Old 09-27-2010, 04:06 AM   #1
BoostedX2
BoostedX2's Avatar
Drives: VR ZL1 #259/Nissan 370Z NISMO
IT HAPPENED TO ME!!
Well, last week I added GMPP exhaust and JBA Cats to my car that along with the Roto-Fab intake are the only mods that I have related to the engine (I also have a Barton Shifter, 4.10 Gears, and some Pfadt sways and Hotckiss max brace). The car ran great, seemes like a lot more power, no check engine light.
So I went to start it yesterday and the DIC said "NO OIL PRESSURE"!! WTH?? Tried it again, same thing, so I called to have it towed to the dealer. What could have happened? Will it be covered under warranty? What do you guys think??
Thanks!
BoostedX2 is offline   Reply With Quote
Old 09-27-2010, 04:14 AM   #2
trudawg660
Drives: 2006 Dodge Charger / 2SS IOM
i really doubt they can prove a CAI could cause that problem
trudawg660 is offline   Reply With Quote
Old 09-27-2010, 04:31 AM   #3
tbss1
More then meets the eye!
tbss1's Avatar
Drives: 2010 Camaro 2SS/RS 426 hp
Keep us up to date.
2010 2SS/RS, OBX l/t headers, with high flow cats, MBRP full 3" exhaust, modified air intake (CAI), Richman 4.10 gears, BMR toe rods, trailing arms, f/r sway bars, f/r sway bar end links, BMR end link brackets, full BMR poly bushing including solid rear cradle bushings, BMR frame connectors and tunnel brace, f/r Hurst swaybar bushing brackets, Fluidampr 25% upd, MGR shifter, VTC, and tune by Jannetty Racing. MRR M228 rims, phantom grill, vinyl wrapped hood and rear spoiler.
tbss1 is offline   Reply With Quote
Old 09-27-2010, 05:55 AM   #4
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Thanks!
Don't let them push you around, they will probably try.
Old 09-27-2010, 06:22 AM   #5
fielderLS3
fielderLS3's Avatar
Drives: 2016 Mazda6, 2011 Mustang 5.0
Does the gauge show no oil pressure as well?
"Proven V-8 power with better efficiency than a turbo V-6"
"The car is the closest thing we will ever create to something that is alive."eds.
fielderLS3 is offline   Reply With Quote
Old 09-27-2010, 06:33 AM   #6
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
CAI would not have anything that could effect that. I would say the CATS should not either but changing the CATS I was warned on by Ted would let GM void your warranty.
Scott@Bjorn3D is offline   Reply With Quote
Old 09-27-2010, 06:50 AM   #7
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
The rear end could screw you ...
Old 09-27-2010, 06:59 AM   #8
BoostedX2
BoostedX2's Avatar
The gauge also read zero, how would they know the rear end has been changed?
Old 09-27-2010, 07:33 AM   #9
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
You'll be fine. They should change out the sensor and you'll be on your way unless your dealer is an ass..
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 09-27-2010, 08:06 AM   #10
acowherd
acowherd's Avatar
Drives: 2010 2ss/RS 4l80. 2009 2500 HD
I bet the oil pump is bad..not a sensor. Had the same thing happen!
Follow along as we build and race this 2010 Camaro!
https://www.facebook.com/pages/FNSS-...75028626000379
FNSS Racing!
acowherd is offline   Reply With Quote
Old 09-27-2010, 09:16 AM   #11
3min3m2
3min3m2's Avatar
Drives: 2011 2SS/RS SIM L-99
There is a tsb out on the oil pump iirc.
3rd Time is the charm
2012 2SS/RS VR 6M.
Borla S type, Volant CAI.
3min3m2 is offline   Reply With Quote
Old 09-27-2010, 09:31 AM   #12
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
This, get the TSB number and give it to your service department or tell them about it and they can look it up.
Old 09-27-2010, 09:40 AM   #13
BoostedX2
BoostedX2's Avatar
I found a PIP4158C on it--is there also a TSB? I did let the dealer know the number--I am hoping I don't get any pushback from the dealer with the hi-flo cats and CAI...
Old 09-27-2010, 09:54 AM   #14
moiy1983
moiy1983's Avatar
Drives: 2010 camaro ss/rs
i had this happened to me. i have way to many mody to even consider the dealer i am having to pay out of pocket! so long story short i am puting a HKE 416 engine in mine. its gonna be a killer car but the timming wasnt that good to be doing this now!
moiy1983 is offline   Reply With Quote
HEY, GUESS WHAT HAPPENED billmiller8 5th Gen Camaro SS LS LT General Discussions 4 02-20-2010 07:07 PM
Accidents: What happened after. Dboy23 5th Gen Camaro SS LS LT General Discussions 11 12-16-2009 09:38 AM
It finally happened to me..... Sir Nuke 5th Gen Camaro SS LS LT General Discussions 4 09-20-2009 10:16 PM
What happened to my Camaro at the dealer? OHIOSS 5th Gen Camaro SS LS LT General Discussions 35 08-03-2009 08:44 PM
