Old 09-16-2010, 07:52 PM   #1
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
V6 Major Motor Problems
9,900 miles and this morning I started hearing a LOUD ticking noise coming from the engine bay. Brought it in and the mechanics dont know yet but they said it could be a major problem. It made the noise in every gear around 2k RPMs. It definitely was not the direct injection either. Hopefully its just a loose flywheel. Regardless I cant believe I already have what could be a major problem at such low mileage.
1 oil change, BONE stock car driven mostly on the highway. I got 2k off the initial purchase, I'm seriously considering trading it up as long as I dont take more than a 2k hit.
UPDATE:
My cars been in the shop since the 16th and all they've told me so far is that they know the noise is coming from the motor and that it is probably a major issue...
Had a nice talk just now with CamaroDriver as well who is having a similar issue and it seems like I'm headed towards the same track as he is.
DarkneSS is offline   Reply With Quote
Old 09-16-2010, 08:26 PM   #2
Caspers2SSRS
Caspers2SSRS
Caspers2SSRS's Avatar
Drives: Summit White 2010 2SS/RS Camaro
Man ole man............that bites. Upfitting into a V8 Gen5 and dump the manual option and all will Okay.
I'm not paranoid, they're following me !
Caspers2SSRS is offline   Reply With Quote
Old 09-16-2010, 08:29 PM   #3
winston2ss
YDLYLB
winston2ss's Avatar
Drives: Cgm 2ssrs
Sorry to hear that. Hope everything works out ok.
winston2ss is offline   Reply With Quote
Old 09-16-2010, 08:41 PM   #4
squat
Drives: 2011 Dodge Charger
There's a guy on the G8 forum that had a similar noise with his cadillac. He was on the G8 board because the caddy had the same LY7 engine as our G8s do. Your's has the same block and a different upper so some parts may be the same.
His issue was the timing belt had stretched out and wrecked some stuff (I don't recall exactly what). He is having to do a full rebuild on the engine to fix it.
2011 Dodge Charger
squat is offline   Reply With Quote
Old 09-16-2010, 08:42 PM   #5
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2014 1LE...Drove: 2012 ZL1
One issue is not enough to drop a car. Especially while you're still under full warranty. At least not imo...
Let them figure out what it is...they will....fix it. And off you go on your merry way.
I don't believe this V6 has a timing belt. It's a chain.
Old 09-16-2010, 08:46 PM   #6
OHIOSS
Russ
Drives: Yukon Denali, Charger, CamaroSS
Send a message via AIM to OHIOSS
Ever hear of a part failing? It's under warranty so it's not going to cost you anything, unless the dealer determines you beat the hell out of it.
If you lose faith that easy you should sell it. Do you think million dollar super cars don't have parts that fail?
Russ
OHIOSS is offline   Reply With Quote
Old 09-16-2010, 08:52 PM   #7
KILLER74Z28
MOD SQUAD
KILLER74Z28's Avatar
Drives: 2G1FT1EW9A9100666
Who cares about the Blue Oval crowd and their little Ponys? We're getting our Camaro back-and it'll be Supercharged!-MDAII
Team LS3
KILLER74Z28 is offline   Reply With Quote
Old 09-16-2010, 08:55 PM   #8
dealer should fix it, especially being a 6cyl., I'm sure your not beating the hell out of it.
Old 09-16-2010, 08:55 PM   #9
motorhead
Drives: POS MOPAR
That's true ,but it seems to be a recurring theme with the V-6. I know the traverse is having more than it's fair share of problems also with the same motor.
Old 09-16-2010, 09:09 PM   #10
Ronn
Ronn's Avatar
Drives: 2010 Camaro
Hope everything works out but that's def not a reason to drop a great car. Get it fixed for free then start thinking about things when the warranty runs out. You've only gotten one oil change so far? How many miles were on it when you first did it?
1SS / RS / M6 / IOM / Black rally stripes / Polished wheels
It's a high school prom, it's a Springsteen song, it's a ride in a Chevrolet...
Ronn is offline   Reply With Quote
Old 09-16-2010, 09:09 PM   #11
b4z
Drives: '06 Pontiac GTO M6, '09 V8 SRX RWD
Op, I've got as much experience with the 3.6L as any. '04 SRX and '07 SRX.
My '04 with 1200 miles started to make loud whirring wounds. Camshafts machined incorrectly. Replaced under warranty all was well.
My '07 had to having the timing chain replaced. Done under warranty and no further problems.
My guess is timing belt or could be as bad as another guy here that had scored bearings.
Funny thing about the 3.6L and the timing chain. When the engine came out Cadillac told us how much better it was than the 3.2L 54 degree motor and that since it had timing chains instead of belts there wouldn't be any extra maintenance every 60K miles. I guess it hasn't exactly worked out that way.
b4z is offline   Reply With Quote
Old 09-16-2010, 09:15 PM   #12
MEDISIN
MEDISIN's Avatar
Drives: 2011 CTS-V Sedan
9,900 miles and only one oil change!? Does that strike anyone else as odd? I mean I could understand if it was 30,000 miles to 39,900 miles with one oil change but during the first 10k, I would have expected more than one oil change
Anywho, hope it's nothing serious. Keep us posted.
2012 - Present: 2011 CTS-V Sedan, A6, Airaid and Tune by R.P.M. = 515 hp/487 lb-ft.
2009 - 2012: 2010 2SS RS IBM M6, MGW Shifter, BMR Trailing Arms/Tunnel Brace, Roto-Fab CAI, VMAX Ported TB, Kooks 6511-Complete (Headers, X-Pipe, Mufflers), dyno tuned by R.P.M. = 415 hp/412 lb-ft.
"Not giving a f*^k is truly the greatest luxury, and no luxury car gives fewer f*^k's than a CTS-V." - Matt Hardigree
MEDISIN is offline   Reply With Quote
Old 09-16-2010, 09:19 PM   #13
daphatgrant
June '10
daphatgrant's Avatar
Drives: '10 2SS/RS RJT
You have a problem that could be serious, you also could have a problem that's not serious at all so let's slow down on the "this is the end of the Camaro world!" until you get an actual cause for the issue.
RJT, 2SS/RS, M6, Black Int, Sunroof.
daphatgrant is offline   Reply With Quote
Old 09-16-2010, 09:24 PM   #14
Capthowdy
Capthowdy's Avatar
Drives: 2010 2SS RS IOM
Send a message via Yahoo to Capthowdy
KEEP THE FAITH...BROTHER!!!
THE "MENACE"
Capthowdy is offline   Reply With Quote
Gran Turismo 5... No Camaro? 5thGenOwner 5th Gen Camaro SS LS LT General Discussions 111 12-06-2011 10:06 AM
Chronicle of the Red Devil - a Lingenfeltered and Pedderized 2010 Camaro 600hp-lpe Member Car Journals 86 09-14-2011 06:17 AM
What's considered a Muscle Car? SyN General Automotive + Other Cars Discussion 125 09-25-2010 12:04 AM
Drying after a rain? KLow7777 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 7 02-17-2010 10:41 AM
