Cold Air Inductions
Old 09-15-2010, 09:07 PM   #1
victoryred1ss
victoryred1ss's Avatar
Drives: 2010 SS M6 2016 2SS A8
MSD BAP question
Does the vaccum port have to be plugged in and if so what part of the intake did you use for a vaccum source?
TVS 2300 721RWHP 686RWTQ
Built by Me
Suspension done by JDP
Tune done by JRE
victoryred1ss is offline   Reply With Quote
Old 10-18-2010, 02:55 PM   #2
quinthawk
Drives: 2010 camaro ss
Anybody have an answer to this question?
quinthawk is offline   Reply With Quote
Old 10-18-2010, 03:43 PM   #3
IPS Brandon
IPS Brandon's Avatar
Drives: 2010 Camaro SS black
Send a message via AIM to IPS Brandon
Yes the vacuumm port will need to pluged in, which means you need to route a line from the BAP to the back of the magnachager.
If you stand in the front of your Camaro, on the left side of the magnacharger, at the very back of the blower, where the end of the fuel rail is, there is a small vacumm nipple located just in front of the MAP sensor. Use this nipple as your vacumm source for the BAP.
By the rear drive pulley for the nipple location. The tricky part will be routing a vac. line under the car.
Regards
IPS Brandon is offline   Reply With Quote
Old 10-26-2010, 12:22 PM   #4
quinthawk
Is a 1/8 vacum line big enough given the distance to the trunk
Old 10-26-2010, 01:23 PM   #5
bigsquirrel
My car runs on acorns....
bigsquirrel's Avatar
Drives: 2010 SS RS Inferno Orange
If you need it the whipple install kit comes with instructions onhow to route it under the car. I can e-mail you a copy if you PM me. It's to big to post on the forum.
bigsquirrel is offline   Reply With Quote
Old 10-26-2010, 01:27 PM   #6
Jessika
Drives: Anything Blown
Here is the best picture I can find at the moment. Shot from the rear of the blower. I will upload a better picture as soon as I find one.
The boost gauge port is the same for the BAP, if both are being added you would just add a 'T'.
The red circle in this link is a clearer picture of the barb
http://www.flickr.com/photos/magnach...n/photostream/
Jessika is offline   Reply With Quote
Old 10-26-2010, 09:04 PM   #7
victoryred1ss
I ended up installing a T fitting at the brake booster to intake hose as per Ted Jannetty's recommendation. I seems to be working well
Built by Me
Tune done by JRE
Factory wire shields on MSD wires? FFPM73 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 09-15-2010 09:24 AM
MSD coils question Kwik Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 08-23-2010 09:14 PM
Question about tire sizes Jram1588 Wheels and Tires Talk Sponsored by The Tire Rack 9 07-17-2010 08:27 AM
Custom wheel offset question ... Bowtie Junkman Wheels and Tires Talk Sponsored by The Tire Rack 4 04-23-2010 06:16 PM
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 07:53 AM
