B&M Racing
Old 09-19-2010, 05:17 PM   #1
ProudLS
ProudLS's Avatar
Drives: Camaro SS
Spec Clutch and Flywheel Installed - Gear Problem
I just installed a Spec clutch stage 2+ and aluminum flywheel with no issue but after the installation my gear can not shift to second, third and fifth while the car is on idle only first and reverse..!! but when the car is running and if its off I can shift any gear I want. It was not like this before the installation, is that normal ?!
Any help will be highly appreciated.
Thanks,
2010 Black/Black SS RS M6, ARH headers, Hi-flow cats w/x-pipe, Fastlane CAI, Livernois Camshaft 2C, SLP 160 Stat, SLP underdrive pulley, Hurst, Eibach lower spring, BMR lower control arms, BMR toe rods, Razzi body kit and Borla axle back. Tuned by me HPT.
ProudLS is offline   Reply With Quote
Old 09-19-2010, 10:04 PM   #2
Roger Ramjet
Motor Head
Roger Ramjet's Avatar
Drives: CTS-V
Sounds like you are not getting full slave cylinder travel.
History Camaro's: 83, 93, 95, 98, & 10.
Roger Ramjet is offline   Reply With Quote
Old 09-20-2010, 05:43 AM   #3
ProudLS
ProudLS's Avatar
Drives: Camaro SS
Everything is fine now, the solenoids cables ware connected by mistake to the wrong ports
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 10:17 PM
Spec, ACT, Fidanza, Clutchmasters @ Import Image!! ImportImage Transmission / Driveline 89 11-06-2011 10:05 PM
Unbeatble Prices on ACT / Fidanza / Hurst / Mishimoto / MTI / SLP / Spec / More maperformance Transmission / Driveline 18 10-26-2010 03:16 PM
Coming Soon! RAM Twin Disc Clutch and Flywheel! Taking Pre-Order List @BMC Peformance Kris@BMCPerformance V8 Bolt-Ons & Tunes 7 02-18-2010 08:00 PM
