JUICEDMOTORSPORTS
Old 09-18-2010, 01:43 PM   #1
SS Drifter
Drives: 2010 2SS/RS L99
Exclamation A6 Stuck in Park
Here's a good one. While installing a stereo my '10 SS/RS I realized the shifter will not move from park unless there is power and the key is in the On position. I need to move the car a few feet and I'm a several hours away from being able to reinstall the console and power up the car.
Does any know how to disable or bypass this feature? There must be a solenoid somewhere in the shifter but, I don't want to blindly rip into it.
This could be a real PITA if you had a dead battery and needed to move the car.
SS Drifter is offline   Reply With Quote
Old 09-19-2010, 01:09 AM   #2
hot ss
hot ss's Avatar
Drives: aqua 2ss l99
go underneath and unhook the trans linkage, and roll the car....then lock it all back up.
May your exhaust note, sing in harmony with your blower.
hot ss is offline   Reply With Quote
Old 09-19-2010, 03:00 PM   #3
jimmyj333
Drives: 2010 CAMARO 2SS/RS Aqua Blue L99
If you are really really skinny this might work
If you find a way to do this please post. Could see how this would be a PITA if battery died.
jimmyj333 is offline   Reply With Quote
Old 09-19-2010, 03:31 PM   #4
Toasty
Custom User Title :D
Toasty's Avatar
Drives: 2011 Summit White 2LT/RS
check the manual, there is a manual shift-lock release -- manual page 8-23.
Toasty is offline   Reply With Quote
Old 09-19-2010, 04:51 PM   #5
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
Apply the park brake.
Pull the passenger side console trim away from the front half of the console to expose the shifter mechanism.
Remove the retainer and the shift lock manual release cover.
Push and hold the manual release lever toward the rear of the vehicle.
Press the select button and move the transmission gear selector to the N (Neutral) position.
Release the lever.
After the vehicle has been moved, align the shift lock manual release cover plate and install the retainer so the automatic transmission can operate properly.
Place the console trim panel in the original position, aligning the fasteners on the trim panel with the slots in the console. Press in the side trim until it clicks in place.
The transmission selector locks if it is moved back to the P (Park) position.
Old 09-19-2010, 06:15 PM   #6
Oldrocker
Oldrocker's Avatar
Drives: 2010 SS2/RS Victory Red
Who would want to do that when you can come here and ask, wait a few hours or days, then find that the answer is in the owners manual?
Oldrocker is offline   Reply With Quote
Old 09-21-2010, 12:33 AM   #7
SS Drifter
camaro1 - Thanks for the help. I really didn't think this would be in the manual.
Oldrocker - It's Ok. Sometimes I'm a smart a$$ too.
Old 09-21-2010, 04:18 PM   #8
Oldrocker
Oldrocker's Avatar
Cool man! I was just funnin' with ya'!
Rear Park Assist Shuts Off Rupe24 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 9 10-08-2013 05:21 PM
New Jersey Motorsports Park Meet & Greet March 28th 2010 RobAGD USA - NY / NJ / PA 6 03-28-2010 04:39 PM
New Jersey Motorsports Park Meet & Greet March 28th 2010 RobAGD USA - Mid-Atlantic 0 03-17-2010 02:17 AM
Rear Park Assist? newagemuscle 5th Gen Camaro SS LS LT General Discussions 1 08-31-2009 08:50 PM
Guys! Be careful where you park! Even if you park right! The Dark Knight General Automotive + Other Cars Discussion 5 08-25-2009 04:39 PM
