Old 09-23-2010, 08:23 PM   #1
Arachnyd
Master of all trades
Arachnyd's Avatar
Drives: 2many2count
Always running low on oil?
I noticed when I changed my oil that it is REALLY low- so I decided I'd start checking it all the time. It's ALWAYS below the fill mark, and I check it atleast once a month, and therefore fill it. I know all cars burn a little oil, but isn't this a little excessive? Is this normal or should I bring it in?
2010 Camaro SS modified extensively. I stretched the body to make it a 4 door, but I swapped in the 3.6L DI V6 for fuel economy. Then I picked up a corvette body around the V8. I also swapped the body for a C2 Z28. (In short I traded it for three cars, a Corvette Z06r, a C2 Camaro Z28, and a Cadillac CTS Summer Performance package 3.6L DI with Aisin 6spd.)
Arachnyd is offline   Reply With Quote
Old 09-23-2010, 10:34 PM   #2
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
Exactly how much is it burning/are you adding every time?
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 09-23-2010, 10:52 PM   #3
KeepItGreasey
So It'll Go Down Easy
KeepItGreasey's Avatar
Drives: Camaro SS/RS
i had two different oil leaks.
you should lay out some cardboard to see if you get any drips.
KeepItGreasey is offline   Reply With Quote
Old 09-24-2010, 07:33 AM   #4
2quick
Drives: none
You can take it to the dealer for this. They have a way to check how much oil it is consuming.
2quick is offline   Reply With Quote
Old 09-24-2010, 07:43 AM   #5
stikSS
9691 & 97586
stikSS's Avatar
Drives: '10 Camaro SS and 2LT
IMO, if it's that low, you would notice blue smoke, or at least smell it often. Are you doin your own oil changes?.... If not make sure whoever is putting 8 quarts in it. A lot of folks are still stuck on the 5 or 6 quart thing.
stikSS is offline   Reply With Quote
Old 09-24-2010, 09:42 AM   #6
steverc
steverc's Avatar
Drives: 2011 2LT RJT V6 AT
At about 1200 miles my oil level dropped from near the top of the stick to the low end of it in a few weeks. Dealer put in 3/4 qt. brought it up to full. Ive got 2400 miles now and the oil level is still on full. I did change my oil at 1900 miles. Sort of wierd but it seems ok now.
steverc is offline   Reply With Quote
Old 09-24-2010, 09:47 AM   #7
Entaille
Drives: 2011 Camaro 2SS/RS
new engines typically burn a little oil. this should stop after a few thousand miles, maybe not entirely, but not enough to where you should have to add oil between changes (doesn't mean you shouldnt check to be safe!)
Entaille is offline   Reply With Quote
Old 09-24-2010, 02:26 PM   #8
Mark Myles
Mark Myles's Avatar
Drives: 2010 2SS/RS IBM / Silver Stripes
This was my first thought.....
M
Mark Myles is offline   Reply With Quote
Old 09-24-2010, 03:21 PM   #9
The Stig
knows 2 facts about ducks
The Stig's Avatar
All I have to say is glad I have a catch can. It may not be a lot of oil but it saves a decent chunk from going back into the engine.
Click to view my build thread
Old 09-24-2010, 03:30 PM   #10
13 ZL1
13 ZL1's Avatar
Drives: 2013 IOM ZL1
I dump about 1/4 cup out of my catch can every 400 miles.
13 ZL1 is offline   Reply With Quote
Old 09-24-2010, 03:56 PM   #11
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
there is a gm bulletin for this,, they have a new valve cover and also all the gm dod/afm engines have a bulletin for a new shield to go over the afm pressure relief valve in the pan to stop oil from spraying onto the crankshaft then to the bottoms of the pistons/cylinders and a de-carbon procedure to clean the pistons/ rings from this oil/carbon build up.
Old 09-25-2010, 12:39 PM   #12
obe1
obe1's Avatar
Drives: 2010 2SS/RS M6 IOM, 1995 Blown Z28
I drain about 6 oz from my catch can every 3,000 miles.
2010 2SS RS M6 Inferno Orange Metallic
1995 Z28 - blown, intercooled and nitrous injected
obe1 is offline   Reply With Quote
Old 09-25-2010, 09:54 PM   #13
BLACK10
BLACK10's Avatar
same here, even more with the cam
Old 09-26-2010, 03:48 AM   #14
2010SSRSM6
2010SSRSM6's Avatar
I had a leak from my oil pan gasket and oil cooler. It wasn't enough to cause a drip, but when I took it to the dealership for an oil change, while it was on the lift they saw that it was covering everything under my car back to the trans.
It wouldn't hurt to have them take a look at it. Its covered.
2010 Camaro V6 Oil and Oil Filter Change azamazonqueen Camaro DIY & HOW-TO instructions & discussions 116 03-19-2017 02:36 PM
Can we use the catchcan made for the G8? HaZe_X Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 05-05-2010 11:35 AM
synthetic motor oil? bigd1276 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 71 01-29-2009 01:28 PM
