JUICEDMOTORSPORTS
Old 09-18-2010, 08:39 PM   #1
joes407
joes407's Avatar
Drives: 2014 ZL1m6 red hot #569
removing LS-3 resonators
i have the muffler delete but i want a bit more. how does removing the resonators affect the LS-3 as far as sound, performance and codes?
joes407 is offline   Reply With Quote
Old 09-18-2010, 09:02 PM   #2
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
Performance, you won't notice a difference.
Codes won't be thrown at all.
Sound, you will probably get a little more out of it and possibly more drone.
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 09-18-2010, 10:50 PM   #3
jimpfromwv
jimpfromwv's Avatar
Drives: 1968 camaro ss, 2010 camaro1ss
I am also interested in deleting my resonators but I'd like a little more info before doing so!
jimpfromwv is offline   Reply With Quote
Old 09-19-2010, 12:45 PM   #4
caverman
caverman's Avatar
Drives: '69 SS Convertible
Try doing the rear-cat delete. You'll pick up a little more sound and power....not a whole lot though...just a little. I was charged $125 to have mine done.
You could also put a Magnaflow Tru-X in place of the factory H-pipe and get rid of the resonators as the same time. That should make a some sound difference for you.
Build Journal
Old 09-19-2010, 02:00 PM   #5
Rage
TRI-COUNTY CAMARO... FTW!
Rage's Avatar
Drives: 2010 Camaro 2SS M6 Cyber Grey
You can delete the rear cats only? Does it throw a CEL code? What do you do with the O2 sensor once removed? Thanks!
CAI inc. cold air intake, LG G6x3 cam, Patriot Gold Extreme Dual springs, Titanium retainers and locks, LG SuperPro 1 7/8 Long Tube headers with full 3" exhaust, DynoMax VT mufflers, SLP 4" tips, Moroso catch can, Race Ready electronic exhaust cut outs, Full painted Razzi body kit, Headlight Armor Smoke taillight and marker blackouts, T-Rex aluminum upper and lower grille, Polished aluminum front and rear bowties. Professionally installed and Dyno Tuned by HorsePower Sales, Pompano Beach FL.
Rage is offline   Reply With Quote
Old 09-19-2010, 02:22 PM   #6
Smoky10
I'm curious about this as well.
Smoky10 is offline   Reply With Quote
Old 09-19-2010, 04:21 PM   #7
caverman
caverman's Avatar
Pretty much everything covered.
http://www.camaro5.com/forums/showth...ght=cat+delete
Build Journal
Old 09-20-2010, 09:09 PM   #8
joes407
joes407's Avatar
so after reading all the attached links and posts it appears i can lose the cat behind both bungs and the resonators and not get any cel's? does this make more decel pop or is it about the same as it is with just the mufflers gone?
Old 09-20-2010, 11:47 PM   #9
caverman
caverman's Avatar
I can't positively tell you because mine was done all at once but from my understanding nothing about your exhaust will actually increase the decel popping. It's there even with the factory exhaust. It's just that with the louder exhaust you are going to hear it more.
So, if you go with that principle you will probably hear it a little louder but not with any more frequency.
I'm not really crazy about the decel popping either and I learned out to drive around it. You either push in the clutch sooner or give it just a touch of gas to make it go away.
Since you are wanting more sound you might consider buying the Magnaflow Tru-X and put it in place of the factory H-pipe at the same time that you are removing the resonators. You'll already be welding pipe in place of the resonators so it probably wouldn't cost any difference to add the x-pipe. You can pick one up from JDP Motorsports for about $75. If you want to tone down the decel popping then use the resonated x-pipe.....but it won't be as loud as the Tru-X. Go through this thread:
http://www.camaro5.com/forums/showthread.php?t=64964
Build Journal
Old 09-21-2010, 10:23 AM   #10
joes407
joes407's Avatar
i had read that the factory H-pipe is fine performance wise but i wanted to free up some restrictions in the exhaust. like @ least 1 cat and maybe the resonators. maybe i should just wait the 6 months until im out of warranty and go with a complete headers back system and tune. whats the consensus on a tune with the factory exhaust in place? is it worth it or just a waste due to bad flow of factory exhaust?
Old 09-21-2010, 10:26 AM   #11
joes407
joes407's Avatar
i too drive around the decel pop so that i dont really care about so much. just looking for a little more umph with little outgoing cash as possible. trying to get the car paid down as much as possible in case i want to trade it for a Z-28. dont wanna put 5k in mods to trade the car in another year.
Old 09-21-2010, 11:55 AM   #12
caverman
caverman's Avatar
The performance gains on the x-pipe, or rear cat-delete, or resonators is going to be very minimal. Probably nothing you'll notice. Even if you got say 5rwhp out of all of it I don't know that you would really feel that.
What you might consider doing is spending about $2.5k - $3k to get headers, exhaust, and tune. You can actually go way cheaper than that if you are willing to go with some Pacesetter or maybe OBX headers and just put some mufflers back on.
If and when the time comes to buy the Z/28 then take off the headers and put the factory tune back. You'll probably have to eat the mufflers though because you'll have to have something there. You then sell your headers for 50%-60% of what you have in them.
Actually....come to think of it....your best bet for the money would be to put on some HF cat mid-pipes and then maybe use a handheld tuner. You can get the JBA HF mids for around $300 I believe. That will give you sound and performance. When you're done....take them off and try to recover some money.
Build Journal
2011 LS Black cloth interior photo request starbase Camaro Photos | Spyshots | Video | Media Gallery 13 03-06-2012 01:36 PM
Removing Swirl Marks using a Flex and Meguiars M105/M205 Angelo@Autopia Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 5 05-22-2010 11:36 PM
Another "noob" question: removing resonators Pumpkin1LT USA - Texas 7 05-13-2010 01:41 PM
Holley LS Fest, September 10-12, 2010 Pro Stock John USA - Great Lakes 1 01-28-2010 09:18 AM
Resonators and your aftermarket XPipe JoshJ81 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 07-30-2009 07:23 AM
