Solo Performance
Old 03-08-2011, 07:52 PM   #29
blackknight
Camaro Lover
Drives: 2014 GMC Sierra 5.3L
Originally Posted by Cam 427 View Post
The plastic checkvalve looking things in the original hoses are just connectors.
precicsly they are quick connects / quick disconnects.
No Camaro right now. But I'll be back in one in a few years.
blackknight is offline   Reply With Quote
Old 03-09-2011, 07:52 AM   #30
motorhead
Drives: POS MOPAR
Originally Posted by 67motorcat View Post
The hoses are running inside the ABS perch.
They are protected by the heat shield,Run split conduit over the hoses to protect from chaffing.
It's tight,but fit perfectly.
Originally Posted by caverman View Post
Nope...no where near the exhaust. There are some openings in the bracket holing the ABS module. You use that to go through.
Thanks for the info. I went out and looked at mine last night and I see what your talking about. Great job Guys!
Old 04-25-2011, 08:56 PM   #31
d69chris
Florida C5
d69chris's Avatar
Drives: 2010 Camaro 2SS Vortech L99 IOM
Send a message via Yahoo to d69chris
I did mine as well.
The funny thing is the 5/8 nipple on the firewall goes to the 3/4 nipple on the water pump.
And the 3/4 nipple on the firewall goes to the 5/8 on the water pump.
I wonder why GM did that
Folks need to be sure to get it the rite way.Use the correct diameter hose at the firewall and spread the 5/8 hose over the 3/4 nipple at the water pump.Less chance damaging the heater core that way.
I wonder how many people have going to the same size nipple both ways and if it would make a difference?The water control valve could be impacted with the flow of water going the wrong direction?
So the 3/4 hose looks like it works best on the firewall, is it 5/8 on the other end that hooks to the water pump or do you really squeeze it? Picture almost loks 5/8. Then the 5/8 on the firewall has to be stretched over the 3/4 on the pump? that's where the WD comes in? Looking to order hoses and do this next weekend.
thanks in advance
Ordered 11/08/08....Del. 08/05/2009 Loving every minute of it! Don't hate me because i'm Pretty....
d69chris is offline   Reply With Quote
Old 04-25-2011, 09:16 PM   #32
67motorcat
Blown Cool Breeze
67motorcat's Avatar
Drives: 2011 Black on Black 2SS M6
Use 3/4" hose on everything.
Sounds wierd but works perfectly.
You will see what I mean when you install them.
Had a 2010 IBM 2SS M6
Enjoy life.Think of all the women on the Titanic who passed up dessert.
67motorcat is offline   Reply With Quote
Old 04-25-2011, 09:51 PM   #33
caverman
caverman's Avatar
Drives: '69 SS Convertible
Actually from what I remember it's both 5/8 and 3/4 on both hoses. In other words looking at connection points on the firewall the one that's 5/8 will go to the one that's 3/4 on the waterpump. Same in reverse on the other side.
If you order the hoses listed in the first thread they'll install perfectly (with a little length trimmed off one hose).
Build Journal
Old 04-25-2011, 10:08 PM   #34
67motorcat
Blown Cool Breeze
67motorcat's Avatar
That could be very true.
I did not use the pre-formed hoses,just standard 3/4" heater hose from Napa.
The larger fitting on the water pump is actually bigger than 3/4" thus requiering a slight bulge to fit over.
The larger fitting at the fire wall fit the 3/4" hose perfectly.
The smaller fitting at the firewall fit just ever so slightly loose with the 3/4"
The smaller fitting at the water pump was easy loose.
I used worm clamps everywhere.
Kinda wierd if you ask me
Old 04-25-2011, 10:12 PM   #35
caverman
caverman's Avatar
Yes it is weird and your method of using 3/4" hose will work as well. I've heard of some people doing it with only the 3/4" as well. One side being pretty tight to go on and the other loose but with a tightened down clamp.
The ones I got off Amazon that are listed in the initial post already come with the slight buldge where need though. Makes it easy to deal with.
Build Journal
Old 04-25-2011, 10:15 PM   #36
67motorcat
Blown Cool Breeze
67motorcat's Avatar
I did mine as well.
Correction from this post.
I was going to use standard 5/8" hose on the firewall side but later decided against it.
It was going to take way to much force to get it on there and there was no way it was going to fit over the larger water pump fitting.
Again,the pre-formed hose may not be an issue.
Old 04-25-2011, 11:53 PM   #37
d69chris
Florida C5
d69chris's Avatar
Ok, now I'm confused..........
Will order the two hoses off Amazon and see where it leads.
Thanks Guys
Old 04-26-2011, 10:35 AM   #38
caverman
caverman's Avatar
Thanks Guys
What are you confused about? Hopefully we can clear it up for you.
Get the hoses off of Amazon and you'll be good. Hardest part is getting the hoses off the firewall because they are stuck on there pretty good and there's not alot of room to get your hand up in there.
Build Journal
Old 04-26-2011, 09:14 PM   #39
Eric Baker
Drives: Black/Black 2SS/RS 6M
I got my hoses from Napa. They were cross referenced from the Autozone part numbers through the Dayco website. In fast, they are Dayco hoses. They are 5/8" hoses with a 3/4" flare on one end, the ends being opposite for each hose. They needed slight trimming to make them the same length just like others stated. They worked out great and fit perfectly.
Eric Baker is offline   Reply With Quote
Old 06-15-2011, 05:46 AM   #40
2SSRSTUVWXYZ
2SSRSTUVWXYZ's Avatar
Drives: 2010 2ss rs sim camaro
Livernois motorsports has a hose relocation kit for sale on their website
2SSRSTUVWXYZ is offline   Reply With Quote
Old 06-15-2011, 10:43 AM   #41
caverman
caverman's Avatar
I couldn't find it but I'm willing to bet it's alot more than $35.
Build Journal
Old 06-15-2011, 12:16 PM   #42
Merc
In The Circle
Merc's Avatar
Nice work! Certianly look's to be a good option and cost saver.
ReRoute of Heater hoses w/ pics GMRULZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 92 09-18-2011 08:15 PM
Can V8 be too much car? tronic 5th Gen Camaro SS LS LT General Discussions 86 07-30-2010 10:10 PM
Hose relocation kit brooks35 V8 Bolt-Ons & Tunes 1 05-24-2010 11:00 PM
TSB on Belt? Screaminz2002 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 34 02-19-2010 08:28 AM
Hose & Cable Catchers At ProperAutoCare.com Angelo@Autopia Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 2 02-02-2010 04:05 PM
