| Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions |
Thread Tools |
Firefighter / Paramedic
Drives: 2010 Camaro SS/RS Join Date: Oct 2009
tuners' advice wanted.....meth injection ...should i or not?
Okay...i am looking for some info as far as which systems to run....I mainly want a tad more HP and a little insurance for my motor....I have read a lot about them and are down to Alky , Coolingmist and Snow. I want something that is fool proof and low maintenance. I want a trunk mounted tank. I have thd Maggie with 3.6 pulley, long tubes with high flow cats, boost a pump. Put down 536 rwhp last dyno. I want something I can run with pump gas. I don't wanna hear from the manufacturers because they tend to be a little biased (please dont get angry)......please educate me which way to go.
2010 IOM SS/RS LS3, Hennessey HPE550 Polished Magnuson TVS2300 Supercharger
Drives: 99' Camaro 404 TT Join Date: Sep 2010
Meth is a great way to go... Helps in everything across the board, power gain, lower your IAT's and safer on the engine.
Meth os only 1/2 the battle, The added timing can be had as well with the cooler dense air charge, and even gain more power. I only recommend you do not have your tune be "meth dependent", unless you have a wide band and monitor your A/F ratio's all the time... If you tune your car to rely on the meth to spray to provide you with the proper a/f, and avoid knock with your added timing, your putting your faith on a secondary system that could fail, via fuse blow, or meth run empty, or pump fail, and you would not know your running lean... For your power level use the 625ml jet or the #6 I believe on the Snow kit, and take advantage of the added power the meth can provide, but also tune it so that (just in case) the meth does not spray, you'll still be safe and ok with your tune when you go WOT. Just my 2 cents and my personal experience. Good luck Clint |
#3 | |
Yeah, My tune is from Jannetty Racing, and I dont want to NEED to have it so I wont tune for it at all times.......I will probably be buying my kit from him if it is one that he carries. It has a fairly conservative tune now and the 536rwhp last time was on a fairly humid day so the lower AIT will help also. Thanks for your two cents!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro Join Date: Feb 2010
I would def do it. If not for more power but just the added insurance for your engine. That's the most important attribute to me. Then you get the ancillary stuff, like lower iat's and ability to throw some timing at it. For what little it costs, it's a no brainer. Have Ted hook you up!
9.80 @ 139.73, 1.45 60', 2010 Jannetty Racing L99
Simple answer is yes you should. It's not all about the increased HP (which you can expect (+25-40) with Meth injection but as you said protection for the rest of your engines parts. Running the Snow system with all the protection with safeinjection, bypass solenoid, and gauges and LED's for meth level, flow, and system power.
Trunk mounted 2.5 gal tank and all interior gauges and LED's mounted in the center console. Love it! |
#6 | |
Awesome! PIctures of your setup?
#7 |
Drives: 2010 camaro Join Date: Sep 2010
Why wouldnt you run a meth set-up if you could?
#8 |
I DO plan on running one...just trying to figure which certain one that I need and which ones are proven performers......I do NOT want it to fail and blow the motor.
#9 |
![]() Drives: Anything Blown Join Date: Aug 2010
I know you don't want to hear from us, but I don't have anything bad to say...
So here it is, Meth isnt bad as long as it is not ran through the blower(and properly tuned). And what the above posters have said. I just wanted to throw that in. We have a set of rotors here that had meth sprayed through them (im sure with a meth dependent tune) and there is ZERO coating left on them.
805-910-7267 - cell 818-998-1975 - shop Email! ..and more | Stainless Works | Squash | ID | RX | GForce | Lingenfelter | Roto-Fab | Your one stop shop & Ebay store! Last edited by Jessika@SCC; 09-27-2010 at 02:13 PM. |
#10 | |
so as long as i put the injector before the throttle body, I would be okay?
#11 | |
![]() ![]() ![]() Drives: Maggie blown LS3 vette Join Date: Aug 2009
. No change in boost. You don't get the increased octane with the WW fluid, but you do get a cooling effect. Jessika, is the coating different on the MP blowers vs the TVS? Or, for that matter, are the MP rotors even coated? |
#12 | |
![]() Drives: Black 1SS Join Date: Apr 2009
And how would you accomplish this with a top mount supercharger like a Maggy, KB or Whipple?
#13 |
![]() Drives: 2010 2SS/RS Black on black Join Date: Mar 2010
Yeah, what he said.
#14 |
Drives: 1999 Trans Am Join Date: Jul 2009
As said above. Magnacharger does not recommend meth because it can eat the rotors from what I'm told. We've installed alot of kit's on maggie cars but it can void the warrenty of the blower itself. I would still meth it.
