Flowmaster Exhaust
Old 09-22-2010, 07:24 PM   #1
6bloodychunks
6bloodychunks's Avatar
Drives: 2011 2SS/RS SGM
shift knob adapter question
ok,heres my problem,
so far i havent been able to find anywhere that makes an adapter
that will let me use a screw on shift knob on the push on knob shaft.
does anyone make one of these that is specificaly for the 5th gen camaros?
if it makes any difference,i will have the factory hurst shifter option.
---2011 synergy green 2SS/RS---
09/27/2010 - (3800)
10/01/2010 - (4200)
10/09/2010 - (4800) Vehicle on final destination route
10/19/2010 - (5000) delivered to dealer
11/19/2010 - (6000) delivered to customer
6bloodychunks is offline   Reply With Quote
Old 03-03-2011, 09:05 PM   #2
wmora4
wmora4's Avatar
Drives: 2010 1LT/RS IBM
Have anyone found where to buy this?
Help!!!!
wmora4 is offline   Reply With Quote
Old 03-03-2011, 09:06 PM   #3
Alfieboy
Madman
Alfieboy's Avatar
Drives: 2017 1SS
check with dave @ barton industries....
Alfieboy is offline   Reply With Quote
Old 03-03-2011, 09:13 PM   #4
wmora4
wmora4's Avatar
great !!! thanks .. i will !!
Old 03-03-2011, 10:20 PM   #5
anglwngss
Lone Star Camaro
anglwngss's Avatar
Drives: 2011 Synergy Green 2SS/RS
MGW sells them too.
anglwngss is offline   Reply With Quote
Old 03-04-2011, 11:06 AM   #6
wmora4
wmora4's Avatar
so this is the shift knob that I got and this is the adapter that I need on the stick...(picture from another member that got it from Barton)
i called Autoanything and they donít have the adapter..
i called Dave at Barton industries and they dont have the adapter maybe in another 2 months.
i call MGW and they donít have/make that adapter their camaro shift knobs donít come with adapter they are made to fit the factory stick i guess..
TWM shift knobs have camaro adapters 3/4 16 that wonít fit the hurts shift knob.
any other ideas where can i get this adapter?
Old 03-04-2011, 03:41 PM   #7
wmora4
wmora4's Avatar
yeah i tryed that but they dont have any now !! they say maybe in two months.//
but i did find this one on on shopMRt.com
http://www.mrt-direct.com/mrtntadapt.html
Product Description
NOTE: BECAUSE THE STOCK OEM SHIFTER ON THE 2010+ CAMAROíS ARE UNTHREADED, USE OF ANY AFTERMARKET SHIFTBALL WILL REQUIRE A NON-THREADED SHIFTBALL ADAPTER. *CONVERTS YOUR THREADED SHIFT KNOB TO A NON-THREADED SHIFTER SHAFT *CAN BE USED WITH ANY SHIFT KNOB WITH A 16 X 1.5 MASTER *POLISHED ALUMINUM FINISH
hopefully it works !! thanks.
Old 03-04-2011, 03:49 PM   #8
wmora4
wmora4's Avatar
yeah .. i talked to him this morning and he said that they dont have the adapter on stuck for a couple of months . so i ask even if i buy the shift knob also ? and he said not that they just dont have the adapter...
Old 03-04-2011, 04:05 PM   #9
wmora4
wmora4's Avatar
i see what you are saying now.. get that and just replace the knob for the one i have now... !! got ya !!!
thanks..
Old 03-04-2011, 04:20 PM   #10
wmora4
wmora4's Avatar
Great!! Thanks for the advise!!
Old 03-04-2011, 05:15 PM   #11
Alfieboy
Madman
Alfieboy's Avatar
Drives: 2017 1SS
shifter
Get the whole shifter from Dave @ Barton, then use your ball/handle...
http://s599.photobucket.com/albums/t...nt=shifter.jpg
Old 10-11-2012, 02:41 PM   #12
AKA-22
AKA-22's Avatar
Drives: ELLE-1
bookmark
AKA-22 is offline   Reply With Quote
Old 10-26-2012, 12:33 PM   #13
Kadet1
Kadet1's Avatar
Drives: Camaro SIM
i bought that same hurst shifter for my car and have had no luck finding that adapter either. for now i went to ace hardware and bought black friction tape i wrapped the shaft with the tape and then twisted on the handle it is on there really good and has to be unthreaded to be removed it cannot just be pulled off. This is just temporary until the adapter can be found let me know if you have found it somewhere.
Kadet1 is offline   Reply With Quote
Old 10-26-2012, 02:20 PM   #14
BA RS
Big B
BA RS's Avatar
Drives: SIM 2LT M6
You might check with www.flameball.com I believe they have adapters that will fit over the stick. I bought mine shift knob from them and it came with a plastic piece that slid over the shaft and then I just pushed the knob down on it and then used the set screw.
2010 2LT, M6 ,Spectre Cold Air Intake,RGB Grill LEDs,Blue LED footwell lights, plastic dip bowties , painted engine cover , fuse box, flameball shifter knob.
BA RS is offline   Reply With Quote
shift knob - removed and redone oldfart1941 Cosmetics and Lighting Modification Discussions 17 06-21-2011 02:15 PM
FS: Hurst T-Handle Shift knob, Hurst INC Emblem. nak3dsnake Transmission / Driveline 9 03-05-2011 06:59 PM
Just got my brand new shift knob WiccaJew Cosmetics and Lighting Modification Discussions 6 07-05-2010 05:44 PM
Shift knob adapters Thrillz V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 05-05-2010 06:14 PM
Question about steering wheel and shift knob jeansonne627 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 15 08-27-2009 03:45 PM
