Cold Air Inductions
Old 09-28-2010, 06:16 PM   #1
Ronin_2SS
Loving My LS3
Ronin_2SS's Avatar
Drives: 2010 Summit white 2SS
Send a message via Yahoo to Ronin_2SS
Blew a JBA mid pipe gasket need help
Hey everyone, I recently blew one of my gaskets that JBA supplied on my highflow midpipes, due to a bolt coming loose. They are a simple 2 bolt flange type gasket with a 2.5in OD. And to my astonishment I cannot find a decent relplacement. No autozone, kragens, or pepboys seem to have anything of that nature. and my muffler guy can only find 2in OD gaskets. I called JBA and they said im kinda SOL since they come as a set with the pipes and they dont sell the gasket by its self. Anyone know where i can find a set of these type of gaskets? I tried google but i can only fine 3 bolt collector types and the 2in OD 2 bolt types... anyone know a place i order a set?
Ronin_2SS is offline   Reply With Quote
Old 09-28-2010, 06:24 PM   #2
Duflar
Duflar's Avatar
Drives: 2011 Camaro 2SS RS
Can you find the gasket material in sheet form and cut your own?
Duflar is offline   Reply With Quote
Old 09-28-2010, 06:30 PM   #3
Ronin_2SS
Loving My LS3
Ronin_2SS's Avatar
ya that was my next option. i know mr gasket makes the material, i guess i just feel more comfortable with a set already made. Its just a surprise i cant find a replacment.
Old 09-28-2010, 07:05 PM   #4
YELLOW2SS
2010 Camaro 2SS
YELLOW2SS's Avatar
Drives: 2010 2SS yellow black stripes
I can't believe JBA won't send you a gasket, free or otherwise, just seems like good business!!!!
2010 Camaro 2SS
Yellow/Black Stripes
Roto-Fab CAI
Solo Hi Flo Cats
Kicker Sub
YELLOW2SS is offline   Reply With Quote
Old 09-28-2010, 07:09 PM   #5
Ronin_2SS
Loving My LS3
Ronin_2SS's Avatar
i couldnt believe it myself
Old 09-28-2010, 07:23 PM   #6
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
ebay
Ovenmitt is offline   Reply With Quote
Old 09-28-2010, 07:23 PM   #7
Ovenmitt
Summit or jegs is also a safe bet. They stock every gasket known to man, and some made by chuck norris.
Old 09-28-2010, 08:38 PM   #8
mikeSS
mikeSS's Avatar
Drives: 2015 c7
so this happen because due to bad installation ?
Old 09-28-2010, 08:58 PM   #9
Fishdadddy
Fishdadddy's Avatar
Drives: 2010 2SS/RS ; 1970 Firebird Formula
Probably because a bolt came loose and the gasket burned through.
Fishdadddy is offline   Reply With Quote
Old 09-28-2010, 09:01 PM   #10
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Just installed JBA mid pipes and I used black oxide ARP 12 point flange ( 12mm head ) m10-1.50 X 35mm bolts with ARP stainless steel 12 point flange ( 12mm head ) m10-1.50 nuts to secure the JBA mid pipes to the BBK headers. I used modified stock GM metal gaskets ( exhaust manifold to midpipe ) P/N 92202326 with the "wire mesh" removed. Once you see the gasket you'll know what I mean about the "wire mesh" which is easily removed with a pick. Didn't like the stock JBA fasteners or gaskets. The GM metal gasket will last forever and is reusable.
Ed.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
Old 09-28-2010, 09:10 PM   #11
Ronin_2SS
Loving My LS3
Ronin_2SS's Avatar
exactly. as i stated it wasnt a bad install. all was good till a bolt came loose. I went to a shop today that deals with summit and he called his distributer and same luck, they only have 2in OD in that style of gasket. so he recommended I cut one myself which is what i may have to do. kinda odd...then again i ran into the same situation with my supra a few years back when i blew a down pipe gasket, however the company tanabe was able to replace the gasket. Not to knock on JBA at all. I love their product and I stand by it, however it does kinda suck.:(
Old 09-28-2010, 09:15 PM   #12
Ronin_2SS
Loving My LS3
Ronin_2SS's Avatar
Ed.
Interesting, I did take a look at the oem ones and at first glance i didnt think they would work. im gonna have to look again close this time. Thanks for the info sir
Old 09-28-2010, 09:19 PM   #13
13 ZL1
13 ZL1's Avatar
Drives: 2013 IOM ZL1
Does it look like this one?
http://www.summitracing.com/parts/WLK-31337/
13 ZL1 is offline   Reply With Quote
Old 09-28-2010, 09:39 PM   #14
Ronin_2SS
Loving My LS3
Ronin_2SS's Avatar
Originally Posted by Orange2SSRS View Post
Ill be damn. thats it!
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 89 02-20-2015 09:43 PM
Another JBA high flow mid pipe video Ronin_2SS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 09-24-2010 04:58 PM
Jba shorty headers and high flow mid pipe max rider Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 29 09-17-2010 01:40 AM
JBA High Flow Catted and Off Road Mid Pipes - LS3/L99 - fits stock manifolds/shortys MarylandSpeed V8 Bolt-Ons & Tunes 8 08-26-2010 03:42 AM
Exhaust manifold to mid pipe gasket flht99b Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 08-11-2010 09:48 PM
