JDP Motorsports
Old 09-21-2010, 09:40 PM   #1
ssmike
BliSSard has come!
ssmike's Avatar
Drives: '16 Camaro 2SS, '13 Equinox CRT
Changed to Mobil1 syn ATF, didn't help
So it was suggested by other members to change the trans fluid to Mobil1 syn ATF as a possible remedy to notchy shifting on the M6. So I tried it but after driving the car for a couple hundred miles I think it is worse now than before. Still got notchy shifting especially going into 3rd gear. I know this has worked for some but not for me. Just letting everyone know that changing to Mob1 may not help. I may go back to GM fluid.
Old 09-21-2010, 09:43 PM   #2
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
Was it notchy before your Hurst install? I know there are a few who have put in the Hurst and have not liked the way it shifted.
Old 09-21-2010, 10:42 PM   #3
thekid96
Drives: Z06, 69 Camaro
My trans was notchy going into 3rd as well, almost since new. I tried two different fluids including Mobil1 and neither helped. I finally had the trans torn down to add some hp parts and my builder found it to be quite a bit out of spec. Needless to say it shifts like butter since being re-assembled within spec.
thekid96 is offline   Reply With Quote
Old 09-22-2010, 06:01 AM   #4
ssmike
BliSSard has come!
ssmike's Avatar
It was notchy even before the Hurst. The dealer said nothings wrong and let them know if it gets worse. 2nd time in they still said nothing wrong. Thats when I installed the Hurst hoping for improvement but same thing, only maybe a little worse with the shorter throws. I decided to try the Mobil1 but still same thing. Should I replace the fluid with stock GM and take it back in to the dealer? I know they'll say "it's the aftermarket shifter".
Old 09-22-2010, 10:04 AM   #5
larryt1026
larryt1026's Avatar
Drives: 2011 Camaro LT
Bump. This is a topic I'd like to know the answer to as well.
larryt1026 is offline   Reply With Quote
Old 09-22-2010, 10:10 AM   #6
BackinBlackSS/RS
Go Blue!!!!!
Well, they should have on record that you have brought this in before for the same thing with the stock setup. Seems your syncros are out of wack. See if they will adjust them under warranty.
Old 09-22-2010, 10:11 AM   #7
SC2150
OK, GM won't agree, but drain the fluid and replace with a straight 30w motor oil with 5-6 oz's of Lucas oil treatment.
Try this and post back. I think you will be surprised.
Old 09-22-2010, 12:19 PM   #8
camarorick
camarorick's Avatar
Drives: .
If someone has the "grapefruits" to try this, and report some good findings, you'll be my hero
I've been to the dealer twice with this, and have heard the same thing.... " That's normal for this transmission "
camarorick is offline   Reply With Quote
Old 09-22-2010, 01:03 PM   #9
thekid96
I strongly believe the issue is tolerance related and changing fluids is a band-aid fix. Unfortunately pulling and disassembling the tranny is a large job and GM isn't going to do it unless they see a catastrophic failure. Same as the clutch sticking issues.
Old 09-22-2010, 04:12 PM   #10
ssmike
BliSSard has come!
ssmike's Avatar
Well I'll bring it in 1 more time and insist they take a closer look! I wonder if I should replace the fluid with stock GM before bringing it in.
Old 09-22-2010, 04:20 PM   #11
BackinBlackSS/RS
Go Blue!!!!!
Better safe then sorry.
Old 09-22-2010, 05:01 PM   #12
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
and they won't acknowledge that either ...
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 09-22-2010, 05:42 PM   #13
thekid96
My point exactly. When you take your car in to have the service dept look at a shifting issue or a sticking clutch pedal do you think they pull the tranny to inspect hard parts? Not a chance in hell. At best they change the fluid, bleed the clutch, take it for a test drive and tell you everything is fine.
Anyone in Tulsa want a FREE bottle of Mobil1 75W-90 Gear Lube? RedJewel2SS USA - Southcentral 1 11-12-2010 01:56 PM
Did Amsoil change their ATF Dex III? What is the best for the TR6060 now? Russell James Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 11 01-29-2010 07:00 PM
What all needs to be changed? mike25 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 2 12-08-2009 01:40 PM
Cheap Mobil1 XP Bell040 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 22 09-22-2009 01:27 AM
Order Changed dieseldave24v 5th Gen Camaro SS LS LT General Discussions 11 12-25-2008 08:30 PM
