Wheels and Tires Talk Sponsored by The Tire Rack Discuss issues related to wheels and tires
Old 09-22-2010, 01:34 PM   #1
EricSS2
Drives: SS2/RS Black
NT05 worse than stock
I got new Foose wheels, 20x8.5 front and 20x10 rear, put NT05s 315/35/20 on the back and moved the stock backs to the front. I bought the NT05s because I installed a vortech sc a few weeks ago and wanted better traction but the NT05s seem worse than stock. I'm basing this on wheel spin, with the stock if I floored it from a stop, the wheels would spin but the car would keep straight and take off. With the NT05s the wheels spin more, it starts to go sideways and I have to let off the gas.
Any ideas? I thought the NT05s would hook great.
EricSS2 is offline   Reply With Quote
Old 09-22-2010, 01:56 PM   #2
2quick
2quick's Avatar
Drives: 2010 ss
Are you doing the test with the same conditions? On a hill? flat? wet? dry? there can be lots of factors.
2quick is offline   Reply With Quote
Old 09-22-2010, 02:04 PM   #3
EricSS2
Yes, same exact spot. dry weather.
Old 09-22-2010, 02:04 PM   #4
2SSCAMARO
2SSCAMARO's Avatar
Drives: 2010 Camaro Auto
You should have got the NT05R....not the NT05
2SSCAMARO is offline   Reply With Quote
Old 09-22-2010, 02:33 PM   #5
SuperFly03
Drives: 2010 Kona Blue GT500
Just for clarification purposes, you installed the supercharger then checked wheel spin on stock tires then compared them to NT05's?
You just don't specify when you got your wheels relative to the SC.
Also, is TC on in both cases or off or sport mode?
CERTIFIED PUBLIC ACCOUNTANT [TEXAS]
You've been Thread Jacked by SF03!
Current Car: 2010 Kona Blue Shelby GT500 M6
Previous Car:
2010 Black Camaro 2SS/RS M6
Two Back: 2007 Black Shelby GT500 M6
SuperFly03 is offline   Reply With Quote
Old 09-22-2010, 02:46 PM   #6
EricSS2
I got the SC installed then about a week later the tires so I'm comparing after the SC install. I couldn't get the tires to spin at all pre SC.
This is with TC on in Sport mode in both cases.
Old 09-22-2010, 02:47 PM   #7
EricSS2
I have read a few other people say the NT05 didn't stick well also but most seem to think they're great.
Old 09-22-2010, 02:52 PM   #8
Dave Coyle
Dave Coyle's Avatar
Drives: 2010 SS , 1970 Z-28, 2002 Avalanche
I can't believe that you don't have traction, I believe that Rick from Livernois Motorsports had the NTO5R's on a costumers car at the C5 in GA and ran in the low 10's with them. Are you doing the recommended burnouts before launching the car?
IF IT'S WORTH HAVING, IT'S WORTH WAITING FOR!!!! (AND IT WAS)
434RWHP/403RWTQ
Livernois Motorsports 2C Cam kit
Kooks 1 7/8 LT Headers/Hi-Flo Cats/Corsa Exhaust
Roto-Fab CAI / Port Intake
Precission 2400/2800 Converter/3.73 AAM gears
Livernois Motorsports Tune
Best time: 11.97 @ 117 MPH
Dave Coyle is offline   Reply With Quote
Old 09-22-2010, 02:57 PM   #9
Snake Slayer
Snake Slayer's Avatar
Drives: Awaiting 2014 C7
I think the problem is the fact that you are running a 315 tire on 10" wheel. The tire is probably bulging at the side wall and not allowing the tire to make a full contact patch/foot print
Snake Slayer is offline   Reply With Quote
Old 09-22-2010, 03:03 PM   #10
SuperFly03
Thanks for the clarification.
I'm guessing A6 not M6, correct?
If it's an M6... I'm curious how you couldn't break the Pirelli's loose. Just need more RPM's :p
Previous Car:
Old 09-22-2010, 03:05 PM   #11
SuperFly03
Damn. Good catch... I forgot 315's need at least a 10.5 rim (11 preferably).
Wasn't even paying attention.
Previous Car:
Old 09-22-2010, 03:21 PM   #12
EricSS2
Yes, its an A6. I've seen others run 315's on 10 rim, there is even a thread where people are putting the NT05 315 on the stock rims. Of course I have no idea how its working for them.
Old 09-22-2010, 03:56 PM   #13
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
Well you put the NTO5's on instead of the NTO5R's...HUGE difference in tire compound. Your not going to notice a difference betweent the 305's and the 315's on those 10" rims. The contact area that is used will still be roughly the same on the 305's you just waste the edges on your 315's and have that truck like bulge... get the NTO5R's and your traction should improve. This doesn't account for the previously mentioned variables...but the tire compound itself makes a HUGE difference.
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 09-22-2010, 04:12 PM   #14
Chris@Livernois
Chris@Livernois's Avatar
Drives: 2010 Camaro
They do need to be pretty warm to hook well, but I went a 1.5 60' on stock suspension and 10.44 @ 135 mph in Midgard's car.
