Emblempros
Old 09-29-2010, 05:30 PM   #1
Cmlloveless
Drives: 2010 2SS RS
Port LS3 heads or invest in LS7 heads?
Just trying to figure out which would be a better way to go? (cost effectiveness)
Is is worth it to invest in CNC ported LS7 heads to swap out with the LS3's? Or am I better off just porting my LS3 heads? Either set up I go with would have new valves/springs, etc...
My plan is to get a 418ci or 427ci stroker kit(maybe), blower cam and procharger.
Cmlloveless is offline   Reply With Quote
Old 09-29-2010, 07:53 PM   #2
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
LS7 heads wont fit on an ls3.
Ovenmitt is offline   Reply With Quote
Old 09-29-2010, 08:28 PM   #3
sspaul
sspaul's Avatar
Drives: 2010 ss camaro, imperial blue
Send a message via AIM to sspaul Send a message via Yahoo to sspaul
not doubting you but why won't they fit?
my youtube
my facebook
www.myspace.com/1djchampagne
www.twitter.com/1djchampagne
mods: borla long tube headers, borla atak catback, lingenfelter gt-9 cam, ported heads, ecs base kit running 11 psi on top end, 1" bmr drop spring, aam 3.70 gears, ported throttle body, 160* thermorstat, lethal racing tune
750/641 rwhp/rwtq
sspaul is offline   Reply With Quote
Old 09-29-2010, 08:31 PM   #4
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
Bore is too small on the LS3 and valves would hit. You have 2 choices to get LS7 heads. Either go with a different block or go with ET small bore LS7 heads. Both options will be very pricey.
Old 09-29-2010, 08:39 PM   #5
Cmlloveless
Drives: 2010 2SS RS
answers my question then doesnt it! Thanks
Old 09-30-2010, 10:11 AM   #6
Jason 98 TA
Drives: Camaro
There's some good options coming very soon though... We have a aftermarket casting LS3 head being finished that will move LS7 flow numbers & still retain all your LS3 hardware. We also are working on a LS7 heads with large & small bore options!
Jason 98 TA is offline   Reply With Quote
Old 10-01-2010, 11:59 AM   #7
gearhead440
gearhead440's Avatar
Drives: Yellow 2SS, 6 speed manual
Stock head flow numbers from Car Craft:
http://www.carcraft.com/techarticles...ocker_arm.html
Hers & His
gearhead440 is offline   Reply With Quote
Old 10-01-2010, 01:03 PM   #8
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
throw the 427 stroker idea out the door... a 4.1" stroke crank is excessive
stock ls3's will flow enough, but if you feel the need to waste money, get a set of ported ls3 heads
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 10-01-2010, 01:24 PM   #9
600hp-lpe
Drives: 2010
I would wait to see what SEMA brings.. it's only a month away.
That's when new parts get announced... especially something like what you want.
600hp-lpe is offline   Reply With Quote
Old 10-01-2010, 01:52 PM   #10
J-Rod6410
M6 10 second club
J-Rod6410's Avatar
Drives: A 4000 Lb BeaSSt
What he said If you're going forced induction with cam, stock LS3 heads would be more than enough.
TEAM LS3 Best pass: 10.49 @ 135 with M6
730RWHP 650RWTQ ECS S/C stock bottom end, 4L80, 9"
Built by: J-Rod.... Tuned by: Matt Sorian @ FSP (floridaspeedandpower.com)
Check out my youtube channel: http://www.youtube.com/user/6410Jrod
Follow me on Instagram: @J_Rod6410
J-Rod6410 is offline   Reply With Quote
Old 10-02-2010, 10:31 PM   #11
redsap05
Drives: 2005 pontiac gto
you would be better off to ditch the ls3 style all together and get some trick flow 235's or afr 230 heads.
redsap05 is offline   Reply With Quote
Old 10-03-2010, 01:10 PM   #12
danhr
BAMF SS
danhr's Avatar
uuhhh so you want him to spend MORE money for a set of heads that flow LESS, and would require him getting a different style intake, and either new fuel rails or an adapter kit?
explantation please
Old 10-04-2010, 03:31 AM   #13
VADER SS L99
explantation please
Yeah unless AFR or Trick Flow come out with a LS3 style head the cathedral port head idea would be a bad costly idea.
Old 10-04-2010, 04:24 AM   #14
klatterblast
klatterblast's Avatar
Drives: 2010 camaro 2ssrs blk.
get L92 ported heads
T-BONES BLACK 2SSRS TEAM L99
CAI w/ADM scoop,Magnacharged 3.8 pulley,L92 ported heads,ss valves,patriot springs,yella terra rockers,Comp cam,L99 to LS3 conv.ATI super damper,Taylor plug wires,NGK plugs,ARH 1 7/8 lt headers w/Borla stingers,Elite oil catch can,trans cooler,Jannetty built Richmond 4.11 rear end,Spohn trailing arms,front Racing Brake rotors,Hawk hps pads,BMR end links,AACstyle lighting. Thanks to Shane & crew for engine work at Thunder Racing & tuner Jeoff at EPS. 501rwhp-463rwtq ++
klatterblast is offline   Reply With Quote
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 07:02 PM
LS9 SC old news. Here comes the LSX. 850HP, 840 lb-ft of Torgue 13F20 5th Gen Camaro SS LS LT General Discussions 15 09-22-2008 05:35 PM
5th Gen Camaro LS3 info from Chevy Hi-Po...READ TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 295 03-07-2008 11:06 AM
LS3 Specs, and Descriptions Mr. Wyndham Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 11-06-2007 02:04 PM
