JUICEDMOTORSPORTS
Old 09-29-2010, 09:27 PM   #1
ilovehooters1385
ilovehooters1385's Avatar
Drives: 2010 Camaro 2SS/RS
Talking KOOKS vs DT vs SW vs ARH
just a couple question if some knowledgable ppl could pm me
have a 3" magnaflow catback already
THANX!
long tube headers only thanx
2010 SS RS A6 20% tint Black K&N CAI Magnaflow Comp series 3" catback
FOR SALE
ilovehooters1385 is offline   Reply With Quote
Old 09-29-2010, 10:12 PM   #2
srb8
srb8's Avatar
Drives: 2011 Yellow 2ss RS, auto, sunroof
I'm having Kooks 1 7/8 LT's installed when they get here. Choice for me was between Kooks and ARH. Kooks is on the G8 so I stayed with them.
Solo Mach XL, Kooks 1 7/8 LT's, Cold Air Inductions CAI, Dyno tune by Modern Muscle, Oswego IL
369 rwhp, 389 rwtq
srb8 is offline   Reply With Quote
Old 09-29-2010, 10:22 PM   #3
caverman
caverman's Avatar
Drives: '69 SS Convertible
So what are your questions?
Build Journal
Old 09-29-2010, 10:32 PM   #4
zirotti
zirotti's Avatar
Drives: 2013 ZL1
Why, at first glance at sites, do ARH look to be about double the price of Kooks?
zirotti is offline   Reply With Quote
Old 09-29-2010, 10:46 PM   #5
caverman
caverman's Avatar
http://www.camaro5.com/forums/showthread.php?t=101391
So that they can give away some fuse box covers with the left over profit.....
Just kidding.....but I had to. That was my initial thought when I saw that thread.
In all reality they aren't double by any means. They might be a few hundred more. You need to make sure you are comparing apples to apples when looking at prices. ARH sells a few different combinations with thier headers and x-pipes. When you compare just the headers and connection pipes between both companies they are actually pretty close in price although from my research the KOOKS are typically cheaper.
Both seem to be great companies with quality headers. Both seem to have great customer service as well. You really can't make a bad choice between either one.
Build Journal
Old 09-30-2010, 12:10 AM   #6
JJ2010
Drives: 2010 Camaro SS
I have Kooks Headers....
JJ2010 is offline   Reply With Quote
Old 09-30-2010, 12:38 AM   #7
Ivan @ Southwest Speed
I guess I'll answer the question the best I can since....well...I've had all three on our SS.
Anthony @ ARH sells their his LT's direct here as well and you can get their LT's for around $800. Great product. Made in America by Americans. Hell yeah.
Brandon at Maryland Speed is the go to guy for Kooks (everybody knows he'll take a deeper discount when you call on them as well.) They are advertised at $913 on his site, but even if/when he takes another $100 bucks off, they're still right around $800.
He also has the SW Headers at $919....same deal. Prolly no less than $800 even with a deep discount.
Then there are Doug Thorley's which sell everywhere for $650.
RPM Inc. did a comparison with the smaller 1 3/4" Doug Thorley's against the larger 1 7/8" Brand A Headers.
When you can get MORE POWER for around a couple hundred bucks less.....it's a tough call to justify the extra money in my opinion.
I'm a customer too and when it comes to my money, I like to do my homework. We appreciate value and that's why we sell the heck out of these headers.
Our bond is with the Customer.
Old 09-30-2010, 12:44 AM   #8
zirotti
zirotti's Avatar
Drives: 2013 ZL1
Hey Ivan, are those ST or LT that were tested from Doug Thorley?
Also, assuming I buy a pair of LTs, what all is needed to match up to my Corsa cat-back? High-flow cats and that is it?
Old 09-30-2010, 01:17 AM   #9
Atti2de
Móderator
Atti2de's Avatar
Drives: 2SS/RS
What no dynatech headers?
I'm not the one with the Atti2de problem it's everyone else that has a problem with my Atti2de!
