| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
![]() Drives: Camaro 2SS RS IBM Join Date: Jan 2009
PTV Cam Clearance?
Ive been looking at this cam but idk if it will require flycutting.
here are the specs: Comp LSR Cam (231/239 .617/.624) 113 LSA any thoughts on the clearence, and is it too big for stock gears and daily driving? |
Supercharged
![]() Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
You will need to clearance the pistons IMHO...what trans do you have?
![]() ![]() ![]() ![]() Drives: Camaro Join Date: Apr 2009
It really depends a lot on how tight p/v your confortable with & how much advance is in the camshaft. It's definitely worth checking at that large of a duration.
BAMF SS
SHOULD clear
but you should check
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over." |
11.12 @ 130mph
Drives: A 4000 Lb BeaSSt Join Date: Jul 2009
I have the cam 1 step bigger in my LS3. I bought it from LMR in Houston. They told me it had plenty of clearance, installed it myself and I do rev it to 7200 (on occasion
). So you should be just fine. BTW the lobes are almost as big as the journals![]() Good luck with your build
TEAM LS3
Built by: J-Rod6410. Tuned by: Matt Sorian @ FSP (floridaspeedandpower.com) Check out my youtube channel: http://www.youtube.com/user/6410Jrod |
#6 |
#7 | |
#8 | |
BAMF SS
#9 |
you can go with a wider LSA to help with ptv clearance.
my youtube
my facebook www.myspace.com/1djchampagne www.twitter.com/1djchampagne mods: borla long tube headers, borla atak catback, lingenfelter gt-9 cam, ported heads, ecs base kit running 11 psi on top end, 1" bmr drop spring, aam 3.70 gears, ported throttle body, 160* thermorstat, lethal racing tune 750/641 rwhp/rwtq |
#10 |
#11 |
![]() Drives: Yellow 2SS, 6 speed manual Join Date: Jan 2010
Take a look at the cam specs for all those tested in this link as food for thought since they all cleared. Notice that none of them had as much duration AND as much lift as the cam you specified.
http://www.gmhightechperformance.com...son/index.html The TSP 231/236 has become quite popular and matches the specs you mentioned closely. http://www.texas-speed.com/shop/item...=1057&catid=44 Following the lead in from SSPaul, a wider LSA will also help your idle characteristics as well.
Hers & His |
#12 |
![]() Drives: Camaro RJT 2SS/RS Join Date: Aug 2009
The lobe lift on the cam you have specified is within tolerance and you there will not be any problems in that regard, I have the the same lift specs on my cam /.617/.624. The Duration is a little on the high side .... That's the only thing i would be the least bit concerned with and I'm not even talking in terms of PTV clearance, that's not the issue. The real issue is with the duration. You are going to lose vacuum there fore causing lack of Intake Idle Air, the car is going to want to stall when coming off the throttle before you tune it (don't worry it's fixable). You are DEF going to have to get it tuned BTW, it's going to run like POO when you first put it in, it's sounds like a monster with the lope though! I also have a 113LSA as well... with a duration of 231/235. I notice the power band has moved up with the cam. It's now between 2800rpm and 7000rpm. It starts leveling off at around 6800. You shouldn't have any problems after it's tuned, just find someone who has the patience, because this one is a BIOTCH.. =O)
2010 RJT SS
Port and Polished, Milled .005 Heads Patriot Valve Springs, Titanium Retainers&locks Manley Race Valves Comp Chromoly push-rods Ported T/B DT Headers, JBA H/F Catted mid pipes Magna Flow Comp series exhaust w/ Xpipe Comp Custom grind Cam Tune and Machine work done by MPC CAI Intake |
#13 |
I never thought choosing a cam would be so difficult!
So would this cam be a safer bet then? : Comp LSR Cam (227/235 .614/.621) 113 LSA |
#14 |
11.12 @ 130mph
235/251 621/624 113LSA. Grind # 285LRR HR13.
TEAM LS3
#15 | |
11.12 @ 130mph
Just verified the right one:227/243 614/624 113LSA. Grind #277LrR HR13. So just a tad bigger on the exhaust side. The one you mentioned would prabably idle a little better. Hope this helps, jrrod.
TEAM LS3
Built by: J-Rod6410. Tuned by: Matt Sorian @ FSP (floridaspeedandpower.com) Check out my youtube channel: http://www.youtube.com/user/6410Jrod Last edited by J-Rod6410; 10-01-2010 at 09:46 AM. Reason: wrong specs. |
#16 |
Drives: 2005 Pontiac GTO Join Date: Jun 2009
It's worth the time to check... easy to do with the heads on with checker springs and a dial indicator.
#17 | |
Supercharged
I use a used head gasket of the same thickness as the one going to be used on the engine, and torque the one head to spec, install pushrod checker and rockers on 1 cylinder and with a low tension checker spring and a solid lifter (you can make one from an old hydraulic lifter by dissasembling and fitting a stiff spring inside to keep it in the same state as a pumped up hyd would when running) I measure the clearance with the valve at the maximum open. I also run it before & past max lift open just for saftey. I target .0080 but never go less than .0060. During this stage you can also determine the proper pushrod length for proper preload & rocker arm geometry. I don't like to "guess" or "assume" as I have to often had parts arrive where a salesman had not figured the heads milled and sent pushrods at a length his guide tells him & if assembled would have resulted in bent valves at the least on startup, and catastrophic failure more likely. I also don't trust the cam was ground properly for "dot-to-dot" assembly and degree every cam install. Can't tell you how many (no matter what company it was from) that the grind was off. Thats why every major cam manufacturer on their site strongly reccomends all the steps I state above. Ussually your fine, but the potential damaage is far to great not to spend the extra time to verify it all. |
#18 | |
He right....
2010 RJT SS
#19 |
BAMF SS
12* more duration is "one step"?
#20 |
Dan these guys need stages and steps to understand cams, go easy on em. lol
#21 |
11.12 @ 130mph
If you take the time to go to the comp cam website, look up the LSR cams for rectangular port heads for LS engines, my cam is listed next to the one the OP mentioned and their listed small to large. So yeah. "one step bigger" is an easy way to help a newb out so they can understand a little better. Sure, you can come up with 100's of cams in between the 2 by going custom, but why add to the confusion
TEAM LS3
#22 |
BAMF SS
must be two steps in their selection guide. lol.
I am doing a stage 5 build on my camaro. lol
#23 |
11.12 @ 130mph
Let me know how it goes, I was thinking of a stage 6.5 myself for next year. I wanna make sure mines bigger than yours
TEAM LS3
#24 |
no wider meaning higher number like 113-116
my youtube
#25 | |
Syntax Error
No issues with PTV clearance here either. |
| Thread Tools | |
| Cam basics | CamaroSpike23 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 59 | 01-27-2013 07:28 PM |
| Finally--VMS Stage 2.5 cam Dynojet results, nice gains! | topgun1 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 32 | 11-25-2010 09:55 AM |
| VVT Cam Specials! | yyz28 | Engine Internals | 17 | 10-18-2010 11:29 PM |
| Big H/C cars inside. PTV clearance question | danhr | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 21 | 07-27-2010 07:46 PM |
| Camshaft Basics | Milk 1027 | Wiki | 1 | 12-09-2009 12:00 AM |
