SDTW Custom Wheels & Tires
Old 06-16-2011, 02:55 AM   #43
mrh923
mrh923's Avatar
Drives: 2011 Camaro 1SS/M6 Cyber Gray Met.
I'd love to do this mod! What size hoses do I need off of Amazon?
2011 1SS/LS3 M6--Vararam CAI-Corsa catback-Dynatech LTs-RX Catch Can-Vmax ported TB-Eibach Springs-Night Fury Camshaft- 486RWHP/458 TQ
mrh923 is offline   Reply With Quote
Old 06-16-2011, 08:22 AM   #44
caverman
caverman's Avatar
Drives: '69 SS Convertible
This is going to sound like I'm being a smart ass but I'm not....I apologize in advance if it sounds like it.
Everything you need is in the first post. Take a few min to read through it all.
Build Journal
Old 06-16-2011, 08:35 AM   #45
mrh923
mrh923's Avatar
I apologize...I did read through every post on this thread so far.
All I saw was the hose size and I didn't notice the part numbers that you included. Thanks for the correction. I just ordered them and I hope to get those ugly hoses off my intake this weekend.
Old 06-16-2011, 09:18 AM   #46
caverman
caverman's Avatar
Cool...
You shouldn't have any issues since almost everything has be touched on in the thread but if you run into any questions/issues just post them.
Build Journal
Old 06-16-2011, 01:13 PM   #47
calbert1999
Camaro SS Lover
calbert1999's Avatar
Drives: 2010 Camaro 2SS/RS Black IOM
This was the first thing I did after my ProCharger installation. The engine cover could not be used as it was too tight, and besides my personal opinion is the engine looks nicer than the piece of plastic covering it up.
2010 Camaro SS, P1SC SuperCharged Livernois LSX429ci., 1 7/8" LT Headers, full 3" MBRP exhaust, SPI built/tuned, a total
calbert1999 is offline   Reply With Quote
Old 06-16-2011, 01:40 PM   #48
photonfury
I wanna go fast!!!!
photonfury's Avatar
Drives: 2010 SS/RS Inferno Orange Metallic
Which relocate kit is that?
photonfury is offline   Reply With Quote
Old 06-16-2011, 02:01 PM   #49
calbert1999
Camaro SS Lover
This is the Tech AFX mentioned earlier in the thread, everybody sells them.
Had them installed now for about 1wk. no issues at all, and noticed engine and oil temps are lower on my centre guages.
I'd say a good buy, and clean if you want something extra than just replacing the rubber hoses.
Old 06-16-2011, 02:16 PM   #50
caverman
caverman's Avatar
Yep....same concept.
Obviously more money though because you're getting hard lines as opposed to all rubber.
If you're wanting more looks and willing to spend the money the Tech AFX is the way to go. For me I use an engine cover so the Tech AFX would be hidden.
Now...I will say that I had at least two guys that had Tech AFX say they wish they would've gone the rubber hose route because if you have to do anything with the spark plugs you have to remove the Tech AFX. I don't know how true that is or if you would even need to mess with your plugs.....just saying that's what I've been told.
Build Journal
Old 06-16-2011, 03:52 PM   #51
calbert1999
Camaro SS Lover
I'm not sure if would have to remove the TechAFX heater hoses to get to spark plugs, (I'll check later) but on my engine I'd have to remove SC air filter and coil covers to get to the spark plugs anyway
Old 06-16-2011, 05:58 PM   #52
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Originally Posted by Eric Baker View Post
I got my hoses from Napa. They were cross referenced from the Autozone part numbers through the Dayco website. In fast, they are Dayco hoses. They are 5/8" hoses with a 3/4" flare on one end, the ends being opposite for each hose. They needed slight trimming to make them the same length just like others stated. They worked out great and fit perfectly.
Eric, do you have the NAPA/Dayco part numbers? Are the same as the Gates numbers?
Old 06-16-2011, 07:52 PM   #53
camaro104
camaro104's Avatar
Drives: 2017 Nightfall 50th Annivers Camaro
Send a message via AIM to camaro104
This is a great DIY which i'm about to do but i found this set which looks good also.....
http://www.techafx.com/catalog/19
camaro104 is offline   Reply With Quote
Old 06-16-2011, 08:14 PM   #54
mrh923
mrh923's Avatar
I'd rather spend $40 for the rubber hose vs. $189 for that kit. A bit overpriced IMO.
Old 06-16-2011, 09:22 PM   #55
camaro104
camaro104's Avatar
Thumbs up
True, a lot cheaper for the rubber ones but my opinion the metal ones looks so much nicer, cleaner.
Old 08-30-2011, 11:23 PM   #56
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Drives: 2010 1SS:RS:LS3:SW
Just bought the hoses on amazon, finally getting to a mod I should have done very soon after I got the car.
A.K.A - Diarmadhi (old handle) - So much to do.. So little money
Owner : Fast-Stache Industries LLC
The_Stache is offline   Reply With Quote
ReRoute of Heater hoses w/ pics GMRULZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 92 09-18-2011 07:15 PM
Can V8 be too much car? tronic 5th Gen Camaro SS LS LT General Discussions 86 07-30-2010 09:10 PM
Hose relocation kit brooks35 V8 Bolt-Ons & Tunes 1 05-24-2010 10:00 PM
TSB on Belt? Screaminz2002 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 34 02-19-2010 07:28 AM
Hose & Cable Catchers At ProperAutoCare.com Angelo@Autopia Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 2 02-02-2010 03:05 PM
