B&M Racing
Old 09-23-2010, 10:21 AM   #1
chilihed
Drives: 2010 Hendrick Modified SS #015
save your clutch
I read this from another website and I will try to find a link, but the bottom line is this......Your clutch, and brakes share the same fluid, and on our cars share the same master cylinder. Every few months or so, maybe even at each oil change, use a turkey baster syringe to suck out all the old nasty, and probably brown fluid, and top it off with new. Then go for a 5 or 10 minute drive, and do it again until your fluid in the reservoir is reasonably clear. This allows you to remove the abrasive clutch dust from the system without having to bleed it. This also extends the life of all your hydraulic equipment having anything to do with your clutch or your precious Brembos. All this takes about 10 minutes, and costs about $10. Pretty simple math there eh? Here is the link.
http://rangeracceleration.com/Clutch_Care.html
chilihed is offline   Reply With Quote
Old 09-23-2010, 10:50 AM   #2
2001ragtop
2001ragtop's Avatar
Drives: V8 american car
That write-up is very interesting. If his suggestion genuinely works, I would do that as often as he suggests. it sounds easy, yet annoying at the same time.
i wonder how long the brake fluid would remain clear if you just drove the car with no type of racing or slamming on the brakes.
2001ragtop is offline   Reply With Quote
Old 09-23-2010, 10:52 AM   #3
VTXrider
VTXrider's Avatar
Drives: RY 2SS/RS
Usually what I do is change the fluid in the reservoir and pump the clutch 20 times or so then change it again, no driving necessary in between. Repeat until clear.
But thanks for this reminder, I haven't done this for the Camaro yet.
VTXrider is offline   Reply With Quote
Old 09-23-2010, 10:52 AM   #4
Jefe's SS
Drives: 2010 2SS/RS IOM L99
Does the clutch and brake system really share the same fluid and resevoir?
Jefe's SS is offline   Reply With Quote
Old 09-23-2010, 10:55 AM   #5
VTXrider
VTXrider's Avatar
Drives: RY 2SS/RS
I was wondering this too, kind of sad that I still haven't been under the hood enough to know this. The same type of fluid yes, but really the same reservoir?
Old 09-23-2010, 10:56 AM   #6
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
Yes. There is a splitter, but some fluid Does make its way from one side to the other..
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 09-23-2010, 11:00 AM   #7
chilihed
As mentioned above it is not necessary to drive the car, simply pumping the clutch pedal 20-30 times does the trick. I don't even have 2k miles yet and my fluid was getting some coloration to it.
Old 09-23-2010, 11:32 AM   #8
VTXrider
VTXrider's Avatar
Drives: RY 2SS/RS
Also worth mentioning a couple of things here.
1. Brake fluid will eat through your paint amazingly fast. Be extra super careful not to drip any on your paint, have a towel over any part of your car with even the slightest possibility of a drip.
2. Brake fluid absorbs moisture very fast even from humidity, keep everything open as short a time as possible. When I open the new bottle I punch a small hole in the seal to let as little air as possible (you will only use a fraction of the bottle) replace the bottle periodically.
Old 09-23-2010, 11:35 AM   #9
phenixdragon
Drives: 2010 Camaro SS
You sure about that? Because I have had my master replaced twice now and the salve once, and neither time did they need to bleed the brakes which I would assume you would need to do. But I don't know much about clutches and I didn't even know there has a mater or slave to begin with. I knew there were for brakes but I just never really thought about the clutch having them.
phenixdragon is offline   Reply With Quote
Old 09-23-2010, 11:39 AM   #10
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
I raise the BS flag.... clutch fluid discoloration on ls applications has been around for years. if 4th gens it was just as bad, and the clutch had a seperate resevoir.
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 09-23-2010, 11:54 AM   #11
robsls3
Drives: 2010 camaro 1SS
My GTO clutch fluid got dirty fast. Dealer cleaned it out twice with in the first 1000 miles and I done the next 2.
robsls3 is offline   Reply With Quote
Old 09-23-2010, 12:22 PM   #12
thekid96
Drives: Z06, 69 Camaro
Here is my solution for bleeding the clutch, saves mucho time and fluid. Anyone interested can PM me.
http://www.camaro5.com/forums/showthread.php?t=101008
thekid96 is offline   Reply With Quote
Old 09-23-2010, 12:26 PM   #13
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
There's a DIY thread for installing a separate clutch reservoir on here somewhere. Pretty simple, used the reservoir from a late model GTO.
Smoked tail lights/ZL1-1LE 3rd brake
Rotofab cai
Old 09-23-2010, 12:28 PM   #14
ZED SLED
ZED SLED's Avatar
http://www.camaro5.com/forums/showth...utch+reservoir
Rotofab cai
***STILLEN ACT Twin Disc Clutch System Intro Sale*** Team STILLEN Transmission / Driveline 55 01-08-2012 09:28 PM
NEW! Katech LS9X clutch for 2010+ Camaro Katech V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 03-11-2010 08:09 AM
Heads Up - Clutch Spring noise ffrcobra_65 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 11-22-2009 10:04 AM
Clutch "Sticking" Issue - Not Clutch Dust - Not Boiling Fluid Embalmer Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 09-11-2009 10:52 AM
