Old 09-13-2010, 11:56 AM   #1
TinyToasta
TinyToasta's Avatar
Drives: way too fast....
ARH Headers & MTI Cam using stock mufflers (LS3) - Help!
Hi guys,
I'm planning on putting some headers and a cam on my LS3, whilst keeping the stock mufflers.
Why keeping the stock mufflers you ask?
I'm living in Germany - the country with the most rigid and admittedly stupid legislation on how loud a car is supposed to be.
My current set-up is a Volant CAI, SLP Loudmouth II (Axle-back) and a custome tune, pulling 419rwhp / 459rwtq. Noweeds will be added in the next couple of days (just for fun of course, good to have that "cops-in-proximity" switch)
The plan is to add an MTI Racing Cam Stage 2 (Stage 3 likely if it makes technical sense), the MTI LS Valvetrain Package, MSD Coils and the ARH Header System (1 7/8'' catted with X-Pipe - p/n CA201078W/C) and the to put the stock mufflers back on (the noweeds would stay on just for the fun of it...)
Questions are as following:
- Has anyone tried a similar set-up (with LS3 stock mufflers)?
- Key question: How loud would this system be compared to a stock set-up, or to a stock set-up with LMII Axle-back?
- How much hp would get lost using the stock mufflers on such a set-up? (Goal is to get close/exceed to the 500hp barrier)
- Has anyone found a soundfile/video on a similar set-up (cut-outs closed of course...)?
Might be an exotic setup, maybe that's why I haven't found a helpful thread (yet)...
Any guidance and help is well appreciated!
Greetz from across the great pond!
tee
custom build forged LSA, 379ci, TVS2300@15psi, 696rwhp/688ft-lbs, built by DH Individual, Customkingz, tuned by Jannetty Racing
JRE rough idle cam, JRE ported lower intake manifold, OD cog drive, 6% OD crank pulley, ported ls3 heads, NW102mm TB, 1/2'' RDS spacer, IW 8-rib drive
Pfadt Cradle Bushings, Arms & Rods, Pedders Supercar w/FE4 conversion, ZL1 sways, HE Twin Carbon Street Slayer, ZL1 Rear End (3.73)
CTS-V Brake upgrade, Street: 22'' Vossen CV1, Strip: 18'' Forgestar F14 on MT Street Radials
TinyToasta is offline   Reply With Quote
Old 09-13-2010, 12:05 PM   #2
Supercharged2SS
Supercharged2SS's Avatar
Drives: 2010 2SS - Supercharged
I had the exact same set up for the most part. I have the MTI stage 2 and the ARH LT's. the car was louder, but not that noticible, sounds like a deep growl at idle. I actually wanted the car louder and went to Borla atak axle back after driving with the stock mufflers for a few months. now it's a lot louder. not sure on the power gains, when I had mine done, I also added the maggie so mine is different. I was pleased with stock, didn't like the huge mufflers hanging below car though.
Supercharged2SS is offline   Reply With Quote
Old 09-13-2010, 12:43 PM   #3
A.R. Headers
Drives: Pontiac G8 GT
TinyToasta, The stock mufflers will rob no power. They will be relatively quiet at idle and cruise but really come on under hard acceleration. Our ARH axle back is a great alternative if you don't want any rasp, which the stock mufflers seem to have under hard acceleration. The ARH mufflers won't get you harrassed when cruising around town but will shake the walls when you're banging gears. Bottom line, either will work but the ARH system doesn't rasp. Hope this helps.
Nick
A.R. Headers is offline   Reply With Quote
Old 09-13-2010, 12:59 PM   #4
TinyToasta
TinyToasta's Avatar
Nick
That helps a lot, thx Nick.
I'm really leaning towards going for the whole thing (Cam / Headers). Starting off with the LMII on and switching to OEM mufflers if noise is getting "out of control". The cam just might add that crucial idle noise, without taking it beyond at higher revs... sure sounds like a plan to me, as long as it's just a tad above the "reasonably silly" German level
The stage2 or stage3 question is still bugging me, though! Stage3 would surely take me closer to 500hp I guess, but is maybe just about too much....
Old 09-14-2010, 02:14 AM   #5
Luttinger
Luttinger's Avatar
Drives: Camaro SS/RS
You will see how the stage3 will work within that setup in October. ;-)
I've choosen quite the same setup, without LTs but race cats from solo performance. GMPP street legal exhaust and I hope too that the car wont get to loud for German purposes.
Camaro SS/RS, summit white, Afterburner Taill., GMPP exhaust, 22inch Forgiato Inferno, T-Rex Grille, KW V1, RK Carbon Diffusor...
Luttinger is offline   Reply With Quote
Old 09-14-2010, 02:52 AM   #6
TinyToasta
TinyToasta's Avatar
Can't wait to hear the "White Lady" then - good luck @Kraftwerk
Soundwise both LT headers and high-flow cats have their share on the overall loudness of the car. But I'd assume that the cats are adding more db than the LTs , right?
