Old 04-23-2011, 06:32 AM   #393
DisneyEngineer
Drives: 2011 Camaro 2SS/RS
Ok so I'm completely baffled by this. I had the PDIM module my 2011 replaced under warranty in December 2010 and after replacement it showed DA/DX. After still having issues I decided to buy part number 20985421 because I was tired of the multiple trips to the dealer. I received the part yesterday and installed it and guess what the module in my car that was showing DA/DX had part number 20985421 on it as well. I still installed the one I had just received and amazingly enough it now shows DB/DB and the indexing is improved and shuffle on/off is now available. Can anyone explain why the same part number would have a different hardware version? The markings are identical expect for the last 2 digits of what I'm guessing is the serial number.
DisneyEngineer is offline   Reply With Quote
Old 04-23-2011, 11:45 AM   #394
kmcd
1,425 hp / supercharged
kmcd's Avatar
Drives: (2010 2SS/L99) (1999 Corvette)
I can only guess that the earlier serial numbers were programmed with the old software. They probably upgraded the software without making any physical changes to the PDIM, hence the part number remained unchanged.
Just a guess.
At any rate, congratulations on solving your issues. It certainly makes using the USB port much more enjoyable, doesn't it?
"If it's too loud...well, you know the rest."
kmcd is offline   Reply With Quote
Old 04-23-2011, 11:59 AM   #395
cmore
cmore's Avatar
Drives: 2011 Victory Red Auto 2SS
Now I am confused. I have a 2011 made in Aug and the codes are as follows:
Holding the Menu/Select button causes
HW ID: CC
SW ID: CE
to be displayed.
My software was updated about a month back so it should be up to date. But neither start with a "D".
Are the codes different for the 2010 and 2011s?
cmore is offline   Reply With Quote
Old 04-23-2011, 12:14 PM   #396
kmcd
kmcd's Avatar
That's because you have an earlier PDIM (even though your car is a 2011). Updating the software in the old PDIMs will not bump you up to the "D" codes.
You need a new PDIM.
Old 04-23-2011, 12:16 PM   #397
kmcd
kmcd's Avatar
No.
The good news for you is that you have a 2011. If you're having USB issues, all you have to do is take it to the dealer to have your PDIM upgraded under warranty.
Old 04-23-2011, 01:59 PM   #398
cmore
cmore's Avatar
It that is true, I wonder why they did not update the PDIM when I took it in last month? The software update did seem to fix the issues I had. Don't know if I need to ask for an updated PDIM.
Old 04-23-2011, 02:21 PM   #399
MARINE1991
MARINE1991's Avatar
Drives: COTW 8/29/11 2010 CAMARO
I just called the dealership and they said there was not new software or hardware for the PDIM and had no idea what I was talking about. They were like you can talk to the parts dept, as I was it covered under warrenty and they said no.. Great, lucky I dont only get problems once in a while.. they also said they checked GM to see if there was any bulletin on it and they said they could not find anything....
MARINE1991 is offline   Reply With Quote
Old 04-23-2011, 03:20 PM   #400
MARINE1991
MARINE1991's Avatar
I am willing to just buy the new part, everyone says plug and play??? I dont even know where it is located?? looked on Utube and the site to figure out how to install, but can not find anything on the install of this part.. can someone post a link or PM me.. Thanks
Old 04-23-2011, 04:17 PM   #401
kmcd
kmcd's Avatar
It's in the center console. Go to post #385 on the previous page.
Old 04-23-2011, 04:19 PM   #402
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
http://www.camaro5.com/forums/showthread.php?t=77662
Old 04-23-2011, 04:56 PM   #403
MARINE1991
MARINE1991's Avatar
Originally Posted by slick rick View Post
Thanks for the response... thats plug and play... I dont think I could do it, without messing it up... thanks again for your responses..
Old 04-23-2011, 05:16 PM   #404
kmcd
kmcd's Avatar
You can field strip an M16. I'm pretty sure you can install that PDIM.
Old 04-26-2011, 12:22 PM   #405
SummoneR
Paul
SummoneR's Avatar
I am dumb founded. I could not use my iPhone 3G with the USB at all right. I just upgraded to a iPhone 4 because the 3G just stopped working period. Anyway the 4 works just fine... Ahhh haaa lame.
Old 04-26-2011, 05:14 PM   #406
spurscar
spurscar's Avatar
Drives: 2011 CGM 2SS/RS A6
It's a beautiful thing.
Just picked the car up from the dealer - invoice says Module part # 22797218.
Car reports version DB/DD.
Random on USB is remembered even after the car is shut off (and exited) and then
turned back on. Very nice.
Now to work on stopping the "Menu -> scroll down, scroll down, Select, Back" muscle
memory every time I get in the car, haha.
spurscar is offline   Reply With Quote
Audio/Bluetooth/PDIM FAQ UCF w00t Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 148 07-08-2017 10:32 PM
How many people will E-85 their new camaro? Speed74SS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 57 01-03-2011 02:16 PM
* * * OnStar iPhone application - UPDATE * * * CamaroScotty 5th Gen Camaro SS LS LT General Discussions 142 08-11-2010 11:13 PM
Tire Monitoring System monevz28 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 11-22-2009 03:42 PM
