Emblempros
Old 09-19-2010, 02:05 PM   #1
moiy1983
moiy1983's Avatar
Drives: 2010 camaro ss/rs
how do u bleed the clutch?
i am upgrading my clucth very soon and i want to know if any know how to bleed the clutch. some pics would be nice and some good instructions. thanks guys!
moiy1983 is offline   Reply With Quote
Old 09-20-2010, 08:58 AM   #2
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
The bleeder should be near the transmission and should have a rubber cover over the end of it, like on you brake calipers. On the V6's AY6 its on the inside of the bell housing. You'll need someone to help you of course. Then just bleed it like you would your brakes.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
Old 09-20-2010, 01:30 PM   #3
moiy1983
moiy1983's Avatar
thanks!
Old 09-20-2010, 02:09 PM   #4
thekid96
Drives: Z06, 69 Camaro
Check this out, makes the job a little easier.
http://www.camaro5.com/forums/showthread.php?t=101008
thekid96 is offline   Reply With Quote
I want a new clutch, you too????? Sign here tjbusa V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 370 08-10-2013 04:27 AM
Bleed the clutch? jnm2003 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 5 06-09-2012 06:50 AM
How to bleed clutch? thekid96 Camaro DIY & HOW-TO instructions & discussions 4 04-16-2012 09:12 PM
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 11:40 PM
