Old 02-19-2011, 02:06 PM   #15
caverman
caverman's Avatar
Drives: '69 SS Convertible
Looks good!
Definately a cheap and easy mod.
Build Journal
Old 02-19-2011, 02:10 PM   #16
blackknight
Camaro Lover
Drives: 2014 GMC Sierra 5.3L
For sure.
next up....CAI and exhaust. those....are a bit more expensive haha
No Camaro right now. But I'll be back in one in a few years.
blackknight is offline   Reply With Quote
Old 03-06-2011, 12:56 PM   #17
The Stig
knows 2 facts about ducks
The Stig's Avatar
Originally Posted by blackknight View Post
Ok so i was able to get it done. I was able to stick a water bottle at the thermostat housing to catch remnant coolant that didnt drain.
I was able to reuse the stock clamps...it was a pain but i got them on there.
Overall this went without a hitch. Burped the coolant system when i was done and took her for a drive. Temps were hight at first, but i burped it a few times while driving and they went down to around 198.
Here are some pics. Overall this was a preetty easy mod and cheap! the hoses come from amazon are 30 bucks or so shipped! no brainer compared to some of the kits that cost a lot.
old hose- came off the firewall surprisingly easy. just a few twists and popped right off.
firewall connections
fed by the abs perch
back to the water pump/tstat housing
overall shot
When you say "burped" what do you mean? Like how would I burp the system?
Click to view my build thread
Old 03-06-2011, 01:00 PM   #18
looks good
Old 03-06-2011, 03:59 PM   #19
blackknight
Camaro Lover
when you drain the system and put the coolant back in there will be air bubbles in the system. You have to literally...burp the bubbles out of the system.
Its easy to do. once you have the coolant back in, start the car and unscrew the filler cap on the radiator to allow the air to escape.
Old 03-07-2011, 08:20 AM   #20
67motorcat
Blown Cool Breeze
67motorcat's Avatar
Drives: 2011 Black on Black 2SS M6
I did mine as well.
The funny thing is the 5/8 nipple on the firewall goes to the 3/4 nipple on the water pump.
And the 3/4 nipple on the firewall goes to the 5/8 on the water pump.
I wonder why GM did that
Folks need to be sure to get it the rite way.Use the correct diameter hose at the firewall and spread the 5/8 hose over the 3/4 nipple at the water pump.Less chance damaging the heater core that way.
I wonder how many people have going to the same size nipple both ways and if it would make a difference?The water control valve could be impacted with the flow of water going the wrong direction?
Had a 2010 IBM 2SS M6
Enjoy life.Think of all the women on the Titanic who passed up dessert.
67motorcat is offline   Reply With Quote
Old 03-08-2011, 07:50 AM   #21
BigRed585Lbs
Drives: Sierra and Tahoe
I thought only us old farts got confused.
BigRed585Lbs is offline   Reply With Quote
Old 03-08-2011, 08:08 AM   #22
motorhead
Drives: POS MOPAR
I can't really see in the pics well. Where are you guys relocating them too? It looks like you're relocating them by the exhaust manifolds which would be a very bad idea. Can someone chime in or show some better pics?
Old 03-08-2011, 08:09 AM   #23
67motorcat
Blown Cool Breeze
67motorcat's Avatar
I'm old now too!
Age has nothing to do with it....
Old 03-08-2011, 08:12 AM   #24
67motorcat
Blown Cool Breeze
67motorcat's Avatar
The hoses are running inside the ABS perch.
They are protected by the heat shield,Run split conduit over the hoses to protect from chaffing.
It's tight,but fit perfectly.
Old 03-08-2011, 08:21 AM   #25
caverman
caverman's Avatar
Nope...no where near the exhaust. There are some openings in the bracket holing the ABS module. You use that to go through.
Build Journal
Old 03-08-2011, 09:09 AM   #26
Coop
Drives: 2010 Camaro 1SS
For later mod.
2010 Camaro 1SS Inferno Orange Magnusson Supercharger Installed and Tuned by ADM Performance, Roto Fab CAI IOM painted, MBRP Cat Back Exhaust, Barton Industries Short Shifter, Clear Image Headers, Pedders coilovers, BMR Front/Rear sway bars Trailing Arms and End Links, VMax ported TB
Coop is offline   Reply With Quote
Old 03-08-2011, 09:14 AM   #27
Cam 427
Cam 427's Avatar
Drives: 2010 2SS
Nicely done. I wish I had gone this route instead of AFX hose kit. Although a nice OE look, the hose kit is in the way as far as accessing spark plugs and header bolts.
Cam 427 is offline   Reply With Quote
Old 03-08-2011, 09:21 AM   #28
Cam 427
Cam 427's Avatar
Drives: 2010 2SS
Originally Posted by Gonzo View Post
This is a great DIY. Just had one question, what did you do with the check valves that were in the heater hoses? I noticed that you had the check valves in your 'before' picture and wondered if you included them with the new hoses.
The plastic checkvalve looking things in the original hoses are just connectors.
ReRoute of Heater hoses w/ pics GMRULZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 92 09-18-2011 07:15 PM
Can V8 be too much car? tronic 5th Gen Camaro SS LS LT General Discussions 86 07-30-2010 09:10 PM
Hose relocation kit brooks35 V8 Bolt-Ons & Tunes 1 05-24-2010 10:00 PM
TSB on Belt? Screaminz2002 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 34 02-19-2010 07:28 AM
Hose & Cable Catchers At ProperAutoCare.com Angelo@Autopia Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 2 02-02-2010 03:05 PM
