Old 09-23-2010, 10:02 PM   #1
LSU/LS3
Drives: Inferno orange
What do you guy thin of this CAM??
So finally pull the trigger and bought a cam from thunder racing. I have ARH full exhaust ,LMR intake (for now),underdrive pulley and tune from EPS. The cam I went with is 223/236, 610/607, 115 lsa. I am new to cams so I was wondering if anyone else is running some thing like this?If so post a video clip.
LSU/LS3 is offline   Reply With Quote
Old 09-23-2010, 10:07 PM   #2
motorhead
Drives: POS MOPAR
Your running a 610 lift cam in a without any bottom end upgrades?
Man, I guess I'm out in left field with these new cars if that's a good pick for a pretty much stock motor. although the duration isn't that wild.
Old 09-23-2010, 10:08 PM   #3
advfire
advfire's Avatar
Drives: 2010 SS Black
let me tell you it's a hole crapload of fun
power power and more power
you might not like a rough idle
2SS- M6 - 849 RWHP, 757 RWTQ - YSI -Supercharger - Comp Cams Stage 3 Blower Cam -54-471-11 - (In-239/624 - Ex 255/624)
MTI - CAI - Meth Injection Systems using 50/50 mix - Kooks 1 7/8" Headers with 3" catted X-Pipe - Kooks muflers to tips - LSR Short Throw Shifter -
NGK TR6 Spark Plugs - 160 degree thermostat - LSR Sway Bars (Front & Rear) - BMR Subframe Connectors bolt-on - DSS - lingenfelter 9" w/ 4.10P - PFADT coilover front/back - BMR Spherical Toe rods / Trailing arms - Posi lock -
advfire is offline   Reply With Quote
Old 09-23-2010, 10:47 PM   #4
LSU/LS3
He said I can expect around 460+ rwhp with this cam. So i went ahead a order the bmr trailing arms and the toe.To help get that sixty foot down.
Old 09-24-2010, 12:26 AM   #5
cool
Old 09-24-2010, 05:45 AM   #6
JUISSD
JUISSD's Avatar
Drives: 2010 White/IOM 2SS/RS M6
The LS3 can handle that much lift and more no problem. Just need a spring upgrade. I can't wait to get my cam.
2010 White/IOM Camaro 2SS/RS M6
JUISSD is offline   Reply With Quote
Old 09-24-2010, 09:27 AM   #7
motorhead
Drives: POS MOPAR
That's pretty wild. I only deal with old cars when it comes to internals. That's pretty amazing to me that a stock motor will run good with that kind of cam.
These truly are good times for motorheads.
Comp cam Dyno, 497rwhp stock heads Ovenmitt Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 101 05-26-2011 07:49 PM
Step by step instructions cam install LS1 Onetime Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 06-04-2010 11:14 AM
MAST Cam - expected a little more... RickyTheStorm Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 03-15-2010 12:04 PM
Don't Be That Guy The_Blur Off-topic Discussions 13 02-03-2010 01:28 PM
LG g6x3 or Super Charger Cam!!! Your Thoughts Mr. Brownstone Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 30 01-24-2010 02:45 PM
