BORLA
Old 09-18-2010, 05:15 PM   #1
Jose
Jose's Avatar
Drives: 2010 Camaro 2SS/RS White S/C
Oil catch can quantity???
Based on forum members experience, how much oil should the catch can have between every oil change? I just changed the oil in my car, the catch can has been installed only for 2 days, I decided to check it and it had at least 10 drops of oil, is this normal????
"It does not matter if you win or loose, what matters is if I win" Carl Fogarty
Jose is offline   Reply With Quote
Old 09-18-2010, 05:16 PM   #2
SC2150
Yes. If it is a good can you should catch oil within the first 100 miles or so. If you are catching a qt between changes then you have a deeper issue with the engine.
Old 09-18-2010, 05:24 PM   #3
Jose
Jose's Avatar
Thanks a lot!!! I will check it monthly, just to make sure that there is not a problem with my engine.
Oil Changes Dave McFly Off-topic Discussions 6 05-18-2010 05:50 PM
Can we use the catchcan made for the G8? HaZe_X Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 05-05-2010 11:35 AM
synthetic motor oil? bigd1276 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 71 01-29-2009 01:28 PM
