Cold Air Inductions
Old 09-27-2010, 08:33 PM   #1
ramsman34
ramsman34's Avatar
Drives: 2011 Summit White, 2SS/RS-LS3
Losing 5 lbs pressure every 4 days in right rear tire
I literally have to fill this one tire with 5 lbs. air every 3-5 days.
I've searched the forum and can't find anyone else with this problem. I've had the dealer check the tire and they said no leaks yet 2 days after getting it back the warning icons light up and I'm down to 29-30 lbs. I've confirmed each time by my manual pressure gauge so it's not the sensor.
I'm very frustrated. It's ridiculous having to fill my tire every 3-5 days....any ideas?
ramsman34 is offline   Reply With Quote
Old 09-27-2010, 09:06 PM   #2
thiggin2
thiggin2's Avatar
Drives: 05/07 Chevy's
How is the dealer checking for leaks? You will need to find a dealer/tire shop that has a "dunk" tank where they can submerg the entire tire. Theres has to be a leak either from the tire, valve stem or the rim itself .
thiggin2 is offline   Reply With Quote
Old 09-27-2010, 09:15 PM   #3
Number 3
Hail to the King baby!
Number 3's Avatar
Drives: '16 ATS 2.0T & '17 Buick LaCrose
You could take a bucket of soapy water and wash the wheel and tire. Look for bubbles. If you can back the car up to rotate the tire. Check inside and outside and the full tread.
5 pounds in 3 to 5 days is a very slow leak. But soapy water should result in some visible bubbles. This is hopefully what your dealer has already done, but you might be a bit more thorough and find it.
"Speed, it seems to me, provides the one genuinely modern pleasure." - Aldous Huxley Link to Every Camaro photo I've taken in Hi-Resolution
Old 09-27-2010, 10:00 PM   #4
ckaram
ckaram's Avatar
Drives: 2011 2SS RS, 1968 ragtop
Had the same problem. Took it to a tire shop, who found the nail. All is good...
1968 Camaro convertible, LS1 & T56, Texas Speed 228R cam, 3.73 posi, 17" Torque Thrusts
2011 2SS/RS, LS3, M6, IOM in and out, factory Hurst short throw, GMPP axleback exhaust SOLD! Now in a 2016 Challenger Scat Pack Shaker, M6
ckaram is offline   Reply With Quote
Old 09-28-2010, 12:01 AM   #5
Ron66Vette&10SS
Plays with Hot Wheels
Ron66Vette&10SS's Avatar
Drives: '17 Jet Black ZL1
I'm with Number 3. Check for leaks yourself with a water/soap solution.
But personally, first I'd check out the valve core itself in valve stem. Pick yourself up a $2 (if even that much) valve core tool and see if the core needs snugged down.
Previous Cars: '78 Z28, '92 Z28, '95 Z28, '85 Corvette, '01 SS, '96 Z28, '04 Z06 Corvette, '10 SS, '13 SS Hot Wheels
Current Cars: '17 ZL1(daily driver), '04 Trailblazer (rain & snow), '66 Corvette (restoring)
Ron66Vette&10SS is offline   Reply With Quote
Old 09-28-2010, 10:25 AM   #6
Russell James
Russell James's Avatar
Drives: '69 Z28, '10 NASA TA2, '15 1LE SS
Location: In the garage fixing stuff, track breaking stuff, at work paying for stuff. Or check the bar.
They probably used a water dunk tank, which is hard to see small leaks.
Soapy water as mentioned before will show the leak. Slop some soapy water all over the tire and watch for bubbles. Tread surface, bead, valve stem...
Probably a small nail in the tread. Pour the soapy water over the tread, wait and watch, pull car ahead and repeat.