Atti2de is offline   Reply With Quote
Old 09-30-2010, 02:28 AM   #10
?? May as well include LG's then too.....
Long Tubes sir.
Nothing at all is needed to connect the DT LT's to your Catback. Everything is included with the kits we sell.
Old 09-30-2010, 02:39 AM   #11
MarylandSpeed
MarylandSpeed's Avatar
Drives: 2012 ZL1 & 2010 2SS/RS
Well first off, it has to be an apples to apples comparison. Listed above are the prices for JUST the header. Kooks, ARH, or SW will require some kind of connection pipe, so they cost a little more.
DT's are nice because they are cheap and decent quality. They come coated and bolt to pretty much anything without having to buy extra mid pipes.
That being said they are coated because they are mild steel. I would much rather have an uncoated stainless header than a coated plain steel one. All it takes on a mild steel header one scrap, or something where rust starts, and it peels the coating back like paint off a wall. Do a search for coated Pacesetters on LS1Tech and you will see what I mean. Additionally, DT only comes in 1 3/4" and with no cats. Almost everyone who calls us looking for headers wants 1 7/8" and cats. I know DT is working on a 1 7/8" Tri-Y with cats, but I am willing to bet that ends up running $800-$1000, which makes them not much cheaper than Kooks.
As for the dynosheet posted above..man o man that is a tough one. I am not really sure how to respond to that. My initial thought is that it does not make sense. The DT header should *maybe* if lucky have a little more TQ down low than whatever the other header was. However a 1 7/8" header should, and always WILL make more HP than a 1 3/4" header because the larger primary can flow the maximum exhaust output of the engine better up top. I have been in this now 7 years and that is pretty much a constant. There are some other variables to. Did the other header system have cats? Why did the LT dyno run start almost a 1000 RPM later than the DT run.
I mean I realize arguing the dynosheet thing is silly. As a vendor, no matter what you do dyno wise, people will question the results. That's why when I did my earlier dynotest on the predator I made it a point to do multiple runs in the same setup and really document things. http://www.camaro5.com/forums/showthread.php?t=106919
443-730-9428 - www.marylandspeed.com - Great Prices and Free Shipping!
* CURRENT SALES * ORDER TERMS * DISCOUNT POLICY
MarylandSpeed is offline   Reply With Quote
Old 09-30-2010, 02:56 AM   #12
BlaSSt Off
BlaSSt Off's Avatar
Drives: 2SS/RS
I went with Kooks with high flow cats from Maryland Speed. Customer service was awsome and the girl on the phone was ok with me being from Texas and having Cage The Elephant as my ringback tone. LOL
When I got the headers in, I opened them up and WOW! Those things are a piece of auto art! SUPER EASY to install and sound awsome. I would say go ahead and spend the money to gt a good set of headers now and not have to worry about the quality instead of taking a chance on a cheap set and having to worry about getting a new set down the road because they are rusting. Go ahead and call Maryland Speed and get an awsome price for the Kooks and get them on the way. The only down fall is that they use UPS instead of FedEx Ground.
BlaSSt Off is offline   Reply With Quote
Old 09-30-2010, 03:20 AM   #13
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
Missing JBA from the list too. =)
Old 09-30-2010, 09:04 AM   #14
Anthony@ARH
Drives: Black s2000, 749 ducati dark
If the question is who has an option to work with your 3" catback I have it. If you would like more information please let me know.
Thanks
Anthony
ARH
631.608.1986
Anthony@ARH is offline   Reply With Quote
kooks or arh headers rickjames Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 62 08-25-2010 10:24 PM
ARH vs Kooks headers mattc Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 61 07-18-2010 01:32 AM
ARH, Dynatech, or Kooks??? eynigush Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 58 03-07-2010 02:48 AM
Kooks & ARH SALE @ KY SPEED!!!!!!! FRCBobby V8 Bolt-Ons & Tunes 1 01-06-2010 03:46 PM
Exhaust Sale @ KY SPEED: Kooks, ARH, Magnaflow FRCBobby V8 Bolt-Ons & Tunes 0 10-07-2009 10:08 AM
