| Transmission / Driveline Shifters, differentials, gears, rearends, clutch |
Thread Tools |
INTHECLOUDS
Drives: 2010 2SS/RS Join Date: Aug 2009
Richmond 4.10's Incinerated!
4k on the gears, professionally installed, stock tires, in 100 pieces! Are you kidding me? Working with the seller now, hopefully I don't have to wait 2 months for my refund from Richmond.
2010 IOM 2SS/RS A6, Tuned by Me, ARH/NoCats, Borla Touring, Vararam CAI, G-Force 9" with 3.89's, Circle D 4500K, (Skinnies/Slicks, and Bogarts all around
24MPG ![]() 11.8 @ 115 1000 DA ![]() www.6l80tuning.com www.6l90tuning.com |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro Join Date: Feb 2010
WTF! Making me glad I never did this but sorry for you. Hopefully they'll make it right.
9.80 @ 139.73, 1.45 60', 2010 Jannetty Racing L99
Whipped
this is such a common thread anymore it is ridiculous.
I was going to grab a set but there is no way in hell I would anymore. . . who would think Richmond and shit would be in the same sentence.
Magnaflow Cat back / ROTO-FAB Intake / Whipple Kit / RDP Tune.
580hp - 650Tq |
![]() Drives: v6 manual n shit' Join Date: Sep 2010
wow, crazy....how much power were you running?
Whipped
there's guys on the board that destroyed their 410's on a stock motor.
580hp - 650Tq |
#6 |
I.AM.
Drives: 2010 2SS/RS/M6 Join Date: Oct 2008
what break-in procedure did you follow? was there ever any whine? any wheel hop? what were you doing when they blew?
Not trying to place any blame on you, just getting some facts because I have the gears too.
2010 R6P-2SS/RS/LS3 - IBM w/ silver rally stripes / UNDER CONSTRUCTION.
NY5thgen.com ![]() |
#7 |
INTHECLOUDS
Stock motor with CAI and tune. During the 1-2 shift they exploded. They were professionally installed and lubed to Richmond standards. No wine whatsoever and they were broke in correctly.
#8 |
INTHECLOUDS
I put it through the heat cycles recommended by the installer and a few guys on the forum. Light driving for 15 min four times with cooling in between. These are performance gears and should handle my power level with no problem. I was skeptical when I saw the sheer size difference in the gears. The stockers are way beefier. If I stay with an aftermarket gear, it will be no steeper than the 3.73. They seem to be comparable in size to the stockers.
#9 |
![]() ![]() ![]() ![]() ![]() Drives: 2010 LPE 650+ CTS-V Join Date: Oct 2008
If you look at 3.70's, you may want to look at the LPE gears. They are made by the original equipment gear supplier and made to OE specs. I had mine micropolished also. I had them set up by RPM Transmission. I like them alot!!
'10 CTS-V : LPE 650+ Package 587hp / 582tq
2.55 Upper / 8.6 Lower / ID850's / Kooks Longtubes / New Era CAI |
#10 |
![]() ![]() ![]() ![]() ![]() Drives: 550+RWHP 2010 camaro Join Date: Sep 2007
un-real,, hopefully all goes well with the refund,, too many failures of these gears, has to be a manufacturing problem
#11 |
Whipped
do a thread search guys. . this has happened MANY times already.
580hp - 650Tq |
#12 |
Syntax Error
I'm about 4K on mine since install, so far no problems. Everytime I hear about a failure, I cringe and wonder when mine will go :(
I've been running with almost two qts of RP in the rear end, Pfadt's diff bushings and Spohn rear trailing arms and sway bar. Hopefully that is helping to keep things together. |
#13 |
Man, I was seriously considering the 4.33's from Richmond, but after hearing this story....AGAIN and AGAIN....I think I'll wait until a different manufacturer comes out with some better gears. I'm not going to have anything installed in my car that I don't have total confidence in. Sorry this had to happen to you, but thank you for posting and letting the rest of us know....
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2001 Camaro SS Join Date: Dec 2009
We are no longer doing the gears due to just this. Every one has broken when doing hard launches. Not worth the hassel.
#15 |
BAMF SS
I think I'm starting to get paranoid about my 4.10's..... but so far... 15,000 miles, lots of spirited driving. mods in sig
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over." |
#16 |
We have only broken them at the drag strip, not on the street.
#17 |
![]() Drives: SIM 2SS/RS '11 Jag XF Supercharged Join Date: Jun 2009
Why do new gears require a "break-in" but the OEM gears do not? Thanks
~Say When
Airaid CAI, JBA Shorties, JBA Axle Back, MGW Shifter |
#18 | |
I.AM.
NY5thgen.com ![]() Last edited by POWERFREAK; 09-14-2010 at 11:55 AM. |
#19 |
No doubt...I'm just interested in the science behind why it would be required.
~Say When
#20 |
I have no life
Drives: 06' Subaru STI, ex-Camaro V6 LLT Join Date: Apr 2010
Break in is mostly all about engine... not really about gears lol =D
#21 |
INTHECLOUDS
Putting any metal through multiple cycles of heat then cooling increases tensile strength. It's just like make making a sword in the old days. Swords were made to shatter not bend. The metal is changed at a molecular level when the correct process is applied. Maybe the stockers are treated before they leave the manufacturer.
#22 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 RY 2SS with Custom Stripes Join Date: Mar 2009
I have been debatting putting 4.10 gears for about 2 months. I am glad I didn't step up and do them yet. I will have to see some better results from Richmond before I install their product. Does anyone know if LPE or another company has 4.10's? Anyone else make 4.10's?
-Custom Stripes, Eibach Drop Springs -MagnaFlow 3" Catback with X pipe -ADM CAI-Street Version, SLP 160 T-Stat -Ragin Racin Custom Tune -Kooks LT Coated Headers, Heritage Grille -Barton Short Throw Shifter -Slotted & Dimpled Rotors -Powercoated Calipers by Mike -Hawk Ceramic Pads -Painted Roof -Painted Gills & Back Panel -3-M Clear Bra, AAC Plasma DRL's 404rwhp and 403tq |
#23 |
INTHECLOUDS
I was getting 25mpg with my 4.10s and my tranny tune. I have been able to FULLY lock the converter in DOD mode.
#24 |
![]() Drives: 2010 Camaro rs/ss inferno orange Join Date: Mar 2010
If you follow the break-in for a new car, the rear gears get broken-in easy. But, if you don't break-in new gears, a lot of people will just hammer the gears first time out.
HOT ROD SS MTH35115 |
#25 | |
I.AM.
| Thread Tools | |
| Richmond 4.33 Rear End Gears Available At Apex Motorsports!!! | Apex Chase | Transmission / Driveline | 84 | 05-13-2011 02:26 PM |
| Just "tested" my Richmond 4.10's | GrinderSS | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 5 | 07-15-2010 08:36 PM |
| 4.10/3.73 Richmond Gears and Install Kits Now available at New Era!!! | SMGSS | Transmission / Driveline | 6 | 07-08-2010 11:34 AM |
| Richmond Rear End Gears - 3.73 & 4.10 | Sean@Phastek | Transmission / Driveline | 0 | 06-02-2010 10:47 AM |
| NEW PRODUCT: 2010 Camaro Richmond Gears - 3.73 and 4.10 Ratios | tbyrne | Transmission / Driveline | 9 | 01-11-2010 10:36 AM |
