| Camaro Issues / Problems | Warranty Discussions | TSB and Recalls Report, discuss and diagnose any issues and problems with your Camaro, including warranty discussions. |
| View Poll Results: Does Your 2010 SS/AUTO Hesitate When You Try To Accelerate After Coasting/Cruising? | |||
| Yes, mine hesitates too. |
37 | 56.06% |
| No, mine does not hesitate. |
29 | 43.94% |
| Voters: 66. You may not vote on this poll | |||
Thread Tools |
#1 | ||
So It'll Go Down Easy
Drives: Camaro SS/RS Join Date: Aug 2010
If You Do Not Drive A 2010 Camaro, Or If Your 2010 Camaro Is Not Equipped With A Stock L99 Engine, Then Please Do Not Vote In The Poll.
Does Your L99 (AFM) Hesitate To Shift From V4 Mode To V8 Mode When You Begin To Accelerate After Coasting? just trying to help a brotha out. http://www.camaro5.com/forums/showthread.php?t=106325 Quote:
thanks for the vote. i test drove a 2011 Camaro and it did not hesitate for me. it's like night and day when you compare it to my 2010.
![]() Drives: 79Z28 and 2010 2SS/RS Join Date: Jul 2010
I added 1 for ya....
I'm not totally useless..
Drives: 2010 SIM 2SS/RS A6 SC LPO Rallies Join Date: Sep 2009
I am no longer stock, but when it was it never hesitated. Never missed a beat....
Former Ford man
I can tell you exactly what the problem is. I had the same problem on my 05 mustang. The electronic throttle body is bad.
1100 - 8 Jun 09
reordered with new dealer - 31 Aug 09 2000 - 08 Sep 09 3300 - TPW 28 Sep 09 3400 - 28 Sep 09 3800 - VIN 2G1FT1EW9A9153318 5000 - 21 Oct 09 6000 - 22 Oct 09 |
#6 |
R.I.P. jesserayjames
must be something wrong with it, bring it back to the dealer, my L99 and has no hesitation at all from when it was stock until my mods.
#7 |
#8 | |
the true mechanical craftsmen are gone. we don't have people who recognize a problem when it's right in front of their faces anymore. we don't have people who know what's wrong just by describing a noise. i went down to the dealer TWICE because my power steering was noisy, and only on the second visit did they care to check the power steering fluid reservoir - it was low. guess what. the engine light doesn't come on when the power steering fluid is low. |
#9 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2LT/RS ABM Join Date: Sep 2009
Sorry, i dont have a v8 camaro but my 2010 camaro does this from day one it just hesitates so much and i brought it to my dealers attention and they said its normal and im like WTF no its not! if any of yall figure it out please let me know...I almost died one time. I was under a overpass and i was yeilding to the cars coming and i thought that if i gave my car gas it would go and guess what my car didnt respond and then after 2 seconds my rmps jumped and nothing happend and then the car that was coming at me slammed on the brakes i let off the gas and slammed it again, it then finally moved...
1100 Order accepted at dealer: 9/15/2009 - NPGV41. 2000 Order accepted by GM: 9/29/2009 3000 Accepted By Production Control: 9/30/2009 - TPW 10/26/09 3100 Sequenced:10/12/09 3300 Scheduled For Production:10/13/09 3400 Broadcast:10/22/09 3800 Produced:10/27/09 4000 Available To Ship:10/28/09 4200 Shipped:10/29/09 5000 Delivered To The Dealer:11/09/09 6000 Delivered To Customer:11/12/09 |
#10 | |
when i originally created this thread, i had a different kind of "hesitation" in mind. mine was more along the lines of having the engine "hesitate" to move from V4 Mode to V8 Mode. i feel it "flutter" like it is trying to accelerate in V4 Mode instead of V8 Mode like i'm understanding it should. and this is why is is so important that LS3 drivers do not chime in on this or vote on the thread. but for LS/LT AUTO owners, it may still be relevant. thanks for your input! i would appreciate it if everyone who votes "Yes" on the poll leaves a comment and describes their symptoms, and when & how exactly this "hesitation" exists. |
#11 | ||
#12 | |
![]() well down by the gear shift there is an auxiliary power jack (cigarette lighter style) and to the left of that, there is a button. tap that button once and Traction Control will be turned off, and you'll see a yellow light (TC) show up on your instrument panel. this will give you full power to your rear wheels without holding back to keep the tires from spinning. this is why i keep it on in bad weather or bad roads... but i'm not punching it all the time either. i just like the way it feels to have T/C off compared to T/C on. i don't think i've even brought my engine up to 6000 RPM's, and unless you're using Tap Shift - your engine RPM's shouldn't be going that high. i recommend taking your car down to the dealer, and driving it with a technician in the passenger seat. |
#13 | ||
#14 | |
#15 |
My 2010 2SS/RS A6 built 02/2010 does it bad! I have HPTuners and thinking about turning it off!
