BeckyD @ James Martin Chevy
Old 09-18-2010, 11:38 AM   #1
camarossrs2150
camarossrs2150's Avatar
Drives: abm2ssrs
IMPORTANT coolant leak from oil cooler hose fitting please read
ive been smelling some coolant for a while now and this is what came up .
[SIGPIC]
camarossrs2150 is offline   Reply With Quote
Old 09-18-2010, 02:46 PM   #2
Hicompression
Rumbly Bumble Bee
Hicompression's Avatar
Drives: 2010 2SS Camaro
That would suck having to re-tap a hole in a brand new engine block because someone cross-threaded it at the factory!
2010 RALLY YELLOW 2SS 6M
-OBX Longtubes FTW!
Hicompression is offline   Reply With Quote
Old 11-15-2011, 02:15 PM   #3
TornadoSS
WICKDSS
TornadoSS's Avatar
Drives: 2011 1SS/RS IOM LS3
Mine was leaking also, Its a 2011 early build. Luckily got it in to dealership last week and repaired, without incident, under warranty even with all my mods. Service tech said it was just loose and teflon seal didn't look right. Re-sealed and no more problems.
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei
11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds.
TornadoSS is offline   Reply With Quote
Old 12-29-2011, 08:17 PM   #4
Awesome_SS
Jeff
Awesome_SS's Avatar
Drives: 2010 Camaro SS/RS
I have this leak now at 16K miles. Looks like someone at the factory got sloppy with the sealant...more of it on the outside than on the thread it looks.
Awesome_SS is offline   Reply With Quote
Old 12-31-2011, 06:27 PM   #5
BLACK10
BLACK10's Avatar
it just needs to be removed carefully and install some Teflon tape on it and re tighten. that's all that was needed to fix mine. i do recommend removing the line to be able to get to it. i used a long extension and came from the wheel area to remove it. its really just a cheap fine threaded fitting
Old 06-10-2015, 09:08 AM   #6
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
Mine is dripping too. Took into the dealership and they were unable to get it to seal. GM has authorized a new block, but I really don't want one with all my current mods. Hoping they can figure something out using RTV sealant or maybe a Time Sert.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, RX CC, GFX, Subs.
rberns is offline   Reply With Quote
Old 02-08-2018, 08:52 AM   #7
wakespeak
wakespeak's Avatar
Drives: 2013 2SS LS3/NPP
Also see:
http://www.camaro5.com/forums/showth...1#post10026951
NPP, 1LE track pack, ZL1/1LE shifter, Apex catch can, 1LE oil separator, Goodridge stainless steel brake lines,1LE strut tower brace. Wheels: 19x10 front and 19x11 rear w/1LE offsets. Pegasus Aluminum Rear Cradle Bushings. Z/28 upper control arm bushings.
wakespeak is offline   Reply With Quote
2010 Camaro V6 Oil and Oil Filter Change azamazonqueen Camaro DIY & HOW-TO instructions & discussions 116 03-19-2017 01:36 PM
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 08:51 AM
First oil change? Fogey Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 27 09-18-2010 06:50 AM
synthetic motor oil? bigd1276 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 71 01-29-2009 12:28 PM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 12:20 PM
