BORLA
Old 09-26-2010, 01:51 PM   #1
InfernoL99
InfernoL99's Avatar
Drives: 2010 Camaro SS L99
Cam questions
Hello everyone, I'm new member here and sorry I didn't introduce myself yet but I'm about to buy a cam tomorrow and I need your advices .
I have 2010 Camaro SS L99, and this is the cam I will install:
http://www.compcams.com/Company/CC/c...csid=1092&sb=2
Questions:
-Do I need to upgrade springs/push rods/retainers/rocker arms???
-Do I need to changer timing chain? Is it a must for every cam swap??
-Do I need to install hydraulic lifters?? I don't know what type of lifters in 2010 Camaro .
Sorry this is my first time I install a cam so any advice is appreciated.
InfernoL99 is offline   Reply With Quote
Old 09-26-2010, 04:22 PM   #2
InfernoL99
InfernoL99's Avatar
anyone? ^^
Old 09-26-2010, 04:41 PM   #3
blake-b
blake-b's Avatar
Drives: Black 2010
InfernoL99, give it a little time, it has only been little more than 2.5 hours since you posted. It is Sunday in the USA and most people are off work and doing various things, such as watching football. It is nice where I am at and I would bet people are outside. I have noticed since I have been a member here that posting counts are less on weekends than throughout the week. I surmise a lot of surfing camaro5 gets done at work... I am at work and can't go to the link you posted because it is blocked. I can get to camaro5 obviously...
That depends on the new cams specs. The vendor should be able to tell you. Depending on the lift of the new cam, it may need new springs. You could probably use the stock retainers, locks, and seals if they don't have too many miles on them. They are cheap insurance though. You don't need to replace your rocker arms.
This I don't know. I think it would be at least be partially dependent on how many miles are on the original one.
The stock cam in your camaro is a hydraulic roller cam. It has factory hydraulic roller lifters already in it. There is no reason to replace yours if they aren't broken.
You'll have more answers before the day is over.
Old 09-26-2010, 05:08 PM   #4
trudawg660
Drives: 2006 Dodge Charger / 2SS IOM
the lifters will have to be replace because he has the L99. the AFM lifters wont be able to take it.
trudawg660 is offline   Reply With Quote
Old 09-26-2010, 05:37 PM   #5
blake-b
blake-b's Avatar
Drives: Black 2010
True, I missed the L99 part.
Old 09-26-2010, 08:27 PM   #6
matt d.
matt d.'s Avatar
Drives: 1998 Z28
Yes you need to upgrade the springs with that cam. And I would not use the comp 918's
The lift in the cam, really has nothing to do with the springs specs other than what your coil bind ht. needs to be. I like to set my springs up as tight as I can sometimes as close as .040"- .060" with non anti pump up lifters. The seat pressure on that cam I would want no less than 135lbs. But I like as much as I can get with hydraulic cams.
matt d. is offline   Reply With Quote
Old 09-26-2010, 09:16 PM   #7
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
Try mast motorsports, texas speed, Jannetty racing or ADM performance cam packages. I would also go with a DOD delete (if going with a VVT cam) or a full LS3 conversion.
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 09-26-2010, 09:27 PM   #8
Supercharged SS
Drives: 2010 Camaro
Jannetty is currently installing an LS3 conversion on my L99 after we had one of the stock lifters fail. There was no way I wanted to put that stuff back in after what happened. He's using one of his blower cams so by the end of the week I should have it back. I'm curious to see how much of an improvement it is going to make.
Finally--VMS Stage 2.5 cam Dynojet results, nice gains! topgun1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 32 11-25-2010 10:55 AM
A few questions about cams, headers and exhaust. Oxtar41 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 15 09-15-2010 08:11 PM
Parts needed for a DIY cam install and estimated cost? robertway Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 08-09-2010 10:06 AM
Going Cam Only (cam experts help!) SS 376 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 05-01-2010 11:00 PM
New Cam!!! getarz4u15ster Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 36 04-27-2010 07:40 AM
