Old 09-13-2010, 01:55 PM   #1
JosephMcTyre1205
JosephMcTyre1205's Avatar
Drives: 2010 Camaro SS
Starting problems any answers
Every time i start my car it makes almost like a backfire type noise every time. I first thought it was normal and then when i rented another camaro when i got back from afghanistan the other car same model never did this. Im just tyring to find out if somethings wrong or if its just me any help would be amazing.
JosephMcTyre1205 is offline   Reply With Quote
Old 09-13-2010, 03:17 PM   #2
MG
MG's Avatar
Drives: 2011 Camaro
Mine did it for the first 300 miles, then it went away. Too bad I liked it...
MG is offline   Reply With Quote
Old 09-13-2010, 03:21 PM   #3
KeepItGreasey
So It'll Go Down Easy
KeepItGreasey's Avatar
Drives: Camaro SS/RS
just take it to the dealer so they can tell you it's normal, even though you have the gut feeling that it's not hahah
really... you should take a video of your start-up so we can hear. is your car AUTO/MANUAL? i hear a "pop" when i start my L99, but definitely not a "backfire"
is your exhaust stock?
KeepItGreasey is offline   Reply With Quote
Old 09-13-2010, 03:31 PM   #4
SC2150
Sounds like the DOD hanging for a sec.....
Old 09-13-2010, 04:08 PM   #5
JosephMcTyre1205
Its auto and ill try and get a video up asap. Its just maks a quick pop when starting iv put a little over 5k on the car sense buying it. just trying to find out if it was normal. and the exhaust is factory
Old 09-13-2010, 04:39 PM   #6
Rip
Drives: 2011 SS/RS
My LS3 does the same thing.
Rip is offline   Reply With Quote
Old 09-13-2010, 08:08 PM   #7
Oldrocker
Oldrocker's Avatar
Drives: 2010 SS2/RS Victory Red
My L99 does it on occasion and has since I bought it new, even after installing a Pypes cat back system.
Oldrocker is offline   Reply With Quote
Old 09-13-2010, 08:09 PM   #8
Camaro_Custom_Painted
Choke on that causality!
Camaro_Custom_Painted's Avatar
Drives: 2010 2SS/RS
My L99 does it on every start. No big.
Camaro_Custom_Painted is offline   Reply With Quote
Old 09-13-2010, 08:42 PM   #9
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
Drive at about 40mph while giving it a little throttle then let off the throttle and let the engine idle down that should make a popping noise. If thats the same sound you're hearing then it's normal. If not has the car been sitting for a long time? Could be old gas.
9/26/09 Took delivery!
Old 09-13-2010, 10:45 PM   #10
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
Mine would pop too. Honestly, the fuse pull might be your answer here. After that my pop and decel popping was virtually gone.
HeavyD is offline   Reply With Quote
Old 09-14-2010, 07:59 AM   #11
Pro Street
Pro Street's Avatar
Drives: 2SS/RS
My L99 does it too!
2016 ZO6 2LZ A8
CamaroFest II-III-V
Pro Street is offline   Reply With Quote
Old 09-14-2010, 05:29 PM   #12
JosephMcTyre1205
thnxs for all the hits really helped me out thnxs guys
paint chip problems gone-south Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 361 07-19-2016 01:05 PM
Automatic Transmission Problems Kyzer Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 30 07-13-2016 07:26 PM
1st and 2nd gear problems. 1SS 6M jnm2003 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 6 08-17-2010 02:06 PM
Long Problem(s) GM techs or someone needed here... xpanda305x Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 37 07-04-2010 03:00 PM
M6 CLUTCH/TRANS PROBLEMS summitss/rsls3 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 05-22-2010 12:48 PM
