Old 09-20-2010, 09:18 AM   #1
TLS Camaro
Drives: 2010 Camaro SS
3.73 Gearing ??
Hi folks. I am brand new to this forum, learned tons already. I just recently purchased a 2010 Camaro SS M6. I had a crate 427 naturally aspirated engine built for it that puts about 680 HP at engine...I think around 525-550 RWHP? ( Have to check dyno sheet to confirm ) Catback Corsa exhaust, cold air intake..
So my question ..and I know it has been beat to death is..what rear end gearing. I ordered a set of Richmond 3.73's, however upon reading numerous threads on here, everyone is going to the 4.10's
I am a casual driver ( city and hwy )and will be taking it to the track..
Are the people on here putting 4.10's int he stock cars? That I can see...but is 4.10 too much for my set uP Or am I wasting my time with the 3.73's?
Any info would be awesome...Im really torn here....
Thanks
T
TLS Camaro is offline   Reply With Quote
Old 09-20-2010, 12:18 PM   #2
Speed74SS
Speed74SS's Avatar
Drives: 2010 LPE 650+ CTS-V
I have the 3.70's and I like them - they feel alot better than the 3.45's. That's my personal opinion.
'10 CTS-V : LPE 650+ Package 587hp / 582tq
2.55 Upper / 8.6 Lower / ID850's / Kooks Longtubes / New Era CAI
Speed74SS is offline   Reply With Quote
Old 09-20-2010, 01:10 PM   #3
flyby
Drives: 2010 Silver SS
With that much power you do not need to change gears unless you plan to race it. Then it depends on what type of racing you plan to do. 373/0 would be good for all around racing. 410 would be overkill.
flyby is offline   Reply With Quote
Old 09-20-2010, 01:24 PM   #4
TLS Camaro
That is what I was thinking...4.10 would be overkill. I do need to make a change though..with the cam in that motor...it is always looking for some revs...and tends to chug and surge in lower RPM's.
Runs way too tall...dyno'd at 120 MPH in 3rd at about 6800RPM. DOnt think I could get it onto 3rd on the 1/4 mile barely...ha
Old 09-20-2010, 04:49 PM   #5
Roger Ramjet
Motor Head
Roger Ramjet's Avatar
Drives: CTS-V
My 4.10s are NOT too much gear on a stock motor. And, 4.10s would be even better on a camed motor.
However, you need to read about the Richmond 4.10 gear failures on this forum.
History Camaro's: 83, 93, 95, 98, & 10.
Roger Ramjet is offline   Reply With Quote
Old 09-20-2010, 05:47 PM   #6
TLS Camaro
Yeah, the failures are also what I am a little worried about...I may run the 373 to be on the safe side and I am sure it will be a great improvement from stock 345
Old 09-20-2010, 06:51 PM   #7
flyby
If you are unsure about your rear or gearing I would suggest upgrading to a 9 inch, you then can swap gears real easy. That is what I am doing.
Old 09-20-2010, 06:57 PM   #8
GQ4Life
Drives: 2010 Camaro SS LS3
Sounds like he want a streetcar that takes to track for fun. I think it depends what tires u will be running. With 525wHP & gears without slick u will spin a lot.
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Old 09-20-2010, 06:59 PM   #9
GQ4Life
Well 3.73 with drag radials prob be fine
Old 09-20-2010, 10:08 PM   #10
Roger Ramjet
Motor Head
Drives: CTS-V
The 3.73s are only a 7% RPM change from factory 3.45s - not much.
The 4.10s are a 16% RPM change - much better.
You may want to consider the new 4.30 gears that produce a 20% change. I have not heard of anyone having breakage with the 4.30s.
Old 09-21-2010, 09:18 AM   #11
TLS Camaro
Thats exactly it. I am not going to be hard core into racing it. Just take it to track to see what kind of times it will put down. Mainly street.
So I will be running the stock tires on it. The engine I have puts down alot of torque as is...just want to bring it to life somewhat with some gears and reduce the lugging and surging with the cam. Good suggestion on the 9 inch...maybe down the road...
Old 09-21-2010, 09:33 AM   #12
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
If you can wait until this coming spring, there will be some other manufacturers coming out with gears....including 4.10's. Just be patient...Daniel-san!!!
blazzin1 is offline   Reply With Quote
3.73 Gear? jo0oker V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 27 08-11-2014 12:16 PM
Any 1/4 mile times with l99 3.73 gear swap only? 73duster V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 3 08-05-2010 08:36 PM
5th gen vs 4th gen JCO2185 Chevy Camaro vs... 158 07-26-2010 09:16 AM
3.73 vs 4.10 gears sexystreetmachine V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 15 06-15-2010 10:09 PM
Rear end gear 3.73 - where to buy? rpepka V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 67 09-17-2009 06:23 PM
