GM Parts House
Old 09-23-2010, 09:51 PM   #1
NewGen
NewGen's Avatar
Drives: 2013 Camaro ZL1
Send a message via AIM to NewGen Send a message via MSN to NewGen
Best Cam
Im thinking about going with a cam but i cnt seem to find one with a very light idle/lope. I dnt really like the rouge lope of the bigger cams.
Can someone tell me what would be the best cam(spec wise) for wat im lookn for?
Thanx in advance!
Young Man wanting Big Power
NewGen is offline   Reply With Quote
Old 09-24-2010, 10:48 AM   #2
J-Rod6410
M6 10 second club
J-Rod6410's Avatar
Drives: A 4000 Lb BeaSSt
I'm running a BIG cam and my tuner was able to make it idle without the lope
But we were playing with a hesitation on take-off and tried that with a few other things.I love the lope so we kept playing with it till we got the lope back and deleted the hesitation.
All in all, I think the lope has alot to do with the tune, not just the cam.
I know ADM has a stage 1 cam that they say idles like stock, but only gives you about 20 rwhp
TEAM LS3 Best pass: 10.49 @ 135 with M6
730RWHP 650RWTQ ECS S/C stock bottom end, 4L80, 9"
Built by: J-Rod.... Tuned by: Matt Sorian @ FSP (floridaspeedandpower.com)
Check out my youtube channel: http://www.youtube.com/user/6410Jrod
Follow me on Instagram: @J_Rod6410
J-Rod6410 is offline   Reply With Quote
Old 09-24-2010, 11:08 AM   #3
NewGen
NewGen's Avatar
LMR also has a stealth cam bt they dont give the specs on it... and there is th LS9 cam nd the Lingenfelter cam
Im hope'n someone with these cams installd would have a video nd post it on here
thanx for the info
Old 09-24-2010, 03:44 PM   #4
Anthony @ LG Motorsports
Anthony @ LG Motorsports's Avatar
Drives: 1994 1LE / 2006 Z51 Corvette
Lot of different cams out there for a lot of different applications.
Figure out what you want from the car and how you want it to drive. Figure out where you spend most of your time RPM wise with the car and how it is going to end up being used. No since in putting in a huge cam that runs 5000-7000 RPM if it never gets driven there. Since your looking at a smaller cam setup, figure you should pick up 30-45 hp anyway to the tire.
As for the lope...you can get a good sounding cam, if that is what you are after that still drives nice and doesn't try and bounce your head off the window from the shake.
We have a number of smaller cams, even one we dubbed "The Executive" because of our Corvette customers that wanted almost no lope at all but wanted to pick up power. In our range of cams, I would look at the G6X1 or G6XE.
What are your end goals for the car?
Anthony @ LG Motorsports is offline   Reply With Quote
Old 09-24-2010, 04:59 PM   #5
toehead93
Drives: 2014 2SS/1LE
Do you have an LS3 or L99?
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 09-24-2010, 05:03 PM   #6
NewGen
NewGen's Avatar
L99
as for the power range between 500-600 at the wheels
im trying to decide on a tt or a supercharger as well so that also plays a big role. headers, exhaust, cai
Old 09-24-2010, 05:30 PM   #7
Originally Posted by NewGen View Post
L99
600 rwhp on a L99/A6 car you are for sure going to have to do some kind of forced induction if you are staying stock displacement.
Plan on a transmission build with that as well
Old 09-24-2010, 05:45 PM   #8
NewGen
NewGen's Avatar
between 500-600 at the wheels not neccessarily 600rwhp...i wud b jus fine with the 500-550 range... i had an '01 Mustang GT with 500 at the wheels but ive read that within the range im lookn for the tranny nd drivetrain will hold up
Old 09-25-2010, 09:31 AM   #9
JS
JS's Avatar
Drives: 2010 Camaro SS
We have used a cam that sounds real nice but has real good street, cold start manners and has made 40 more RW once headers, exhaust and cold air were installed.
The whole setup is good for 70RW total...
Its not a big cam but sure acts like one
Spec are 224-236 611-621 114LSA
We have Comp grind it on LSL lobes, we call it the "cam of the man"
We have made anywhere from 470 to 710RW with it, it flat out works...
Only 2 degree's of overlap, easy to tune and make great powa
SOLD
2010 Camaro 1SS/A6
12.59@111.31
Magnaflow Magnapack Axleback & Resonated X-Pipe/OBX LT Headers/Airaid Cold Air Kit/Injection Connection Tuned
JS is offline   Reply With Quote
Old 09-25-2010, 10:37 AM   #10
sspaul
sspaul's Avatar
Drives: 2010 ss camaro, imperial blue
Send a message via AIM to sspaul Send a message via Yahoo to sspaul
go with the ls9 cam, ported heads, and a s/c or tt, will get you in your power range. also as mentioned need to beef up transmission and rearend, and i would also install a stall.
my youtube
my facebook
www.myspace.com/1djchampagne
www.twitter.com/1djchampagne
mods: borla long tube headers, borla atak catback, lingenfelter gt-9 cam, ported heads, ecs base kit running 11 psi on top end, 1" bmr drop spring, aam 3.70 gears, ported throttle body, 160* thermorstat, lethal racing tune
750/641 rwhp/rwtq
sspaul is offline   Reply With Quote
Old 09-25-2010, 10:57 AM   #11
JS
JS's Avatar
Wouldnt waste the money on a LS9 if u are staying NA.
Boosted its not a bad cam.
SOLD
2010 Camaro 1SS/A6
12.59@111.31
Old 09-25-2010, 11:59 AM   #12
NewGen
NewGen's Avatar
Damn
Old 09-25-2010, 12:00 PM   #13
NewGen
NewGen's Avatar
Thanx for the advice...its jus goin to be a street car nothin ima do alot of racing in...im 19
Cam basics CamaroSpike23 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 76 11-25-2015 11:42 AM
Vector Motorsports Stage 2.5 cam kit installed! pics and video topgun1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 38 12-18-2010 10:28 PM
Finally--VMS Stage 2.5 cam Dynojet results, nice gains! topgun1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 32 11-25-2010 09:55 AM
VVT Cam Specials! yyz28 Engine Internals 17 10-18-2010 11:29 PM
L99 TVS 1900 + Cam Dyno #'s ARE IN pharmd Forced Induction - V8 35 09-07-2009 04:36 AM
