JUICEDMOTORSPORTS
Old 09-27-2010, 12:25 PM   #1
mulletman
Drives: 2017 Camaro SS
Foam seal on air intake
Can anyone explain the foam seal on the air intake on the LS3? It does not seal against anything.
mulletman is offline   Reply With Quote
Old 09-27-2010, 03:31 PM   #2
FRANK121
FRANK121's Avatar
Drives: 2011 Camaro SS
I noticed that too, and it doesn't appear to get air from the front of the car/grill?
FRANK121 is offline   Reply With Quote
Old 09-27-2010, 03:41 PM   #3
obe1
obe1's Avatar
Drives: 2010 2SS/RS M6 IOM, 1995 Blown Z28
Air is routed through the front grill; there's a sheet metal panel that directs air hidden under the front facia
2010 2SS RS M6 Inferno Orange Metallic
1995 Z28 - blown, intercooled and nitrous injected
obe1 is offline   Reply With Quote
Old 09-27-2010, 03:46 PM   #4
Russell James
Russell James's Avatar
Drives: '69 Z28, '10 NASA TA2, '15 1LE SS
Location: In the garage fixing stuff, track breaking stuff, at work paying for stuff. Or check the bar.
I'm guessing engineer A wasn't communicating to engineer B.
Most vehicles that seal, seals off underhood heat from the intake. I have an 09 Silverado where the intake tube goes into the inner fender behind the headlight. It has the exact same style of seal around the tube and it firmly presses up against the sheetmetal - factory CAI.
Someone mucked up.
Old 09-27-2010, 05:57 PM   #5
Kulo
Kulo's Avatar
Drives: Silver Ice Metallic SS
This is an unrelated thread but the 2nd picture with the exposed radiator shows the plastic mate to the foam tube on the intake side. The black plastic tube like thingee next to the drivers side headlight is it. The top is a open tube ,which draws the air in.
http://www.camaro5.com/forums/showth...ighlight=TURBO
JBA High Flow Cats, CAI Intake, Ported Throttle Body, Pfadt Sport Sway Bars, 12.57 @111.6 mph
Kulo is offline   Reply With Quote
Old 09-27-2010, 06:05 PM   #6
SlowSS
SlowSS's Avatar
Drives: 2013 Camaro 2SS/RS 1LE
I was wondering the same thing. Glad to know I'm not the only one.
I've only had my car for a couple of weeks.
SlowSS is offline   Reply With Quote
Old 09-27-2010, 06:08 PM   #7
My 5th
My 5th's Avatar
Drives: 2010 2SS/RS M6 Black on Black
My guess is the gap is caused by over enthusiastic production tolerances. It's cheaper to design the snorkel too short for the production process than to have to cut it shorter on the assembly line. Most of us would say "Measure twice--cut once" GM apparently said "Measure once--it's cheaper"
Meh
My 5th is offline   Reply With Quote
Old 09-27-2010, 06:49 PM   #8
BigRed585Lbs
Drives: Sierra and Tahoe
"I cut the damn thing twice, and it's still too short!"
BigRed585Lbs is offline   Reply With Quote
g5cr cai system anybody install or looking at one "pics" camarossrs2150 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 07-14-2011 09:26 PM
RAM AIR MYTH OR TRUTH JANNETTYRACING Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 30 06-19-2010 12:41 AM
Why RAM Air is a myth!!! Long Read (Wall of text) live2well Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 80 11-02-2009 04:34 PM