Old 09-14-2010, 03:21 AM   #7
Luttinger
Luttinger's Avatar
Right... the stock cats are real db-eaters. ;-)
The LTs will only influence the sound itself. The GMPP Exhaust is near to the stock exhaust, so I hope it will still be driveably after installing the solo cats.
Old 09-14-2010, 06:40 AM   #8
Richy_Rich
FAVOR
Richy_Rich's Avatar
Drives: Many Different Rides
I'm planning this same set up with MTI, using the stage 3 cam and valve train kit with ported heads and tune... most likely will be adding the CORSA or MAGNA FLow axel back system. From what I understand the stock mufflers are way too raspy at WOT. The CORSA eliminates the cabin drone and the Magna's... we'll they really bark a deep intimidating bark.
Please be kind when you drive; thank you.
Richy_Rich is offline   Reply With Quote
Old 09-15-2010, 02:17 PM   #9
TinyToasta
TinyToasta's Avatar
I've been doing some research on the Magnaflow Street Series as an add-on to the above set-up. Looks like this is an obvious replacement for my Loudmouth II Axle-Backs, and by far the better option than switching back to the OEM mufflers.
This should milden the overall sound whilst maintaining the deep and not too loud tone I'm looking for
Has anyone done the same sort of set-up? Dynoed? Videos?
MTI Stage2 Cam
ARH 1 7/8'' LTs, HighFlow Cats & X-Pipe
Magnaflow Street Series Axle Back
I'd also be curious if someone has opted for the MTI Stage3 Cam (again dynoed, videos...)
Old 09-15-2010, 02:57 PM   #10
mikeSS
mikeSS's Avatar
Drives: 2015 c7
wait.... you were pulling 419 rwhp, and 459 rwtq
thats not possible with just a axle back and CAI and tune maybe in Germany but not here lol
Old 09-15-2010, 03:29 PM   #11
TinyToasta
TinyToasta's Avatar
Odd thing I know, we've been completely baffled after all the pulls we did.
I pulled 622Nm several times, that should be 458,7 ft-lbs, right?
The shop where we tuned and dynoed the car is one of the most renown over here in Germany, with loads of experience in US-cars, I do trust them blindly... They have never seen similar results on such an engine, so they tested it times after times with no changes....
although I know that dynos do vary quite significantly, we had some other LS3s pulling on the same dyno with similar mods&conditions, with results you'd expect from this engine in a range of 377 to 401 ft-lbs...
I'm pretty sure that the fuel quality here in Germany makes a significant difference in combination with the very thorough tuning we did over 2 days... not to forget the brutal break-in period this car had from the very beginning
Let's see how the next pulls go after adding the LTs and the cam....
Old 09-15-2010, 03:39 PM   #12
2010 2-Tone
2010 2-Tone's Avatar
Drives: 2010 RY 2SS with Custom Stripes
with those LT's does the cats help in keeping it from being louder or are they just for emissions?
-Custom Stripes, Eibach Drop Springs
-MagnaFlow 3" Catback with X pipe
-ADM CAI-Street Version, SLP 160 T-Stat
-Ragin Racin Custom Tune
-Kooks LT Coated Headers, Heritage Grille
-Barton Short Throw Shifter
-Slotted & Dimpled Rotors
-Powercoated Calipers by Mike
-Hawk Ceramic Pads
-Painted Roof
-Painted Gills & Back Panel
-3-M Clear Bra, AAC Plasma DRL's
404rwhp and 403tq
2010 2-Tone is offline   Reply With Quote
Old 09-15-2010, 03:49 PM   #13
mikeSS
mikeSS's Avatar
Drives: 2015 c7
unless europe has a different way of reading power... even with great fuel, stock ls3s are putting down like 350-360 stock..... axle back does not give any gains, is its only the CAI, and a tune giving you 100TQ over stock not possible
http://www.camaro5.com/forums/showthread.php?t=106073
this guy is using a supercharger, CAI , headers , tune and look what numbers he is getting
Old 09-15-2010, 03:50 PM   #14
TinyToasta
TinyToasta's Avatar
Well, in my case it sure is both. No Cats could be seen as tax fraud over here, and too much sound is just attracting the wrong sort of individuals
LS3 CAM AND HEADERS DYNO ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 53 02-13-2016 06:15 PM
LS3 engine specifications Tran Wiki 3 10-06-2010 10:56 PM
LS3 SS Stock Mufflers for Sale SSTony V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 1 06-23-2010 06:01 PM
ARH Long-Tubes Installed on LS3 with Factory Mufflers ZZcamaro Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 73 08-31-2009 09:57 PM
2010 Camaro ARH Headers IN STOCK!!! Frans96ss V8 Bolt-Ons & Tunes 4 06-30-2009 11:48 PM
