hot Wheels Camaro Brochure | EOD Fund Facebook Pedders Head Office 248.522.8021 |
#16 | ||
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
So, with that said, you should investigate tuning with sway bars to solve your balance requirements for autocrossing. It is well documented that any understeer can be solved with the right sway bar upgrades. If you have any doubt, just take a look at what kind of results Erik from Torq is getting with his National autocross efforts! Not only was he one of the victorious cars down at the Camaro5Fest autocross competition, he recently had a momentous 3rd place overall at the national Holley LS Fest in Bowling Green! No other late model car could touch him! He has the balance dialed in pretty well for consistent podium finishes! Torq Autocross thread Give us a shout with any specific set up questions. We have been fielding autocross questions all day today and yesterday on the phones, seems to be a popular subject right now! As for us, its off to NASA Nationals this week! Last edited by PfadtRacing; 09-14-2010 at 08:47 PM. |
#17 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS/RS IBM Black Polished Join Date: Feb 2009
More HP fixed my understeering issue..try getting around 600 rwph...not kidding I am totally serious here....I had serious understeer at 400 rwhp but the additional 200 allows you to kick the ass out with ease.
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
#18 |
PM sent
#19 |
Josh, thanks for taking the steps toward reducing understeer with Pfadt. Post up with your findings after installing all of your new parts. We will be interested to find out how they have changed the balance of the car, and its overall competitive edge.
#20 |
I'm interested and excited myself. Will post up as soon as I can. Thanks.
| Thread Tools | |
| 5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 138 | 05-09-2013 03:58 PM |
| Kill The Factory Understeer With Pfadt Sport Sway Bars From Apex Motorsports!!! | Apex Chase | Suspension / Chassis / Brakes | 185 | 08-11-2012 05:29 AM |
| UNDERSTEER: Solutions how to correct it? | Mikamaro | 5th Gen Camaro SS LS LT General Discussions | 23 | 02-18-2010 07:05 PM |
| Pedders Camaro was the fastest Camaro at the Optima Challenge! | Info@PeddersUSA.com | Suspension / Brakes / Chassis | 118 | 12-02-2009 11:06 PM |
| How bad is the Understeer? | Kingdipsy | 5th Gen Camaro SS LS LT General Discussions | 17 | 08-20-2009 08:11 PM |
