Old 09-27-2010, 01:12 PM   #1
MTI Racing Kevin
MTI Racing Kevin's Avatar
Drives: 2010 Camaro
LS7 Swap
For all you guys planning to do an LS7 swap into your Camaro MTI Racing has what you need to adapt the oiling system. When ever you do a swap like this you never know where everything is going to end up so you need some versatility. If you are using the dry sump oiling system in your conversion you may have to put the tank in a location so the stock length lines will not reach or just cannot get to. If you use this adapter you can make the lines as long as you will need them. This adapter can be used on the pan or sump tank to convert to a -12 fitting.
For example...
If you want to use a factory oil pan and upgrade the sump tank to an aftermarket unit, this adapter converts your oil pan to -12 oil lines.
If you bought an aftermarket oil pan (ARE, etc..) and want to maintain the stock sump tank, this adapter converts your factory sump tank to -12 oil lines.
The adapter is made from billet aluminum with oring fittings and is suitable for racing and street environments.
These fittings will give you the flexibility you will need with the LS7 swap.
All the parts and pieces
Assembled and ready to install.
Installed on the pan
The same adapter fits the tank also
MTI Racing Kevin is offline   Reply With Quote
Want to engine swap. LS7 or LSX better option? ls7camaro Forced Induction - V8 50 02-13-2013 10:39 PM
LS7 Camaro on eBay starting at around 60k! x7productions 5th Gen Camaro SS LS LT General Discussions 11 03-19-2010 04:54 PM
SEMA CAMARO: LS7 Camaro Tran Camaro Photos | Spyshots | Video | Media Gallery 157 10-16-2009 10:26 AM
LS7 Camaro....some assembly required Txturbo 5th Gen Camaro SS LS LT General Discussions 11 11-03-2008 01:17 PM
LS7 Swap into V6 cheaper than factory? LSxcellent Off-topic Discussions 26 03-24-2007 12:20 PM
