Old 09-13-2010, 08:28 PM   #1
gmag21
gmag21
gmag21's Avatar
Drives: 2010 Camaro 1SS/RS
Send a message via AIM to gmag21 Send a message via Skype™ to gmag21
Pfadt Suspension - Weird Sounds??
I recently installed the Pfadt lowering springs and sway bars with end links on my 2010 camaro ss. When I drive my car I am hearing this sound that is difficult to describe..
The sound usually only occurs when I am driving slowly or going over a fairly bumpy road. The sound is not loud but it is definitely noticeable.. It is almost like the sound of horse hooves but on a softer level. It's like a crunchy/bumpy sort of sound that sounds like something is being shaken or moved around. Is this normal? Has anyone experienced anything this
Thanks,
Grant
L99 | Billyboat Exhaust, American Racing Headers, Pfadt Springs and Sways, Tune | 350 whp / 371 tq
gmag21 is offline   Reply With Quote
Old 09-13-2010, 08:40 PM   #2
TCao
Drives: 2010 2SS RS, 2007 FJC
Not normal. Most likely cause of the soft thunking or popping noises is the endlinks are not tightened. Also double check the orientation of the rear endlinks. More info here:
http://www.camaro5.com/forums/showthread.php?t=101864
TCao is offline   Reply With Quote
Old 09-13-2010, 09:03 PM   #3
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Yep, TCao is correct. Check that thread out. We must stress that torque values are important. Be sure to do endlinks at 33lb/ft. and sway bar bushings at 22lb/ft. and check orientation as noted in the thread above.
Give us a call if you have any more questions!
Old 09-13-2010, 09:46 PM   #4
Robbie1227
Robbie1227's Avatar
Drives: 2015 Camaro Z28/2016 Jeep Sahara
Crap, I have some weird sounds as well.
I brought it back to the car care center and had them check that very thing was ok, and tight. They kept it for the day, and told me it was ok, they even re tweaked the alignment after I drove it for 2 weeks.
It sounds like a clunking sound, I don't like it.
I will have to question them on the end links. I am no mechanic, but is it something I can see for myself?
Robbie1227 is offline   Reply With Quote
Old 09-13-2010, 11:54 PM   #5
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
My end links were loose too...much better after hitting it with an impact...
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 09-14-2010, 08:51 AM   #6
Berean
Drives: Truck
I had a loose end link nut.
Berean is offline   Reply With Quote
My SS Camaro's tranny sounds weird in 1st and 2nd gear. RyanSSaddict V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 03-07-2011 02:08 PM
New Camaro video features dyno tuning and Pfadt lowered suspension PfadtRacing Suspension / Brakes / Chassis 0 01-15-2010 04:07 PM
New Camaro video features dyno tuning and Pfadt lowered suspension PfadtRacing 5th Gen Camaro SS LS LT General Discussions 0 01-15-2010 03:52 PM
Pfadt Springs and Sway Bars In Stock! *Package Deal*! PfadtRacing Suspension / Chassis / Brakes 0 10-14-2009 05:41 PM
