Emblempros
Old 09-13-2010, 02:59 PM   #1
Merc
In The Circle
Merc's Avatar
TCI Line Lock
Has anybody installed a TCI line lock?
Old 09-13-2010, 04:26 PM   #2
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
+1 lookin to put one in and would like info as well.
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 09-13-2010, 04:33 PM   #3
Merc
In The Circle
Merc's Avatar
There is an issue with there line lock, that I am trying to resolve. I would not buy a TCI line lock right now. Once the issue is resolved I will post again.
Old 09-13-2010, 06:06 PM   #4
Merc
In The Circle
Merc's Avatar
Made several calls to TCI today trying to resolve the brake line fitting issue. No sucess I am blown off for another day. Buyer beware of TCI.
Old 09-13-2010, 07:29 PM   #5
Z Madness
Z Madness's Avatar
Drives: 2010, 2000, 1971 Camaros
What problems did you have? I purchased a set from Spohn Performance which where the TCI and mine seems to be fine. Just curious to see what you issues were/are.
Z Madness is offline   Reply With Quote
Old 09-13-2010, 08:04 PM   #6
Merc
In The Circle
Merc's Avatar
Heres the problem. The brass fitting is not tapped deep enough to get the stock brake line to seal. So what happens is the stock flair nut bottoms out in the brass fitting before the double flair seats. Creates a massive brake fluid leak. We have searched high and low for a re-placement brass fitting, no luck. We tried finding a flair nut for the purpose of making a tap to fix the brass fitting. No luck. I made several calls to TCI tech line today. All I am asking for is a spare brass fitting and a flair nut to make a tap. I have been jerked around all day. I am being told they have to wait til some dude comes out of a meeting to OK them sending me $2 worth of parts. Another option would be to us a dremel with a cut off wheel and shorten the stock flair nut. Very delicate work and I refuse to do that to the stock brake line, to make there junk work. Not to mention were doing jack shit stuff on a braking system of a very fast car.
IT'S TOTAL GARBAGE!
Old 09-13-2010, 08:24 PM   #7
Z Madness
Z Madness's Avatar
I feel your frustration. Mine went on fine, though I do have a V-6. I believe the kits are the same for both but I have not had any issues. Maybe they sent you the incorrect nut. Needing an ok to get a $2 part sucks. I went through Spohn and not TCI but didn't have any issues for them to resolve. I used Spohn parts on my 4th gen is why I went with them for the line lock. I saw another line lock on another car that tapped in near the ABS system as opposed to TCI which is right at the master cyclinder. Hope you get this fixed.
Old 09-13-2010, 08:26 PM   #8
Z Madness
Z Madness's Avatar
Oh, forgot to mention. I switched from the tap they included to an inline fuse. Much better connection.
Old 09-13-2010, 08:29 PM   #9
Merc
In The Circle
Merc's Avatar
I went with TCI because it tapped into the master cylinder and was kind of hidden out of the way. I have lots of custom parts and paint under the hood and did not want the selinoid sticking out like a sore thumb.
Old 09-13-2010, 08:31 PM   #10
Z Madness
Z Madness's Avatar
Yes, I liked the location of the install. Hope they get you the correct fittings FOR FREE! Good luck to you.
Old 09-13-2010, 08:33 PM   #11
Merc
In The Circle
Merc's Avatar
My system is powered from the the hot post under the hood and I have a weather pack connection hidden under dash for the activation switch which is attached temporarly to the e-brake handle. The reason for that is, I remove it after Friday Night Street Legals.
Old 09-14-2010, 12:44 PM   #12
Merc
In The Circle
Merc's Avatar
TCI has agreed to send me a couple more brass fitting, hopefully that will work. Failing that they are sending a couple of flare nuts for the purpose of making a tap to run the threads deeper into the brass fitting.
DIY Brake Calipers Rotors and Line Removal Gotthat02fire Camaro DIY & HOW-TO instructions & discussions 31 02-14-2012 07:52 PM
2nd Gen. Line Lock Kit carsismeZ06 1st & 2nd Generation Camaros 2 05-29-2010 12:58 PM
2010 Camaro Line Lock Kit? Windy City Wheels and Tires Talk Sponsored by The Tire Rack 15 11-09-2009 11:05 PM
# of Cars on Line...? carguy 5th Gen Camaro SS LS LT General Discussions 6 06-09-2009 12:32 PM
