BeckyD @ James Martin Chevy
Old 09-23-2010, 10:21 AM   #1
paslag
paslag's Avatar
Drives: 2010 Camaro 2SS/RS
cruise cancel button feature
I'm installing a line lock on my car, but I wanted to use the ''cancel'' button from the cruice control. The entire cruise control panel runs with 1 data wire, so I came up with this circuit:
2010 2ss/rs Ls3, E-force s/c, 3.25'' pulley,Kooks long tubes w/cats, magnaflow 2.5" cat back, Rotofab cai, 65 lbs inj, MSD bap, AEM water/meth, comp cam, 621whp,577 wtq on mustang dyno
paslag is offline   Reply With Quote
Old 09-23-2010, 10:23 AM   #2
paslag
paslag's Avatar
You can also use this to activate NOS!
Old 09-23-2010, 07:50 PM   #3
daphatgrant
June '10
daphatgrant's Avatar
Drives: '10 2SS/RS RJT
Very cool man, I just had to go and look up what a line lock was though, lol.
Line lock is a solenoid that actually locks the front brakes, so that you can do a brake stand and warm up the rear tires. As long as you hold the little button, the front brakes will stay on.
It's also used to prevent the car from taking off of the starting line too soon and can be used as a hill brake.
http://www.hotrodders.com/forum/what...ock-41283.html
RJT, 2SS/RS, M6, Black Int, Sunroof.
daphatgrant is offline   Reply With Quote
Old 09-23-2010, 11:07 PM   #4
TonyNo
TonyNo's Avatar
Drives: 2016 2SS, SW
I would think that you would want a resistor on the base, unless there is one upstream at the switch.
TonyNo is offline   Reply With Quote
Old 09-24-2010, 01:56 AM   #5
jagan323
I have no life
jagan323's Avatar
Drives: 06' Subaru STI, ex-Camaro V6 LLT
Yeah, i want to install a linelock on my car too LOL. Should be awesome =D Let us know what your install looks like after you are done =D And show some crazy burnout videos! =D
jagan323 is offline   Reply With Quote
Old 09-24-2010, 11:41 AM   #6
paslag
paslag's Avatar
My install is already done and it works great. You don't need a resistor at the base of the transistor since it's already low voltage (2.11v).Resistor is already in the cruise control panel.
Old 03-12-2011, 05:17 PM   #7
paslag
paslag's Avatar
Sorry, it is not a 1n9004 diode... it's a 1n4004... you can use 1N4001 thru 1N4007
Envoyé de mon iPhone avec Tapatalk
Old 03-13-2011, 12:53 PM   #8
Fubar
Drives: SW 2SS/RS M6
Fubar is offline   Reply With Quote
Old 03-14-2011, 02:38 AM   #9
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
NOS application?
Thanks for the idea and great job, thats just genious
CAMARO
Old 03-14-2011, 02:17 PM   #10
paslag
paslag's Avatar
It would work for NOS activation...
Old 03-26-2011, 09:42 AM   #11
JohnForeman
Drives: 2010 2SSRS
Do you lose the use of the cruise control?
2010 2SSRSA6 - GFX
35% Window Tint
93 Octane Diablo Predator Tune
JohnForeman is offline   Reply With Quote
Old 03-29-2011, 01:45 PM   #12
mwt18
mwt18's Avatar
Thumbs up
I can confirm that this does work!!
'Paslag' walked me through it and was very helpful!
When the arm switch is open, all cruise control buttons function as normal. When the switch is closed, the cancel button provides 12V to the solenoid as long as it's held down.
I was going to do a full-blown DIY on this but just got swamped with work.
Here's the completed diagram:
FOR SALE:
- Maggie w/ 3.6" Pulley | Kooks Coated 1 7/8" LT Headers | Rotofab CAI | MSD FPVB | ZR1 Twin Disc Clutch / LPE flywheel | MGW Short Throw Shifter | Diablosport Trinity / PLX boost & AFR sensor modules | TCI line-lock
mwt18 is offline   Reply With Quote
Old 03-29-2011, 06:18 PM   #13
caverman
caverman's Avatar
Drives: '69 SS Convertible
No someone needs to come up with a way to make this an easy install and I would be all over it. I'm not big on wiring things up unless it's real straight forward.
Build Journal
Old 03-29-2011, 06:29 PM   #14
Padre
Only drives on Sundays
Padre's Avatar
Drives: '16 2SS A8 NPP MRC NGray
Yep, a full-blown DIY would be awesome.
Padre
OLD HOTNESS: The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
NEW HOTNESS: '16 2SS A8 NPP MRC. Bone Stock, 1/8th: 8.051 @ 89.44, 1.919
Padre is offline   Reply With Quote
Calling all central Texans! Cruise for charity on June 9th!!! Need YOUR help! TAG UR IT USA - Texas 71 06-11-2010 03:10 AM
Coastal Cruise Inzanesrt4 USA - Northwest / Pacific Northwest 6 06-08-2010 04:47 PM
Circuit Motorsports Daytona Beach / Central FL Cruise Circuit Motorsports USA - Southeast 9 09-26-2009 10:42 AM
Marks Cruise Night Connecticut Closing Event 9/14 irocnroll USA - NY / NJ / PA 21 09-19-2009 12:04 PM
Woodward Dream Cruise - F-Body Cruise/Parking on Saturday August 15th 2009 SlpDave USA - Great Lakes 11 08-19-2009 05:26 PM