On the other hand,some other blowers do not get affected from meth like centrificals because it's sprayed after the blower. I know for a fact Kenne Bell does warrenty the blower with meth.They told me I could dump as much methenol as I wanted through it. Either way, a good methenol kit will work wonders.We've done a bunch of them which live life on methenol,dual nozzles maxed out and have never seen an engine failure from it. |
#15 |
This is an extreme example of your blower on meth.
![]() ![]() Because our rotors are zero clearance, the rotor finish is very important. As far as how you should go about meth injection, I've got nothing. I suggest homework & research. Just like modding your car while under factory warranty, you may need to pay to play... same goes for the supercharger. Just because it voids your supercharger warranty doesnt mean you will gain no benefit from it. But, beware that the benefit may come with a cost.
805-910-7267 - cell 818-998-1975 - shop Email! ..and more | Stainless Works | Squash | ID | RX | GForce | Lingenfelter | Roto-Fab | Your one stop shop & Ebay store! |
#16 | |
PRESIDENT CALIBRATOR JRE
![]() Drives: YELLOW 2013 ZL1 AUTO Join Date: Jun 2009
What vehicle was this on? How Many Miles? How Much Blower Overspeed was involved? Did the supercharger Fail as a Result of the coating coming Off? The rotors appear to be fine otherwise. Was it sprayed with Straight Meth or Water Meth? What is the Coating on the rotors made of? Does this Apply to Current Production Magnachargers? I would think that Gasoline would have the same affect on this particular coating since it has Ethanol in it if it were Carburated. Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs! Ted Jannetty Jannetty Racing Ent Inc. 2984 East Main St. Waterbury Ct. 06705 203-753-7223 tedj@jannettyracing.com www.jannettyracing.com www.turboaddictionparts.com Performance Parts |
#17 |
Probably a TVS. I'm sure it's not an early MP112. I don't think even the MP112HH/MP122 rotors have that much twist. One thing to consider is that even though you may lose a little coating, the fluid injected is going to take up a bit of the extra clearance
The only time you need a good seal is when you're under boost. My Snow system starts coming in at 4psi and is full bore at 6psi. I probably have 60K+ on that MP122. I've been spinning the snot out of it from day one. Started with a 2.8" pulley and more recently a 2.6".
#18 | |
#19 |
Ted, It happens to alot of the Magnachargers with anykind of methenol solution.Seen alot of those throughout the years.
I would figure since alot of people run methenol kit's now and the Magnacharger definitely benefit's from it that someone would come up with a coating that doesn't get affected by it. |
#20 |
Since I don't have the answers to the questions, I passed this to Jon. Hes been buried in work today and says he will answer ASAP. He is the one that shot the pictures of the blower.
Sorry guys... but we will get you answered!
#21 | |
Drives: 2008 Chevrolet 2500HD Join Date: Sep 2009
But I will tell you, methanol itself, is highly corrosive, and if it gets to a certain mixture of oxygen, water and meth, it will turn to acid and eat everything in its path. As long as the motor runs for a moment with the meth system off, this will not be a problem, but I've seen some systems that don't have check valves and during vacuum (idle, shut off, highway), it will suck the water/meth from the system and then when you shut the car off, it will sometimes eat chunks of material. So just make sure you run a check valve so you don't get any leakage. |
#22 |
Banned
wow this is eye popping, what about just straight water inj..i have of this before also
#23 |
![]() Drives: c Join Date: Feb 2010
do centrifugal blowers like vortech have this issue?
#24 |
#25 | |
Not trying to scare anyone.I recently pulled apart a C5R 427ci we built 5 years ago.Ran 14lbs of boost from a procharger and went through an easy 20-30 gallons of 100% methenol. There was no damage to the aluminum parts of the motor and the pistons/valves looked new from the methenol. We also always run check valves so it doesn't siphon. I'd say it's safe to everything except maybe the maggie rotors. |
| Thread Tools | |
| Water Meth Injection Q & A, lets talk CMGS from Coolingmist! | coolingmist | Forced Induction - V6 | 17 | 03-22-2012 05:52 AM |
| DIY - Meth Injection Install | FASST 1 | Camaro DIY & HOW-TO instructions & discussions | 20 | 02-16-2012 04:00 PM |
| Water/Meth Injection choices | benjj | Forced Induction - V8 | 39 | 07-21-2011 09:50 PM |
| PERRIN Performance Water/Methanol Injection Kit | PERRIN_JOHN | Forced Induction | 4 | 03-17-2010 09:57 PM |
