| Off-topic Discussions Discuss any off-topic subjects with other members. |
Thread Tools |
![]() ![]() ![]() ![]() ![]() Drives: ... Join Date: Oct 2008
Mirror fell off my windshield AGAIN!!!
Hey Guys,
I live close to Dallas and the heat has caused my mirrors to fall off on both my cars in the past. I was heading home from church on Sunday and went over a railroad track which is normally pretty smooth and it jolted the car a little too much and I will be darn if the mirror didn't fall of again. This is the second time I will be putting it back on. What is the best glue to put on it to make sure this NEVER happens again? Super Glue? I have tried the stuff you get at Auto Zone and also from the dealer but geez, I for the life of my have never had this problem before. |
#2 | ||||
The Jalopy Jedi
Drives: anything I can get my hands on Join Date: Sep 2006
clean the residual glue from the window and the mounting block with alcohol. ensure the entire area is completely clean. then you should be able to find some mirror adhesive that will hold up to the heat. apply it on as per the directions, you might even put tape on it to hold it firmly in place. id leave it to cure for at least 24 hrs with the tape holding it in place just to be safe, then reinstall the mirror.
#3 | |
Thanks. What kiind of tape should I use? |
Camaro Fanatic
gorilla glue is some pretty strong stuff...but takes practice, the stuff expands a bit when setting. but once cured that stuff will take part of the windshield off if you have to remove that rearview mirror...lol
Make sure there no residual glue before application. |
It takes practice??? I have already been doing that with other things. Do you mean it takes practice before I use it on the windshield? This may be the way I go because with the heat down here I don't want to spend anymore time messing with it than I already have. Right now it is cold and I need to clean out my garage so I can get it inside and warm enough to do the job. Does the windshield have to be at a certain temperture before installation?? BTW..........thanks for responding.
| Thread Tools | |
| Rear windshield cover | The_Beast_ | Cosmetics and Lighting Modification Discussions | 55 | 12-03-2008 11:06 AM |
| So some guy put his parking ticket on my friend's windshield. | nester7929 | Off-topic Discussions | 5 | 11-24-2008 02:22 AM |
| Bad paint job? Lose a windshield or roof. | Silverado | General Automotive + Other Cars Discussion | 4 | 08-25-2008 09:50 PM |
