SDTW Custom Wheels & Tires
Old 09-22-2010, 01:15 PM   #1
dplyttle
dplyttle's Avatar
Drives: 2SS RS Black with Cyber Gray Stripe
Any Truth to the Rumor that Installing an After Market Exhaust Will Void Warranty?
I was talking to some friends and they were saying a rumor had surfaced that adding an after market exhaust would void the manufacturers warranty on the 2010 Camaro. True? False?
dplyttle is offline   Reply With Quote
Old 09-22-2010, 01:20 PM   #2
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
In most cases, just a cat-back will not void your warranty. Long tube headers, which in most cases require a tune, probably will. Every dealership can be a little different....talk to your servicing dealership to make sure.
blazzin1 is online now   Reply With Quote
Old 09-22-2010, 01:20 PM   #3
Michelle42780
Cracker
Michelle42780's Avatar
Drives: 2010 2LT/RS Summit White/Beige
I was told a cat-back system will be fine.
2010 Camaro | 2LT | RS | Summit White | Beige Interior | Born: 5/10/10 | Purchased 5/28/10
Michelle42780 is offline   Reply With Quote
Old 09-22-2010, 01:27 PM   #4
autobotaz
Drives: Black 2010 Camaro LS
Dealer would have to prove that whatever the issue was, it was caused by you installing the exhaust. Axel back and cat back systems are really a non-issue. If you replaced eveything from the headers back including the cats you could have a potential issue but not likely.
They would just not warranty the exhaust or whatever you happened to replace.
No if you put a turbo on and then your engine blew you would likely be SOL.
Google the Magnuson-Moss Warranty Act. It provides us consumers with some level of protection.
So no they can not just void the warranty on the entire vehicle but they can exclude any parts that you have added or replaced with aftermarket parts and any damage that may have been caused by an aftermarket part.
They can't void the warranty on the transmission, suspension, interior, etc because you installed an exhaust unless they can prove that the exhaust caused the damage or problem.
autobotaz is offline   Reply With Quote
Old 09-22-2010, 01:40 PM   #5
The Stig
knows 2 facts about ducks
The Stig's Avatar
It will only void the exhaust warranty and that's IF they can prove your mod exhaust is what caused the problem.
Click to view my build thread
Old 09-22-2010, 01:48 PM   #6
KARR48
KARR48's Avatar
Drives: 2010 Camaro 2SS/RS Imperial Blue
If you have a failure that relates directly back to an aftermarket part then the failure would not be covered. So if you did put a cat-back exhaust on and you had say a window problem, the problem would be covered by warranty. Now if you had a rattle in the rear end that was caused by the a/m mufflers it would not be covered by warranty.
KARR48 is offline   Reply With Quote
Old 09-22-2010, 01:55 PM   #7
FinMan
Drives: Red Jewel 2010
warranty
Dealers don't really have to "prove" anything to initially deny your claim. If they do deny a claim it's up to you to spend $$$ to hire a lawyer and make them prove a relationship between your axle backs and your damage in a courtroom. Anybody tried that?
FinMan is offline   Reply With Quote
Old 09-22-2010, 02:02 PM   #8
camaroluver
Tampa Gulf Coast Family
camaroluver's Avatar
Drives: '05 Impala, '10 IOM Camaro SS
Send a message via AIM to camaroluver
If they try to deny your claim you don't have to run out and get a lawyer. There is a 1-800 number for GM you can contact IF it comes to that.
2010 Camaro 2SS IOM/Black Interior/Black Hood & Hockey Stripes #26,805
Ordered 1/30/09 as a surprise for me by the best husband ever! Delivered 8/6/09 to me!!!
camaroluver is offline   Reply With Quote
Old 09-22-2010, 02:05 PM   #9
LT's and Corsa Exhaust on mine, FT warranty.
Old 09-22-2010, 02:10 PM   #10
sangerbanger58
sangerbanger58's Avatar
Drives: 2010 IBM Camaro 1LT/RS
Question
i'm in the same boat i want to put on the SLP LM I on mine would that void mine 2
sangerbanger58 is offline   Reply With Quote
Old 09-22-2010, 02:17 PM   #11
camaroluver
I've had the SLP loudmouth on mine since last Sept. I also have an aftermarket CAI. In March of this year I had the entire engine replaced under warranty.
Old 09-22-2010, 03:25 PM   #12
SSPower
Surely thou jivest...
SSPower's Avatar
Drives: 2SS/RS LS3 CGM/IOM stripes
Several years back had a silverado pickup that I had installed a cat back exhaust on. Maybe a month or so passed and I got a CEL, I took it to the dealer for them to see what was up and to fix it.
To make a long story even longer..the service manager "claimed" that he couldn't do any diagnostics because he thought that it might be directly related to my cat back exhaust. I was like...are you kidding me? He said that the exhaust could have decreased the back pressure and caused the computer to throw a code....I was like WTF are you serious? This guy would not even hook it up to see what code was thrown unless I put the original exhaust system system back on it. Needless to say...after taking this up the chain of command...they finally agreed to hook it up and diagnose the problem which by the way...had absolutely nothing to do with my cat back exhaust.
The point is...some dealers out there can be real pricks...it all depends on where you go I guess.
SSPower is offline   Reply With Quote
Old 09-22-2010, 03:32 PM   #13
Sax1031
Drives: 2000 Mustang GT
many dealerships will find whatever reason they can to not do warranty work.
technically they would have to prove the exhaust caused the damage/problem. but that would be in court, after they denied you warranty work and you hired an attorney to fight it.
Sax1031 is offline   Reply With Quote
Old 09-22-2010, 03:33 PM   #14
camaroitalia
Go Harder Than Baltimore!
camaroitalia's Avatar
Drives: 2010 CGM
Which SLP LM did you have? 1 or 2? and why was your engine replaced?
MAGNAFLOW Cat-Back / Axle-Back Exhaust Systems | FREE Shipping Apex Paul V8 Bolt-Ons & Tunes 134 01-24-2011 01:56 AM
Tuner will VOID warranty Stealth 2010 2SS/RS Tuning / Diagnostics -- engine and transmission 644 07-08-2010 12:39 AM
Portland/Vancouver dealers willing to mod - and not void your warranty? Topdown USA - Northwest / Pacific Northwest 3 05-14-2010 03:26 PM
SS Basic Upgrades? Mod4SS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 58 08-10-2009 06:01 PM
will adding after market headers void warranty? lakersftbl69 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 05-26-2009 02:07 AM
