BeckyD @ James Martin Chevy
Old 09-20-2010, 10:51 AM   #1
larryt1026
larryt1026's Avatar
Drives: 2011 Camaro LT
Thud Noise
Hi everyone!
So I've searched this whole forum for an answer to this mysterious thud noise that happens in the rear of the car (maybe trunk?) at times. It's usually when I come to a stop or if my shifts aren't smooth and causes my car to buck. The thud sound can be best described as a basketball hitting the back of my car. I've read on this forum that this could be normal, but I haven't found an answer that everyone seem to agree with.
Does anyone know where this noise is coming from and if I should be worried about it? It's driving me crazy . Thanks in advance everyone!
larryt1026 is offline   Reply With Quote
Old 09-20-2010, 11:01 AM   #2
ga0358
ga0358's Avatar
Drives: 2010 ABM LS
I notice a "thud" after I fill the tank-doesn't sound like a basketball hitting it though...
ga0358 is offline   Reply With Quote
Old 09-20-2010, 11:06 AM   #3
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
Have you had the dealer check it out?
The only things I can think of would be to look under your trunk mat in the wheel well and see if anything is rolling around in there. Also, have the dealer check to make sure everything is tightened properly under the car like the exhaust clamps, sway bar bolts, etc.
If you figure it out, let us know. Good luck!
Old 09-20-2010, 11:12 AM   #4
BeckyD@JamesMartinChevy
BeckyD@JamesMartinChevy's Avatar
Oh Larry, I'll do some checking on this end and see if anybody here
has heard anything like that. Does it do it all the time? or just occasionally? Someone here will know
Don't forget, I honor ALL DISCOUNTS THAT APPLY!
Available Inventory -James-Martin Chevrolet
BeckyD - I Deliver Nationwide!
..only 20 min from Detroit Metro Airport!
BeckyD@JamesMartinDetroit.com
ChevyFleet@aol.com
BeckyD@JamesMartinChevy is offline   Reply With Quote
Old 09-20-2010, 11:26 AM   #5
larryt1026
larryt1026's Avatar
Heh, thanks Becky! It happens once in a while I wouldn't say everytime. The thud usually happens when I brake. It does it most of the time when I'm reversing and hit the brakes to come to a stop.
Old 09-22-2010, 10:33 PM   #6
nalinc23
nalinc23's Avatar
Drives: 2010 2SS/RS 6MT
I get it too, usually when I make a not so perfect shift from 1-2, it's definitely transmission related is all I would say...
'10 2SS/RS 6MT, Silver Ice Metallic/Black, CAI Inc Intake, Magnaflow 3'' Catback Exhaust 16483, Llumar 35% Tint, Headlight Armor 20% for Fog/Side/Tail Light Lenses
nalinc23 is offline   Reply With Quote
Old 09-23-2010, 12:29 AM   #7
FuryKTH
FuryKTH's Avatar
Drives: 2011 Camaro LS
1160miles / 2011 Camaro LS
I have same thumping noise issue when I brake. Normally happens when just stopped as recoil or something. Sometimes I hear it, sometimes I don't.
I went to my dealer for the rear thumping noise last friday.
They said, they need to contact GM about it and will get back to me within this week.
But, i doubt it. :(
It sounds like as if the fuel hits fuel tank wall back and forth when I brake to stop.
Hopefully that is what it is.
FuryKTH is offline   Reply With Quote
Old 09-23-2010, 12:38 AM   #8
RichieRich
RichieRich's Avatar
Drives: 2010 Black Camaro 2SS/RS
I found the car manual to be a thud noise in the glove box when I turned
RichieRich is offline   Reply With Quote
Old 09-23-2010, 01:06 AM   #9
zach_powell_2000
Love it!
Drives: 2010 Imperial blue RS
But, i doubt it. :(
When i first heard this i thought i had a hanging tail pipe, but now I'm leaning toward fuel hitting the tank wall also.
zach_powell_2000 is offline   Reply With Quote
Old 09-23-2010, 10:32 PM   #10
boilermaker
Drives: 2011 Camaro RS/2SS Blk/Blk
Same issue here. 2011 Camaro M6 SS/RS <2000 miles. Happens when I come to a stop and sit in neutral.
boilermaker is offline   Reply With Quote
Old 09-26-2010, 03:31 PM   #11
JEFF2010SSMANUAL
JEFF2010SSMANUAL
JEFF2010SSMANUAL's Avatar
Drives: IOM 2SS/RS LS3
I have noticed that sound 3 or 4 times in the last week, its sounds like someone stomping in the trunk. Usually after a turn it off. I have 20k miles.
JEFF2010SSMANUAL is offline   Reply With Quote
Old 09-26-2010, 04:31 PM   #12
jagan323
I have no life
jagan323's Avatar
Drives: 06' Subaru STI, ex-Camaro V6 LLT
Uh, im pretty sure thats the engine downshifting... it happens to my car only when im driving in Manual tapshift mode in my Automatic.
When im in gear 2, and i hit the brakes, it shifts to gear 1 automatically, and the gear change is as described like you guys, harsh. If this is the same case, then you have nothing to worry about. it's normal =)
jagan323 is offline   Reply With Quote
GM is gonna kill me!!!! canadian ss 5th Gen Camaro SS LS LT General Discussions 37 08-09-2012 03:44 PM
Different noise from Dash (not the Heater Core noise) ColdCamaroSS Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 2 04-02-2010 10:49 AM
Got Pulled over... TRSS2 Cosmetics and Lighting Modification Discussions 39 03-08-2010 12:57 PM
Creaking Noise - Heads up ffrcobra_65 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 0 03-03-2010 03:54 PM
QC missed something-- AC Compressor making a whining noise under engine load Kyle.Gilmour Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 12 10-09-2009 11:42 PM
