Old 09-28-2010, 08:29 PM   #1
KevinGolshani
Drives: Camaro 2 LT
Will STS turbo work well with automatic tranny?
I have an auto tranny and am not sure how well the combination of the turbo and auto will work.
What do you guys think?
KevinGolshani is offline   Reply With Quote
Old 09-28-2010, 09:47 PM   #2
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
The r&d for the sts was on an auto I believe.
Edit: meaning it'll work with both transmissions
Old 09-29-2010, 07:34 AM   #3
jim505
Drives: 2010 Red V6 STS Turbo Installed
Yep that's what I have A6 no problems.
jim505 is offline   Reply With Quote
Old 09-29-2010, 11:26 AM   #4
xLoGiK1
xLoGiK1's Avatar
Drives: 2010 2LT/RS Camaro
have you dyno'd the car?
xLoGiK1 is offline   Reply With Quote
Old 09-29-2010, 11:29 AM   #5
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Dynos I've seen have put it at anywhere between 350-380 rwhp. Jim said his torque was 423.
[B]
Old 09-29-2010, 11:56 AM   #6
xLoGiK1
xLoGiK1's Avatar
Wow that's pretty impressive
Old 09-29-2010, 06:01 PM   #7
littleman54321
littleman54321's Avatar
Drives: Something
Turbos are usually a touch more efficient on auto's anyway, as you don't loose the boost pressure when the transmission shifts.
littleman54321 is offline   Reply With Quote
Old 09-29-2010, 06:03 PM   #8
Team STILLEN
Team STILLEN's Avatar
Drives: Varies
Plus you can stall a turbo car up against the converter to make boost.
Although watch the trans temps when you do it.
Team STILLEN is offline   Reply With Quote
Old 09-29-2010, 06:40 PM   #9
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Can stall the car up to about 2000 rpm... not sure where the STS starts making boost... Of course getting a converter loosened up a bit is usually not to terrible expensive... However with an open differential launching under boost (and staying hooked up!) might be a bit tougher..
scrming is offline   Reply With Quote
Old 09-29-2010, 07:46 PM   #10
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
With stock tires you are going to have a hard time hooking up stalling above 2000 RPM (boost or not). At 1500 RPM mine loves to spin on the stock tires :(
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 09-29-2010, 07:57 PM   #11
scrming
scrming's Avatar
Which "stock" tires do you have?
I find i get my best 60' foots flashing the converter off of idle...
of course if you are spending $$$$ for a turbo can probably afford to get ride of the stock tires! LOL! I actually have 13,000 miles on my Nitto NT555R drag radials... granted they haven't seen a lot of passes at the track but still 13,000 miles and counting is still pretty dang good... And I drive in the rain! LOL!
Old 09-29-2010, 11:31 PM   #12
GretchenGotGrowl
Pirelli PZero 245/50/ZR19. I seem to get a little better launch at 1000 RPM then idle, but it has been so hot I'm not sure if that will remain to be the case.
I'm sure glad we are out of the 100's and into the 80's
Old 09-29-2010, 11:32 PM   #13
GretchenGotGrowl
I want those tires right after the turbo!
Old 10-01-2010, 04:27 AM   #14
KevinGolshani
Drives: Camaro 2 LT
If you ever get the chance try slicks they make driving so much more rewarding
STS Turbo Install> Pics! AACstyle Forced Induction - V6 603 08-16-2014 01:04 AM
Tracking All Currently Known US VIN and Window Stickers - Order Tracking Thread UCF w00t Camaro Price | Ordering | Tracking | Dealers Discussions 4242 02-17-2014 09:57 PM
Updated - Twins almost here! - STS (Twin Turbo) Camaro SS 5th Gen SS Forced Induction - V8 249 08-19-2012 10:45 PM
STS Twin Turbo Hits the Dyno!!! ZZcamaro Forced Induction - V8 15 10-17-2009 08:11 PM
ULTIMATE PERFORMANCE* TURBO Camaro SS -- 750hp Custom Single Turbo Kit (T04Z) Ultimate Performance Forced Induction - V8 496 10-11-2009 02:29 PM