Old 09-28-2010, 11:20 AM   #7
pennor
pennor's Avatar
Drives: 2011 2LT - 73 Corvette 454
I've had this problem with my 37 year old Corvette with aftermarket mags. The tires are fine but the air seeps out through a porus wheel casting. Have the dealer dunk the wheel in a tank and look for a leak, not just in the tire but in the wheel as well.
pennor is offline   Reply With Quote
Old 09-28-2010, 12:06 PM   #8
Chrisrp454
Chrisrp454's Avatar
Drives: 2010 ABM 2SS/RS M6, 98Z28 M6
Had the same thing, took it to discount tire, was a nail in the tire.
Started again, took it back, patch had came loose.
They fixed that, so far about 10 months now and no issues.
Always Remember! Rest in Peace Brothers
9/11/2001. And thanks to all those who defend and serve!
Ordered 5/23/2009
3400 with TPW of 08/03/09
3800 8/11/2009
Arrived 8/21/2009 2SS/RS/Aqua Blue/Grey Interior
Chrisrp454 is offline   Reply With Quote
Old 09-30-2010, 02:20 PM   #9
Evil35th
Drives: 02 35th Aniversary SS/'11 RJT 2SS
We had this problem on our G8, the dealer put the wheel/tire assembly in a dunk tank. It turned out that the rim itself had a small pinhole in it from the casting process. they had to replace the rim. no problems since
02 35TH LE#3089 and 2011 2SS/RS
Evil35th is offline   Reply With Quote
Old 09-30-2010, 03:03 PM   #10
firestone_ss
firestone_ss's Avatar
Drives: 2010 camaro ss
just remember once the tire is patched/plugged its no longer speed rated
firestone_ss is offline   Reply With Quote
Old 09-30-2010, 03:29 PM   #11
Dave Coyle
Dave Coyle's Avatar
Drives: 2010 SS , 1970 Z-28, 2002 Avalanche
I had a problem like that with a set of brand new rims and tires, first they broke the bead down and reseated it and that didn't work, then a new valve stem and that didn't work. The last time I went back they did the "dunk test" and sure enough, on the inside of the rim on the flat spot there was a pin hole so they ordered a new rim and replaced it, no more low tire. Have them do a "dunk test" and you should find a problem.
IF IT'S WORTH HAVING, IT'S WORTH WAITING FOR!!!! (AND IT WAS)
434RWHP/403RWTQ
Livernois Motorsports 2C Cam kit
Kooks 1 7/8 LT Headers/Hi-Flo Cats/Corsa Exhaust
Roto-Fab CAI / Port Intake
Precission 2400/2800 Converter/3.73 AAM gears
Livernois Motorsports Tune
Best time: 11.97 @ 117 MPH
Dave Coyle is offline   Reply With Quote
Old 10-22-2010, 11:43 PM   #12
Hoss
Hoss's Avatar
Drives: 2004GMC Extended Cab
Do you have Discount Tire in your area. Let them help you!
2010 2SS/RS, Black/Black, LS-3, delivered 6/19/09
Hoss is offline   Reply With Quote
Old 10-23-2010, 03:25 PM   #13
ramsman34
ramsman34's Avatar
So the dealership where I bought it said they took the tire off and tested it for leaks, found none. I take it to Power Chevrolet by my house and they find a staple in it after looking for about 5 mins. All fixed. Unbelievable that the first shop couldn't find it, IF they even looked.
2010's Sold Out ! carguy 5th Gen Camaro SS LS LT General Discussions 53 12-06-2009 02:12 PM
Tire Monitoring System monevz28 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 11-22-2009 04:42 PM
How does onstar know what tire pressure I have? FLYNNZL1 Wheels and Tires Talk Sponsored by The Tire Rack 8 08-09-2009 03:11 PM
Pedders December Dollar Days for the 2010 Camaro and Brand X Vehicles JusticePete Wheels and Tires Talk Sponsored by The Tire Rack 85 07-26-2009 06:20 PM
I think i'm done waiting. pinkcamaro10 Off-topic Discussions 332 05-13-2009 05:56 PM
