sjm autoprod
Old 09-18-2010, 10:30 PM   #1
gearhead440
gearhead440's Avatar
Drives: Yellow 2SS, 6 speed manual
Driveway Mods in the Quest for Power Meets The Dyno
The Royal Bee has finally met the dyno at Precision Dyno in Belmont, NC.
Topgun1 has also made a couple of threads about his dyno runs there as well
http://www.camaro5.com/forums/showthread.php?t=104211
Thomas is a very knowledgeable mechanic, tuner and dyno operator who takes the time to work with you and is an all around stand up guy .
Recap of Driveway Mods in the Quest for Power is located here:
http://www.camaro5.com/forums/showthread.php?t=96761
C.A.I cold air intake, ADM race scoop, TSP underdrive pulley, hand ported exhaust manifolds with high-temp coating, rear cat removed, front cat ported for 3 inch inlet pipe with header wrap, polished throttle body, Mobil 1 trans fluid, Royal Purple gear lube in rear, Rev Xtreme catch can, stock exhaust system from cats back including stock mufflers.
The dyno runs were performed Saturday morning with absolutely fabulous weather and even a slight chill in the air – a far cry from the 90F+ temps that arrived later on in the day. We did a couple of runs, let the car cool for a few minutes, followed by another couple of runs with the third run being the best. Check out this video on You Tube of Anna at the wheel of her car on the dyno:
Gallons of sweat and cases of beer behind these results :
SAE: 401.5 RWHP, 394 RWTQ
STD: 410 RWHP, 402.6 RWTQ
Hey, at least she lets me drive it from time to time!
Hers & His
gearhead440 is offline   Reply With Quote
Old 09-19-2010, 08:21 AM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Very nice!
Old 09-19-2010, 09:51 AM   #3
gearhead440
Thanks Chase! I could not have done it without your CAI !
Hers & His
Old 09-19-2010, 03:50 PM   #4
tp_preformance
Drives: 2006 gt500 super snake
i think i speek for all when i say wow i was suprised what the royal bee made i was VERY impressed with the work on the car and the power it made. and look forward to having yall back.. thank you for your business had a blast....
tp_preformance is offline   Reply With Quote
Old 09-20-2010, 07:30 AM   #5
gearhead440
TP,
Thanks! We had a fantastic time and are already scheming for further "improvements" in the near future!
Hers & His
Old 09-20-2010, 10:42 AM   #6
sspaul
sspaul's Avatar
Drives: 2010 ss camaro, imperial blue
Send a message via AIM to sspaul Send a message via Yahoo to sspaul
Originally Posted by gearhead440 View Post
TP,
what would those improvements be?
my youtube
my facebook
www.myspace.com/1djchampagne
www.twitter.com/1djchampagne
mods: borla long tube headers, borla atak catback, lingenfelter gt-9 cam, ported heads, ecs base kit running 11 psi on top end, 1" bmr drop spring, aam 3.70 gears, ported throttle body, 160* thermorstat, lethal racing tune
750/641 rwhp/rwtq
sspaul is offline   Reply With Quote
Old 09-20-2010, 10:49 AM   #7
topgun1
topgun1's Avatar
Drives: 10 SIM 2SS/RS LS3
excellent numbers for the Royal Bee!! unique and very effective mods with those kinds of gains looking forward to seeing the Bee come to life.
Good job TP!
5th Gen Camaros of the Carolinas SIM, 2SS/RS LS3 5/7/11 453.9 RWHP 427.5 RWTQ
VMS Stage 2.5 Comp Cams kit, Cold Air Inductions intake, ADM race scoop, DT 1 3/4" headers, Solo cats, 3" Magnaflow catback, Pypes cutouts, HP tune, H&R SuperSport springs, Eibach sways/spacers, TexasSpeed UD pulley, LSR tensioner pulley, Barton shifter, skip shift eliminator, powder-coated calipers, R1 concept rotors, StopTech pads, Granatelli wires, Lloyds mats, tint, AAC afterburner taillamps, AAC scanner/sidemarkers, SRP pedals, custom engine cover, black bowties, Ridergraphix hood spears....
topgun1 is offline   Reply With Quote
Old 09-20-2010, 11:43 AM   #8
gearhead440
Topgun1,
Thanks, man! You have raised the bar for me YET AGAIN with you cam swap! What do I have to do to catch you?
SSPaul,
Simple stuff this time around to improve the longevity of the engine, control valve train harmomics and free up a few additional horsepower.
This winter, I'll install Comp 918 valve springs, perform the Comp rocker arm upgrade to replace the needle bearings in the stock rocker arms (I'll have a shop press them since I don't own a shop press), and install Comp pushrods.
The springs will add additional harmonic stability throughout the rpm range and the stiffer pushrods will not "flex" as much as the stock ones, thereby adding another level of stability and removal of wasted motion. Replacing the needle bearings in the rockers is more for longevity and piece of mind since we plan to keep the car forever.
Hers & His
Roto-fab CAI dyno results Roto-fab 1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 102 07-30-2016 08:21 PM
Vararam CAI Testing on Dyno at England Green Racing (Pix, Vids, RESULTS!!!) TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 113 01-05-2011 04:32 PM
Camaro on the dyno today in Concord, NC! topgun1 Camaro Photos | Spyshots | Video | Media Gallery 6 03-19-2010 07:49 PM
Dyno numbers STOCK. Guess the HP after the Mods... Qwkss Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 08-26-2009 01:22 PM
SGOS's - L99 A6 Dyno results (after dyno tune) SGOS252382 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 48 07-27-2009 02:13 PM
