Old 09-13-2010, 03:39 PM   #1
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
Thumbs down Oil Leakage!
So I was under the Camaro today changing the oil and I noticed the entire oil pan and bell housing is covered in oil.
Guess I need to make an appointment now.
Is there a TSB on this or has anyone else had this issue?
franknbeans is offline   Reply With Quote
Old 09-13-2010, 03:49 PM   #2
kaler
kaler's Avatar
Drives: 2011 Dodge 3500 dually Mega Cab
The LS motor is notorious for rear main seal leaks.I have a small leak myself I am going to take advantage of it and have my dealer put a 2800 rpm converter in while the transmission is out.
kaler is offline   Reply With Quote
Old 09-13-2010, 03:57 PM   #3
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
I just had an oil cooler gasket replaced this past weekend for the same thing ...
Old 09-13-2010, 04:09 PM   #4
franknbeans
Whipped
Drives: 2010 CAMARO
ok, at least I'm not the only one then. LOL
Old 09-13-2010, 05:08 PM   #5
BalogUK
THE architect.
Drives: 2SS/RS M6
similar...had cleaned off the bottom of the pan (it was an absolute mess)
#34122 EMPTIED, AT YARD ON 8/26/09; Delivered 9/07/09
MODS: Borla ATAK Cat-Back GFX (#140378), 35% Ceramic all-around, CAI, Inc. Intake w/ Scoop, Hurst Short Throw, Heritage Grille, GM Dove Tail, Laser Interceptor Triple v8.9, Passport Max, Pfadt ZL Stage 2
BalogUK is offline   Reply With Quote
Old 09-13-2010, 05:14 PM   #6
franknbeans
Whipped
Drives: 2010 CAMARO
yup... looked JUST like that.
Old 09-13-2010, 05:29 PM   #7
BalogUK
THE architect.
Drives: 2SS/RS M6
NO TSB for it yet- Its not the rear case seal/porosity issue. (it could still be porosity or just as simple as a bad gasket)
Dealer is waiting for more info from GM for action on mine (last week) requires dropping trans, removing sub frame et al. to replace the pan gasket- he'd rather not pull it apart until he knows what the resolution is... (to avoid multiple fixes/dis-assemblies)
20,000 miles Vin 34122
Old 09-13-2010, 06:46 PM   #8
franknbeans
Whipped
Drives: 2010 CAMARO
dude, could you keep me posted on this. . . Once your dealer finds out the issue I'll have something to go off of.
Don't want to walk blind into my dealership.
Old 09-13-2010, 06:55 PM   #9
BalogUK
THE architect.
Drives: 2SS/RS M6
yea sure will- is yours dripping oil or just seeping? my garage floor is clean, so whatever it is, happens while it's circulating
whats your VIN ending & AT6 or MT6
Old 09-13-2010, 10:20 PM   #10
franknbeans
Whipped
Drives: 2010 CAMARO
Mine is just seeping. . . haven't noticed any drips, but I'll be watching it a lot closer now.
It's a M6 #16235
Old 09-13-2010, 10:27 PM   #11
James4086
James4086's Avatar
Drives: Black 2017 ZL1
ok, I'm parked on a slight incline, nose down (we're talking like 5-10 degrees) and the last time I got in my 2ss the check engine light came on. After I made it to my destination, about 2 hours later I get in to come home for the night and now the info screen says I need to add oil! YIKES!! but after checking the dipstick, it doesn't look low.
Anyway I added about 1/4-1/3 of a quart of Mobile 1 synth to her and low and behold, happy as can be. Now the "add oil" message comes on every now and then, but then goes away the next time I start the engine, and there's no check engine light...
after hearing these stories, however, a dealership checkup just got bumped to top of the list anyway.
CAUTION: side effects of driving a Camaro include grinimus permintallis otherwise known as "Permagrin" and random, uncontrollable outbursts of "I love this car!!"
James4086 is offline   Reply With Quote
Old 09-13-2010, 10:30 PM   #12
IROCanSS
Drives: 89 IROC 350
Hmmm... I will have to look at mine next time I change the oil. I can't reacall seeing anything but come to think of it I may have been down a little on oil last time I changed it. No drips though, floor is clean. I would likely take the "do nothing" approach it it is as minor as shown in the pics and isnt dripping.
Old 09-13-2010, 10:31 PM   #13
IROCanSS
Drives: 89 IROC 350
Never had the "add oil" light...
Old 09-13-2010, 10:43 PM   #14
Tomato
G-Force Addict
Tomato's Avatar
Drives: 2010 SS/RS A6
Same issue here - seeping, but no drips. The idiot dealer put dye in it and rechecked a month later..."We can't find any leaks." Changed the oil a couple of weeks ago and still seeping. Well, I checked the oil pans bolts, and THEY WERE ALL LOOSE!
Spec is 15 (or 18, I forget now) pound feet - they were all at about half that. The stupid service techs didn't even check this. ???
I need to get back under and see if that did the trick.
Tomato is offline   Reply With Quote
My V6 oil change experience convert Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 38 04-08-2014 04:15 PM
GM's OLM & synthetic oils. duder4thgen Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 03-24-2010 11:37 AM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 12:20 PM
