JUICEDMOTORSPORTS
Old 09-12-2010, 03:19 PM   #1
hillbennerdeluxe
the legend
hillbennerdeluxe's Avatar
Drives: 2010 Camaro 2SS 6 speed manual
not going into second!
when i shift from first to second it grinds n i have to go into third gear. anyone had this issue?
hillbennerdeluxe is offline   Reply With Quote
Old 09-12-2010, 05:54 PM   #2
SS 376
SS 376's Avatar
Drives: IBM 1SS
Need more info. Are you trying to shift into 2nd when skip-shift is trying to send you to 4th? Is it an actual grind or just harsh? Is the grinding occurring under hard acceleration? Power-shifting, etc.?
SS 376 is offline   Reply With Quote
Old 09-13-2010, 01:03 AM   #3
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
I'll bet you are encountering the skip shift. Go higher in your rpms and you will avoid it.
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 09-13-2010, 01:22 AM   #4
JMAC2011
MONGOOSE
JMAC2011's Avatar
Drives: 2011 SS Camaro M6
I just bought my 2011 2SS and it is not my first 6 speed manual. I have 1,400 miles on it. Under full acceleration I can't shift quickly from 1st to 2nd without getting the grind either. I don't have this problem from 2nd to 3rd or to any other gear for that matter. When I slow down my 1 to 2 shift just a little bit, it goes into second just fine. This kind of pisses me off. I installed a Hurst shifter and still the problem exists. It is a dragstrip liability. The T56 in my 94Z28 never had this problem; What's going on with the TR6060? I'm not looking for speculation... does someone have a real answer?
JMAC2011 is offline   Reply With Quote
Old 09-13-2010, 02:23 AM   #5
SILVER BULLITT
Drives: 2010 SIM 2SS/RS MONSTER
damn!
HP MONSTER' SOUTHERN CALIFORNIA BUILT, LMR CAI, CUSTOM GRIND CAM, CUSTOM BUILT CNC PORTED AND POLISHED HEADS, FAST 102MM INTAKE MANIFOLD,ARH LONG TUBES AND HIGH FLOW CATS, BIGGER INJECTORS, VALVES SPRINGS RETAINERS, MGW SHORT SHIFTER, EIBACH SPRINGS, FACTORY CHROMED WHEELS, BLACKED OUT EMBLEMS, BLACKED OUT ROOF,BLACKED OUT MARKERS, 3.5 INCH ELECTRONIC CUTOUTS, FLOWMASTERS, ZEX WET 150 SHOT, FOR A GRAND TOTAL OF =630 REAR WHEEL TORQUE ,AND 600 REAR WHEEL HORSEPOWER
MY JOURNALhttp://www.camaro5.com/forums/showth...02#post2023802 SOON TWIN TURBO SETUP
SILVER BULLITT is offline   Reply With Quote
Old 09-13-2010, 01:45 PM   #6
nuptualnemesis
NuptualNemesis
nuptualnemesis's Avatar
Drives: Silver 1SS M6 - 480hp 11.57/120.79
Skip shift is speed oriented not rpm related. But I did have a problem trying to shift too close to speed limiter and it would stick in neutral till we tuned it out of the program.
Don't release clutch to soon if speed shifting. Push seat closer to front to ensure pedal all the way to the floor, and it will take a little longer to release.
Wrap fingers around shift knob, with palm on right side and thumb over fingers, not shift knob, and pull straight back.
nuptualnemesis is offline   Reply With Quote
Old 09-13-2010, 02:02 PM   #7
superman
Drives: 2011 Camaro 1SS
Fail. It's not just speed oriented.
Skip Shift activates under 21% throttle in 1st = 2500 rpm (max).
superman is offline   Reply With Quote
Old 09-13-2010, 06:44 PM   #8
hillbennerdeluxe
the legend
no its not skip shift it grinds n cant get it into gear! it doesnt do it for anyother gears and i i have come to see from PM's thats i am not alone there are a few other ppl with the same problem! so if anyone have issue when the push there cluch in n it makes a chatter or fludder sound get it looked as asap cause ur showin signs of the same issue as me
Old 10-05-2010, 02:50 PM   #9
RipperFox
Grrr!!!
RipperFox's Avatar
Drives: BLK/IOM '11 2SS/RS
Yup, I have it to. Exactly as you state. Hard acceleration, first to second, grinds and wont go into second.
Rules for ordering a car.
1. Dealers are liars
2. Buy off the lot
3. See rule #1
RipperFox is offline   Reply With Quote
Old 10-05-2010, 03:40 PM   #10
06blownSS
06blownSS's Avatar
Drives: 2010 Camaro SS
I too have had this happen to me many times. I have learned to avoid it by pressing really hard on the clutch and delaying the shift to 2nd a fraction of a second later. I think its a driver problem, we try too hard to go insanely fast into second our transmissions dont like it.
Black on Black on Black 2010 Camaro 2SS LS3;K&N intake, Dynatech 1 7/8 catted LTs, Borla S Cat Back, Eibach prokit, Pfadt rear trailing arms, JRE tuned
06blownSS is offline   Reply With Quote
Old 10-05-2010, 04:08 PM   #11
Blueclyde
Blueclyde's Avatar
Drives: 2016 2SS
I agree. Driver error. I have encountered this myself. You have to time your clutch and shifting just right or it will grind on the 1-2 shift. Slow it down a little and all works perfect.
Blueclyde is offline   Reply With Quote