CamaroFest II and III
2010 White Camaro 2SS/RS A6 2002 Corvette Yellow Coupe 1sc,3.42 rear end,Z06 wheels,Pioneer AVIC D3,A4,Vortex Rammer intake,25% underdrive pulley,160°stat,Texas Speed cam 224/224 581/581 114 LSA,Texas Speed Headers high flow cats,Bassani X-pipe,Z06 Ti's,BlackMaxx tunnel plate,Z06 sway bars,Z06 shocks and HPTuners |
#16 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
I have not noticed any hesitation other than the time it takes to down shift when punching it. Curious to know does it happen when using tap shift or only when computer controlled shifting
#17 | |
yeah i completely understand the downshift time, but that's a different - less annoying issue that i figure there's nothing doable about. but the "hesitation" that i'm describing can be duplicated when i'm using Tap Shift as well. Tap Shift does not turn off AFM; it only allows you to drive at higher speeds in lower gears with higher RPM's - so not only are you not allowing AFM to kick in, but you're killing your MPG for the fact that you're not cruising in a higher gear when you could be. i could drive around town, "red-lining" it in 1st or 2nd gear and not get any "hesitation". i hope this answers your question. |
#18 |
Ollie
Drives: 02 Subrbn/94 Prizm/10 SSRS :) Join Date: Jul 2009
ditto mine too.!
Living the dream!
#19 | |
i regularly drive a GMC Sierra with AFM. i can hear the exhaust note change when AFM kicks in - it doesn't bother me and isn't very noticeable. i don't feel any "flutter" or "hesitation" to change from V4 Mode to V8 Mode. that change is instantaneous. |
#20 |
![]() Drives: 2010 CGM 1SS Camaro Join Date: Oct 2009
Did not vote because it only occurs here and there. Depends on my driving pattern before cruising speed it seems. ALmost as if the car gets "sleepy" at times if your not driving kinda hard at times. BUT drive that sucker like you stole it and ZOOOOOM!! She never wants to stop!
#21 |
i dont get any hesitation on mine when i accelerate.. only in sport mode after i step on the gas hard for just a second or 2 and then let up to allow the rpms to drop a little sometimes it doesnt drop down right away it just stays kinda high reving almost as if it is rev matching like when you downshift in manual mode
![]() 2010 Camaro 2SS/RS L99 (Sold) 2011 Camaro 2SS/RS LS3 M6 -Borla S-Type Catback | Solo High Flow Cats | ADM Race Intake | Factory Hurst Short Throw | Sequential Taillights | LS7 Blackout | Rear Camaro Letters | Skip Shift Eliminator | ZL1 Grill | Plasma DRLs | Anvil CF Spoiler | Forgestar F14s | ZL1 Sideskirts | Plasma Afterburners | QTP Cutouts | |
#22 | |
#23 |
the votes on the poll are at around 50/50 right now. though i know that there's at least one 2011 SS/Auto owner who voted "no". 2011's are not being considered in this poll.
#24 |
How U Doin?
Never had the issue with mine before I had the AFM tuned out.
#25 |
| Thread Tools | |
| G-Force Stg III 2010 Camaro SS L99!!! | Mike TexaSS | USA - Texas | 0 | 07-09-2010 10:44 AM |
| 2010 Camaro SS L99 Vs 2007 MUSTANG GT/CS | Jekyll-N-Hyde | Chevy Camaro vs... | 28 | 06-09-2010 06:44 PM |
| Over 230 Satisfied 2010 Camaro Customers! Paddock Chevrolet has 40 in stock NOW | camarojoe | Dealer Camaros for Sale | 2 | 05-24-2010 05:58 PM |
| G-FORCE Stg III 2010 L99 Camaro SS!!! | Mike TexaSS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 9 | 05-11-2010 06:51 PM |
