Cold Air Inductions
Old 09-24-2010, 01:16 PM   #1
Etherij
Etherij's Avatar
Drives: 2010 Camaro 1SS LS3
Muffler delete pipe size
I talked to a local muffler shop just a few minutes ago and he said he'd do a muffler delete for $100's and use the same stock tips. However, when the size of the pipe came into question, he said he can only bend up to 2.5 inch pipe and asked me if I wanted to go with 2.25 or 2.5. Any recommendations?I was really hoping for 3 inch pipes 'cause I have future diabolical plans for my motor, but I guess it won't happen... yet. Thanks guys
TEAM LS3!
Mods so far:
JBA Catted mid-pipes
Flowmaster AMT
Etherij is offline   Reply With Quote
Old 09-24-2010, 01:19 PM   #2
CamaroCowboy
CamaroCowboy's Avatar
Drives: 2013 Chevy Truck
where are you located?
Texas speed LT Headers and High Flow Cats, Magnaflow 3 inch cat-back Exhaust, SNL V2 Comp CAM, Texas Speed Underdrive Pully, G5CR CAI, Hurst Short Throw Shifter, JetFlo Mass Air Sensor, Custom Grill, Amber AAC Headlight and Fog Light Halo, Amber footwell Lighting, Amber under hood lighting, RK Sport Ram Air /Heat Extractor Hood and ADM Racing Scoop. 447.9 RWHP 428 TQ
My car is exactly that, No one has to like it but me!
CamaroCowboy is offline   Reply With Quote
Old 09-24-2010, 01:22 PM   #3
CamaroCowboy
I say call around and try to get the 3"
Old 09-24-2010, 01:30 PM   #4
Etherij
Etherij's Avatar
Victoria :/ well the shop I went to is the only decent shop around here that has experience working with high horsepower cars. (2002 z28 w/ 800hp ALL motor and many more) but I waaaant 3 inches. :( and the other shops NEVER listen to what people want
TEAM LS3!
Mods so far:
Flowmaster AMT
Old 09-24-2010, 01:37 PM   #5
CamaroCowboy
ahh ok.....check with the San Antonio or Huston guys to see what they recommend. It will be worth yorur while to drive a little farther and get what you want. I had to drive three cities away to get mine done.....Worth it.
Old 09-24-2010, 03:00 PM   #6
caverman
caverman's Avatar
Drives: '69 SS Convertible
No...you'll need 2.5".
The factory exhaust is 2.5" and there would be no advantage at all with adding about 2' of 3" pipe.
If you want a 3" system then buy a 3" cat-back....which BTW wouldn't techically be a true 3" because the inlet would have to be 2.5" to hook up to your factory mid-pipes.
Build Journal
muffler delete with xpipe and no resonators, first imprseeions caper Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 07-05-2011 05:41 PM
Question for those with muffler delete daphatgrant Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 27 10-26-2010 05:27 PM
Sound difference between muffler delete and Loudmouth? jag107 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 14 03-11-2010 09:38 AM
Muffler Delete + X-pipe = Cost? Cooper2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 03-06-2010 03:36 PM
Muffler Delete with Dyno clips and pictures KK2010SS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 07-26-2009 03:09 PM
