Cold Air Inductions
Old 09-12-2010, 12:04 PM   #1
Sean@Phastek
Sean@Phastek's Avatar
Drives: 2010 Camaro X5 Turbo
Angry rear seats.... how to remove?
Don't have my car with me right now... does anyone know how to remove the bottom rear seat? I'm getting horrible indentions in the fold-down rear seat when I lay it down for more trunk room, from the rear seat belt buckles. GM...
Sean@Phastek is offline   Reply With Quote
Old 09-12-2010, 12:13 PM   #2
Brownhornitt
Brownhornitt's Avatar
Drives: 2006 White Corvette Convertible
In my late model Firebirds, I could put the buckles under the rear seats. Can you do that with the new Camaros?
The Corvette is an animal.
Brownhornitt is offline   Reply With Quote
Old 09-12-2010, 12:25 PM   #3
firefighter1
firefighter1's Avatar
Drives: 625 rwhp red jewel ss COTW 11-8-10
Just pull up from the front and it will come un-unclasped, then pull the seat up and it will come off the hooks on the back. I think it's only got 4 clips, BUT, let me tell you it's VERY loud in the car with out the seat! Long story, but, that's why I had it out for a week!
Jess
firefighter1 is offline   Reply With Quote
Old 09-12-2010, 12:30 PM   #4
mlee
www.CamaroFest.org
mlee's Avatar
Drives: 2017 A10 ZL1
What he said... pretty much just snaps in... Not sure what the fold down would rest on w/o the seat in place.
Maybe you could remove the buckles or just tuck them under the seat.
Old 09-12-2010, 12:54 PM   #5
daphatgrant
June '10
daphatgrant's Avatar
Drives: '10 2SS/RS RJT
These cars have back seats
j/k
RJT, 2SS/RS, M6, Black Int, Sunroof.
daphatgrant is offline   Reply With Quote
Old 09-12-2010, 01:01 PM   #6
mlee
www.CamaroFest.org
mlee's Avatar
j/k
Sean obviously doesn't need it... sounds like he needs one of these...
Old 09-12-2010, 09:36 PM   #7
Sean@Phastek
I don't know if I could pass on that killer wood-grain setup mlee..... lol!
I pulled the rear seat bottom out.... and when you lay down the rear seat now, it gets almost completely flat, and still rests on the front leg support - not bad!
Only problem now is the seat belt buckles hit the seat-back worse now - the buckles have two little prongs that won't let them "lay forward" and not ruin the seat-back. I guess they could be unbolted, but I think I'm just going to leave the back seat in and up - i might have found another solution for this little project (not telling yet!!!)
And yes, it is KILLER loud like that. I have the straight pipes on my car too, so its extra extra loud for me.
Old 09-13-2010, 08:10 AM   #8
mlee
www.CamaroFest.org
mlee's Avatar
Originally Posted by Sean@Phastek View Post
I might have found another solution for this little project (not telling yet!!!)
Kinda figured you were up to something with this question...
Old 09-22-2010, 02:54 PM   #9
HBMike
HBMike's Avatar
Drives: 2010 Synergy Green HBR
It's 5 bolts to remove the back seats.
pull the back seat down and look on the far left side. push the padding down a bit to get to the bolt. I used a 15mm socket to break it loose then just my fingers.
Then lift the whole seat, bottom and top fold down up. Again look to the far left you will see another bolt looking the same as the top, remove it in the same fashion. Repeat on the other side.
Then in the very middle there is 19mm bolt to remove the entire seat belt / seat assembly. Remove it.
The seat then just picks right up off the center bolt.
You can hear the gas tank sloshing with the seats out, pretty weird.
I did this when I had my seats done is green/black leather.
HBMike is offline   Reply With Quote
Old 05-18-2013, 12:52 AM   #10
JeffyS94
Drives: 2010 Camaro 1LT cyber grey metallic
Does the bolt in the middle stick up after the nut is removed? I would not like that staying up all the time, but I don't want to shave it off just in case I wanna revert back to stock..
JeffyS94 is offline   Reply With Quote
Pfadt Race Engineering DIY Drop Spring installation procedure PfadtRacing Suspension / Chassis / Brakes 20 09-23-2011 10:31 PM
How to remove rear side markers? CUPRA 5th Gen Camaro SS LS LT General Discussions 3 08-30-2010 11:50 PM
Has anyone taken rear seats out? Revenant Cosmetics and Lighting Modification Discussions 3 07-29-2010 01:14 PM
Why rear seats room is so little 80 LS7 6L90E Camaro ZL1 Forum - ZL1 Specific Topics 25 03-08-2010 06:53 PM
No confirmation number? jamesc1123 Camaro Price | Ordering | Tracking | Dealers Discussions 12 02-21-2009 09:49 PM
