Solo Performance
Old 09-22-2010, 09:41 PM   #1
Blitzman
173rd Paratrooper
Blitzman's Avatar
Drives: Summit White SS
What Sensor Is This?
Was pushing some wires out of the way while reinstalling the a/c belt earlier and this little bugger gave way with almost no pressure on it. It connects behind the A/C pulley on the compressor hub. Question is what does it control (temp im guessing) and can it be replaced without replacing the whole compressor?
Really hoping I can just replace the damn sensor.
Jeramey - 715rwhp
Vortech YSI - 10Rib
CTS-V Dual Fuel Pumps
American Racing Headers
Thunder Racing Cam
Walker Bullet Exhaust
DSS 1400hp Axles
Barton Industries Shifter
ADM Boost/AFR Gauges
Blitzman is offline   Reply With Quote
Old 09-22-2010, 11:29 PM   #2
Ocikat
Ocikat's Avatar
Drives: 2012 2LT 45th convertible
I'd think that would be the wire for the clutch on your compressor, does AC still work?
Ocikat is offline   Reply With Quote
Old 09-22-2010, 11:42 PM   #3
Cam 427
Cam 427's Avatar
Drives: 2010 2SS
If it came from the compressor hub, it's the connection that turns your AC clutch (system) on. That would require removal of the clutch/hub and replacing the coil.
Cam 427 is offline   Reply With Quote
Old 09-23-2010, 01:34 AM   #4
Blitzman
173rd Paratrooper
Blitzman's Avatar
Dont know installing Vortech YSI so car isnt together right now.
Thank you, if anyone has any more info to confirm this that would be great.
Jeramey - 715rwhp
Vortech YSI - 10Rib
Thunder Racing Cam
DSS 1400hp Axles
Old 09-23-2010, 11:14 AM   #5
Blitzman
173rd Paratrooper
Blitzman's Avatar
Anyone else have any info or can confirm its what Cam 427 said?
Jeramey - 715rwhp
Vortech YSI - 10Rib
Thunder Racing Cam
DSS 1400hp Axles
Old 09-23-2010, 01:44 PM   #6
ITGuy11
Burning up tires
ITGuy11's Avatar
Drives: 2010 Camaro 1SS/RS
Did you try the dealer?
Blower, cam, supporting mods 644RWHP 615RWTQ
My Build Thread COTW 11/19/12
Detroit 5th Gen Camaro Club
ITGuy11 is offline   Reply With Quote
Old 09-23-2010, 01:46 PM   #7
robsls3
Drives: 2010 camaro 1SS
Its part of the AC compressor and as cam 427 stated thats how you change it.
Try turning on your AC and see if you get cold air.
robsls3 is offline   Reply With Quote
Old 09-23-2010, 01:56 PM   #8
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
that is for the a/c clutch,, it should be attached to the front of the compressor,, you can replace just the electro magnet but you need to remove the compressor and pull off the clutch plate and pulley/bearing, then the magnet will pull off and can be replaced
Old 09-23-2010, 02:27 PM   #9
Russell James
Russell James's Avatar
Drives: Camaros
The good news is you will not need a new compressor. You need the compressor coil.
The pulley comes off first, there is a bolt in the center. Then the coil comes off with a snap ring in the center. Pay attention to which way the snap ring goes back in. The flat side goes against the compressor.
Once the snap ring is off, the coil will come off.
The service manual says - remove the AC Compressor "if necessary"
So I'm not sure if you can get to the bolt and snap ring with the compressor still mounted there, but it's worth a try.
Old 09-23-2010, 02:49 PM   #10
Blitzman
173rd Paratrooper
Blitzman's Avatar
Thanks guys that was exactly what I needed to know.
Jeramey - 715rwhp
Vortech YSI - 10Rib
Thunder Racing Cam
DSS 1400hp Axles
