Old 09-19-2010, 10:12 PM   #1
KB2010
Drives: 2010 Camaro SS
Anyones clutch get stuck w/o launch ctrl?
Hello all.
I made a post about this a couple days ago, just checked back today and it was deleted. Dont know if I violated a rule, or the thread started some sort of uprising while I wasn't looking. Anyway, I'll leave out the story this time, and just ask if it has happened to anyone.
Thanks
PS: If I did do something incorrect with this thread, please inform me Mighty Moderators....I like this forum and would prefer to stay
KB2010 is offline   Reply With Quote
Old 09-19-2010, 10:18 PM   #2
chopss
chopss's Avatar
Drives: 04 sentra, 2ss
happened to me a couple of times. took it to dealer with tranny moaning.
slave cyl (t/o bearing) finally failed on way to dealer and had to tow to dealer.
new slave cyl, t/o bearing.
never got stuck again but dealer said black fluid is normal lol. i use motive power bleeder every 10k miles.
clutch just doesnt feel right.
chopss is offline   Reply With Quote
Old 09-19-2010, 10:19 PM   #3
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
Originally Posted by KB2010 View Post
Hello all.
Thanks
Typical problem associated with dirty brake clutch fluid. The MN6 uses the same reservoir for both brakes and clutch. Many of us have gone to seperate systems that allow for easy fast and inexpensive replacement of clutch fluid. I used a 20 Ml clutch reservoir from a Yamaha crotch rocket. Made a quick bracket and mounted off the shock tower. total cost was 30 bucks. But to fix your sticking clutch pedal...use a syringe to remove fluid from your reservoir. Add new fluid. pump the clutch like 30 times and repeat process until debris is removed. That should fix your issue. Good luck.
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 09-19-2010, 10:21 PM   #4
2010 SS RS
2010 SS RS's Avatar
Black fluid is normal...omg they are nuts...
I change my clutch fluid every 4 or 5 runs. of course that is in my 20 ml seperate reservoir not the huge brake clutch shared reservoir. Still cant get over the black is normal quote...bahahahaah
Old 09-19-2010, 10:25 PM   #5
chopss
chopss's Avatar
question about the syringe, if you remove the brake fluid with this doesn't air get into the system? do you pump the clutch with the car on or off?
thanks
Old 09-19-2010, 10:34 PM   #6
chopss
chopss's Avatar
yea i know i showed the service advisor and he said the fluid turns black cause of all the driving and refused to change it when i got the new updated t/o. I was like what??? lol
i said can you change it i dont want the fluid like that. they where going to charge me so i did it myself.
my eyes crossed also when he said it was normal.
Old 09-19-2010, 10:46 PM   #7
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
thanks
No it dos not let air in, you are removing only the fluid in the reservoir so no air gets in, Why you need to pump the clutch 30 times and repeat process, Is so some of the old fluid will come to the top and in the reservoir, So you can remove more debris, If you do that before and after track days your clutch will not get stuck.
Old 09-19-2010, 10:56 PM   #8
chopss
chopss's Avatar
thx for the info.
just to get this straight remove dirty fluid from reservoir with syringe.
fill it with new fluid, Start car pump clutch 30 times repeat process to remove the dirty fluid?
Old 09-19-2010, 11:30 PM   #9
2SSRS@Gen5diy
But no need to start car.
Old 09-20-2010, 07:15 AM   #10
chopss
chopss's Avatar
Good times
Thanks.
Old 09-20-2010, 07:15 AM   #11
chopss
chopss's Avatar
Good times
Thanks.
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 10:17 PM
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 11:40 PM
Transmission output shaft hiller72 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 267 12-02-2009 09:39 PM
Clutch "Sticking" Issue - Not Clutch Dust - Not Boiling Fluid Embalmer Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 09-11-2009 10:52 AM
Burned my clutch a bit with Launch Control.... Caution you guys... Embalmer 5th Gen Camaro SS LS LT General Discussions 49 04-23-2009 09:49 PM
