ADM PERFORMANCE
Old 09-29-2010, 11:02 PM   #1
Arsenal11
Drives: 2010 2SS
Cam Question!
Hey I may be looking into getting cams for my SS. How much do they run? What kind of HP gains do they give on average? Also are they hard to install?
Thanks
Arsenal11 is offline   Reply With Quote
Old 09-29-2010, 11:50 PM   #2
BLACK10
BLACK10's Avatar
around $600-900 for a cam kit.. around 80-100rwhp with the cam and headers/dyno tune is average
Old 09-30-2010, 05:49 AM   #3
sspaul
sspaul's Avatar
Drives: 2010 ss camaro, imperial blue
Send a message via AIM to sspaul Send a message via Yahoo to sspaul
like black10 said around $600-$900 for the kit, gains will vary depending on your choice of cam. what are your goals so you can choose the right cam for you
my youtube
my facebook
www.myspace.com/1djchampagne
www.twitter.com/1djchampagne
mods: borla long tube headers, borla atak catback, lingenfelter gt-9 cam, ported heads, ecs base kit running 11 psi on top end, 1" bmr drop spring, aam 3.70 gears, ported throttle body, 160* thermorstat, lethal racing tune
750/641 rwhp/rwtq
sspaul is offline   Reply With Quote
Old 09-30-2010, 08:52 AM   #4
SC2150
Also, they only have one cam. No dual or quad overhead cam on the american V8 & V6 in the Camaro's.
Old 09-30-2010, 08:58 AM   #5
klatterblast
klatterblast's Avatar
Drives: 2010 camaro 2ssrs blk.
if its an L99 you will have to do dod & vvt delete unless you go with a vvt cam but expect about a $3500.00 bill when your done on the L99.
T-BONES BLACK 2SSRS TEAM L99
CAI w/ADM scoop,Magnacharged 3.8 pulley,L92 ported heads,ss valves,patriot springs,yella terra rockers,Comp cam,L99 to LS3 conv.ATI super damper,Taylor plug wires,NGK plugs,ARH 1 7/8 lt headers w/Borla stingers,Elite oil catch can,trans cooler,Jannetty built Richmond 4.11 rear end,Spohn trailing arms,front Racing Brake rotors,Hawk hps pads,BMR end links,AACstyle lighting. Thanks to Shane & crew for engine work at Thunder Racing & tuner Jeoff at EPS. 501rwhp-463rwtq ++
klatterblast is offline   Reply With Quote
Old 09-30-2010, 09:01 AM   #6
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
I hope that's a LS3 conversion bill...
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 09-30-2010, 10:29 AM   #7
Arsenal11
Drives: 2010 2SS
Its for LS3. I'm just looking for something less than $800 that gives some good numbers. I'm new to this kind of stuff so I don't know exactly know what to look for haha. i just love the idle sound when it has cams
Old 09-30-2010, 11:29 AM   #8
mr. anderson
Drives: 2015 Camaro 2SS 1LE
dont' forget the tune for the car once you put the new cam in. if your buying one that's at least 300 for the tuner. not including a custom "cam" tune.
2015 White 2SS 1LE
2011 Black Mustang GT
2012 Ducati Panigalee 1199 Tricolore
2011 Ducati Diavel Carbon black
mr. anderson is offline   Reply With Quote
Old 09-30-2010, 11:56 AM   #9
Dr Jkel
and MR. HYDE
Dr Jkel's Avatar
Drives: 2010 2SS RJT/BLK 6Spd Man
If you are going to do a cam there are a few things to take into consideration to have longevity, dependability and drivability.
I had my cam changed and this is kind of a list of things that I had to buy for this install:
Cam
Dual Valve Springs
Trunion Kit
Hardened Push Rods.
It was also suggested that I put a Melling High Volume Oil Pump in when I did this. I did and amd gals since there is a TSB out for the oil pumps now.
I installed headers, hf cats, cam, cai, and the above items when this was done, plus new plugs, oil change and a couple of other things like dyno tuned, underdrive pulley etc...
It cost me around 4000.00 maybe a little less for everything parts and labor which is not too bad. I increased from about 360 rwhp to about 450 rwhp and you can tell a big difference.
MUSTANG...Like Bringing a Hot Dog to a Steak Dinner....There is no comparison.
Dr Jkel is offline   Reply With Quote
Old 09-30-2010, 02:19 PM   #10
Jason 98 TA
Drives: Camaro
Checkout www.texas-speed.com we have cam packages & dyno sheets for each of our camshaft packages on the site!
http://www.precisionracecomponents.com/231236idle.wmv
Jason 98 TA is offline   Reply With Quote
Old 09-30-2010, 05:00 PM   #11
sspaul
sspaul's Avatar
what kind of numbers are you looking to get? me personally i would go as big as can and still be streatable. no matter what cam you go with you are gonna be spending about the same amount of money
my youtube
my facebook
750/641 rwhp/rwtq
Hot Cam install question gearhead440 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 36 02-21-2011 12:23 AM
Vector Motorsports Stage 2.5 cam kit installed! pics and video topgun1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 38 12-18-2010 11:28 PM
LS3 cam question 4xchamp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 05-04-2010 06:41 PM
Cam question Gunsmoke Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 04-17-2010 05:38 PM
Cam gear question 4xchamp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 04-16-2010 08:01 PM