-Rick
Chris@Livernois is offline   Reply With Quote
Old 09-22-2010, 04:22 PM   #15
SSRSLY
Lady Racer
SSRSLY's Avatar
Drives: 2010 Camaro SS/RS
Our NT05's hook fine, so long as you don't dump it from a dig or gas it around a corner. But, we're running a 315 on 11 inch wheels.
2010 Camaro SS/RS: HRE, MGW, Magnacharger, BMR, TSP || 2012 Boss 302: BMR, Forgeline (incoming)
SSRSLY is offline   Reply With Quote
Old 09-22-2010, 04:23 PM   #16
MillerTime
MillerTime's Avatar
-Rick
That's his issue..He got the NTO5's and not the NTO5R's... Should be able to get your 60' times with the R's... or at east sub 2's..
2G1FS1EWXD9163847
Old 09-22-2010, 04:59 PM   #17
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2011 Camaro SS
This. Just because a tire fits on a wheel, that doesn't mean it is properly sized for the wheel. Chances are, at WOT your tire expansion is likely making your tread contact patch shrink since they are too wide for the wheels. Try the 305 wide drag radial, you won't have traction issues...unless its raining.
www.DV8Motoring.com - Forged Wheels & Customs
Email: Tony@DV8Motoring.com
Old 09-23-2010, 12:44 AM   #18
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
Try playing around with your tire pressures and let us know how things went.
C.A.I., Apex Scoop, ARH LT, Pypes Cat Back, Barton Short Throw, JDP Tow Hook
Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler
Pfadt coilovers, camber plates, trailing arms & differential bushings.
BMR adjustable toe-rods. Pedders ZL1 barz, rear cradle inserts, radius arm & steering rack bushings.
Hotchkis Max Chassis Brace (minus tunnel cross-over piece for SCCA rules)
1LE 3.91 gearzzz. Drive Shaft Shop Road Race Axle Upgrade. TurnOne power steering pump.
Forgeline GA3-R 19x11 + Hoosier R6 315/30R19
426 HP @ 5550 RPM / 427 TQ @ 4700 RPM
Avalnch is offline   Reply With Quote
Old 09-23-2010, 12:49 AM   #19
Merc
COTW 12/5/11
Merc's Avatar
Drives: 2010 Camaro 2SSRS IOM
Old 09-23-2010, 01:06 AM   #20
gotpball44
Boost Is Your Friend
gotpball44's Avatar
Drives: 2010 Black 1SS Camaro
Send a message via AIM to gotpball44
Ur the first person i heard that doesnt like the nt05. Everyone that i talk to loves the tire. Its Nittos best street tire you can buy
gotpball44 is offline   Reply With Quote
Old 09-23-2010, 06:36 AM   #21
2SSCAMARO
2SSCAMARO's Avatar
That's right "street" tire......not Drag Racing tire!
Old 09-23-2010, 06:42 AM   #22
orange10s.c.
GARYS CUSTOM
orange10s.c.'s Avatar
Drives: IOM 2SS RS M6 sunroof
the NT05's work great under these conditions !!
Old 09-23-2010, 12:49 PM   #23
EricSS2
Thanks everyone for your help. I'll give it a few more tries and make sure the tires are warmed up. It sounds like I need to get the NT05R but I can't dump these and spend another $600 for those so I'll make do with these for now. I also only see the NT05R for 20'' wheels in a 315.
Old 09-23-2010, 11:33 PM   #24
hot ss
hot ss's Avatar
Drives: aqua 2ss l99
local canada tire shop quoted me $588 each NT05R. EACH i say again, egads.
kal tire is only importer according to nitto.
i bought them out of cali, who shall ship them out of british columbia. for 160 less each, in cdn dollars.
May your exhaust note, sing in harmony with your blower.
hot ss is offline   Reply With Quote
Old 09-23-2010, 11:41 PM   #25
jagan323
I have no life
jagan323's Avatar
Drives: 06' Subaru STI, ex-Camaro V6 LLT
you can get them cheaper in BC, just FYI...
Yeah, and with a SC, you should really burn out your wheels before you try that launch. Heat them up real nice. Im sure they will work fine.
jagan323 is offline   Reply With Quote
DIY Noweeds exhaust diverter installation CanadianCamaro Camaro DIY & HOW-TO instructions & discussions 12 05-11-2013 03:17 PM
Tires, anyone using Nt05 rears Napper Wheels and Tires Talk Sponsored by The Tire Rack 14 07-17-2010 08:47 AM
ALL Our Camaros are GM Prefer Pricing (old Supplier Pricing) at MacMulkin Chevrolet! MacMulkin Dealer Camaros for Sale 0 01-20-2010 06:40 PM
Camaro L99 American Racing Headers (Catted) system with stock exhaust = +42rwhp pharmd Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 43 07-25-2009 10:01 AM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 01:00 PM
